Question about AT&T 874 4-Line Phone
How do I factory reset my AT&T 954 4 line phone
Panasonic WV NS 954 PASSWORD RESET TO FACTORY DEFAULT
Hi
there is no Password reset to default.
in order to restore the camera setting to default are by doing a restore to default inside the configuration page, or , by doing hard reset on the camera by pressing the reset button
Feb 03, 2014 | Panasonic Wvns954 I-pro Wv-ns954 Ip Ptz...
Hello. I tried to reset my new Sony Ericsson Xperia X10 in line with he user guide. I went from Settings to SD Card & Phone storage settings, but from there I cant find the 'Factory data Reset' option...
1 From the Xperia 10 Home screen, tap the applications bar.
2 Tap Settings > SD card & phone storage > Factory data reset > Reset phone.
3 Enter your screen unlock pattern.
4 Tap Erase everything.
Done! Now, You can reset your Xperia X10 to its factory default settings.
Mar 25, 2011 | Sony Ericsson XPERIA X10 Cell Phone
Need to rest phone
To Reset & clear your phone
To reset your phone to factory settings and erase all
the data on your phone, press Menu > Settings
> SD card & storage > Factory data reset > Reset
phone.
Warning: All downloaded apps and user data on your
phone will be deleted. Data on your memory card will
not be deleted.
from the Cliq manual which can be found here
http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/MOTOROLA_CLIQ_MOTOBLUR/US-EN/_Documents/Static_Files/CLIQ_UG_TMO_final_68000202382a.pdf
Mar 05, 2011 | Motorola Mobility CLIQ Cell Phone
I have 3 of the 954 model. If im using the phone
Do you have DSL on the first line? I would say that you have split the line to the phones so that they are not able to recognize the off hook from your office phone because each phone has a DSL filter. So take your phone line from the back of the DSL modem (line 1) and split it to all of the phones. Put the filter in the line, if you need one before the splitter.
Jun 15, 2010 | AT&T 954 Corded Phone
Laptop dv9000
What are these codes can you please explain inorder for me to help you out...
Jul 11, 2009 | Computers & Internet
Phone ringing after power failure
I believe you have to reset the intercom system, meaning you need to reassign one or all of the phone's intercom numbers. To assign intercom # ( found on page 10 of the manual which you can download online)
1 Do NOT lift handset
2 Press the following 3 buttons (in order) PROGRAM, STAR, and then POUND
3 Enter two digits (the number you want the phone to be)
4 Press the INTERCOM button and you will hear a tone - then youre all done.
Aug 03, 2008 | AT&T 954 Corded Phone
Format N95
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
Billman87
Nov 16, 2007 | Nokia N95 Cellular Phone
Lands Phones Logo
95 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
