Question about GE Washing Machines
THE PULLEY ON MY WASHER MODEL # WCVH6600H0BB KEEPS COMMING LOOSE AND THE BELT COMES OFF I TIGHTEN IT AND AFTER 1 WASH IT IS LOOSE AGAIN HOW DO I FIX THIS PROBLEM THANKS
SOURCE: whirlpool GHW9100LW1, belt came off
I had the same problem and being a procrastinator, I waited until the belt came off before launching a full scale investigation into the knocking noise it had been making for about a year. Here is what I found and below that is my no guarantees fix.....
I removed the nut and pulled the tub pulley off. I noticed the tub shaft has a "shoulder bolt" and the pulley could not be tightened onto the shoulder bolt with enough squeeze to keep the tub pulley from wobbling. Tolerance issue... maybe? I decided to measure the keyed tub shaft with calipers and found the thickest part of the shaft to be 1" ish. The Shaft is part of the tub bearing assembly (from my observation) and the tub shaft is part of the tub bearing which measured 1 1/4" diameter. I found a washer that was 1" inside diameter and 1 1/4" outside diameter and placed it over the tub shaft behind the tub pulley. I tightened the nut snugly and reinstalled the belt. Ahhhhh, quiet operation and no more wobble. I will let you know if it causes another problem but from what I can tell.... replacing the tub pulley with another of the same dimensions will not work.
you don't need a very thick washer(my washer is too thick (.1"ish) so I will replace it soon(yeah right) with 1/32" or maybe 1/16"...I used rubber but I think steel or brass or what ever would probably work too.
Purists will tell you that the lock nut should be replaced, or if you don't use the permanent thread locker you could use loctite.
Hope that helps.
Posted on Oct 02, 2008
mumma_1
  • 903 Answers
SOURCE: BELT LOOSE ON FRIGIDAIRE WASHER HOW TO TIGHTEN
you can't really tighten a belt, I suggest that you change it, although it is extremely hard to replace a a new belt yourself. Have you checked the carbon brushes in the motor do not need changing, this could also generate a burning smell and leave you clothes wet if they are worn.
Posted on Nov 15, 2008
tiphinze
SOURCE: Chamberlain Whisper Belt Drive
door does not close without holding wall button in
Posted on Nov 21, 2008
  • 686 Answers
SOURCE: LA612 maytag washer. motor too
get yourself a new belt the old one is stetched and no longer good
Posted on Jan 08, 2009
RepairClinic
  • 32 Answers
SOURCE: Machine not spinning properly
The top of the washer lifts up like a car hood after two clips between the top and the front panel are pushed with a putty knife. Once the top is flipped open, the screws that hold the front panel in place at the top can be removed and the panel lifted off. The belt may be bad or something may be stopping the belt like a bad pump. Or the transmission drive pulley and bearing may be going bad. If the bearings above the transmission drive pulley fail the brake will not release correctly in the spin cycle causing weak, slow or no spin. The belt & pulley system can be accessed by tipping the washer back. The belt is routed around all three pulleys under the washer and is fairly loose until the motor starts. It is the torque of the motor that gives the belt tension. Leaking or loud "jet engine" sound in spin indicates a bad main tub seal at the outer tub which has caused the spin bearing to fail. This is a complicated repair as the inner and outer tubs need to be removed from the washer to access and replace the seal and bearing components. Enter your model number into the PartDetective on the Find & Order Parts page to see all the parts available for the unit.
Go here for Magic Chef Washer Parts: http://www.repairclinic.com/Magic-Chef-Washing-Machine-Parts
www.RepairClinic.com
Posted on Feb 11, 2009
Where do I find the timing marks on pulleys?
in the factory service manual FSM.
or
login to
alldata.com
and read all the steps
3VZ-FE (and 2vz)
this is your engine. and has many steps
key is timing and proper belt tension and is free running engine.
quote
Prior to timing belt removal, make sure all the match-marks are there-2VZ-FE and 3VZ-FE engines
less photos:
the crank mark is CR -line
the cam pulleys, 3v pulley to R-cam mark
and 3v pulley to L-cam mark. (photos are best).
  1. Remove the timing belt.
If the timing belt is to be reused, draw a directional arrow on the timing belt in the direction of engine rotation (clockwise) and place matchmarks on the timing belt and crankshaft gear to match the drilled mark on the pulley.
  1. With a 10mm hex wrench, remove the setbolt, plate washer and the No. 1 idler pulley.
  2. Remove the crankshaft timing pulley, if it can NOT be removed by hand, use two flat bladed tools. Position shop rags on the components to prevent damage.
TO INSTALL:
  1. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Slide the timing pulley on so that the flange side faces inward.
  2. Apply bolt adhesive to the first few threads of the No. 1 idler pulley setbolt, install the plate washer and pulley and then tighten the bolt to 25 ft. lbs. (34 Nm).
  3. Install the timing belt on the crankshaft timing, No. 1 idler and water pump pulleys.
If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing cover and tighten the bolts.
  2. Align the crankshaft pulley set key with the key groove on the pulley and slide the pulley on. Tighten the bolt to 181 ft. lbs. (245 Nm).
  3. Install the No. 2 idler pulley and tighten the bolt to 29 ft. lbs. (39 Nm). Check that the pulley moves smoothly.
  4. Slide the left pulley, facing the flange side outward. Align the knock pin hole of the camshaft with the knock pin of the timing pulley, then install the knock pin. Tighten the left camshaft timing pulley bolt to 80 ft. lbs. (108 Nm).
  5. Set the No. 1 cylinder to TDC again. Turn the right camshaft until the knock pin hole is aligned with the timing mark on the No. 3 belt cover. Turn the left pulley until the marks on the pulley are aligned with the mark on the No. 3 timing cover.
  6. Check that the mark on the belt matches with the edge of the lower cover. If not, shift it on the crank pulley until it does. Turn the left pulley clockwise a bit and align the mark on the timing belt with the timing mark on the pulley. Slide the belt over the left pulley. Now move the pulley until the marks on it align with the one on the No. 3 cover. There should be tension on the belt between the crankshaft pulley and the left camshaft pulley.
  7. Align the installation mark on the timing belt with the mark on the right side camshaft pulley. Hang the belt over the pulley with the flange facing inward. Align the timing marks on the right pulley with the one on the No. 3 cover and slide the pulley onto the end of the camshaft. Move the pulley until the camshaft knock pin hole is aligned with the groove in the pulley and then install the knock pin. Tighten the bolt to 55 ft. lbs. (75 Nm).
  8. Position a plate washer between the timing belt tensioner and the a block and then press in the pushrod until the holes are aligned between it and the housing. Slide a 1.27mm (3VZ-FE 1.5mm) Allen wrench through the hole to keep the push rod set. Install the dust boot and then install the tensioner. Tighten the bolts to 20 ft. lbs. (26 Nm). Don\'t forget to pull out the Allen wrench!
  9. Turn the crankshaft clockwise two complete revolutions and check that all marks are still in alignment. If they aren\'t, remove the timing belt and start over again.
  10. Install the right engine mount bracket and tighten it to 30 ft. lbs. (39 Nm).
  11. Position a new gasket and then install the upper (No. 2) timing cover. refer to the illustration for bolt positioning.
  12. Install the spark plugs.
  13. On the 2VZ-FE, install the right engine mount insulator. Tighten the bolt to 47 ft. lbs. (64 Nm), the bracket nut to 38 ft. lbs. (52 Nm) and the body nut to 65 ft. lbs. (88 Nm). Install the No. 1 stay and tighten it to 38 ft. lbs. (52 Nm). Install the No. 2 stay and tighten the bolt to 48 ft. lbs. (66 Nm) and the nut to 38 ft. lbs. (52 Nm).
  14. On the 3VZ-FE, install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm). Install the right stay and tighten it to 23 ft. lbs. (31 Nm).
  15. Install and adjust the drive belts.
  16. Install the fender apron seal and the wheel.
  17. On the 3VZ-FE, install the No. 2 stay and tighten the bolt to 55 ft. lbs. (75 Nm), the nut to 46 ft. lbs. (62 Nm). Install the No. 3 stay and tighten it to 54 ft. lbs. (73 Nm).
  18. Install the coolant overflow tank and the washer tank.
  19. Install the power steering reservoir tank and the cruise control actuator.
  20. Connect the battery cable, start the car and check for any leaks.
end quote.
Feb 27, 2014 | 1993 Toyota Camry V6
Managemylife com
See if there is a pulley on the belt that can be moved to tighten the tension. Often the motor's mounting bolts can be loosened and the motor itself can be moved to tighten the belt and restore friction. If not possible, a new tight belt is in order.
Nov 23, 2013 | Maytag Dryers
I am having problems with my front loader washer. The belt keeps coming off.
Check the pulley If is loose tighten the pulley If it is making oblong shapes you need to replace the pulley
Jul 12, 2011 | Frigidaire ATF6000ES Front Load Washer
4cyl 2000 honda accord engine stalls while idling, recently died and will only start for short periods... possible problems/solutions?
check for spark and fuel after it dies.
If there is spark but no fuel, then the fuel pump may be bad or a clogged fuel filter.
If there is fuel but not spark, then the ignition control module or the ignition coil could be bad.
Also, check that the timing belt is timing the engine correctly.
Timing Belt & Balancer Belt
Removal & Installation
2.3L Engine
To Remove:
  1. Record anti-theft code for radio.
  2. Disconnect battery negative cable then positive cable.
  3. Turn crankshaft pulley until TDC is achieved.
  4. Raise and safely support vehicle.
  5. Remove front tire assembly.
  6. Remove splash shield.
  7. Remove power steering belt.
  8. Remove alternator and alternator bracket.
  9. Safely support engine under oil pan.
    Upper bracket removal
  10. Remove stop, detach ground cable and remove upper bracket.
  11. Remove cylinder head cover.
  12. Remove upper cover.
  13. Remove dipstick and tube assembly.
  14. Remove crankshaft pulley.
  15. Remove adjusting nut rubber seal and remove lower cover.
    Timing belt/balancer belt removal
  16. Loosen adjusting nut 1 turn.
  17. Push up on balancer belt tensioner to relieve belt tension.
  18. Push down on timing belt tensioner to relieve belt tension.
  19. Tighten adjusting nut 1 turn.
  20. Remove balancer belt and timing belt.
To Install:
NOTE: Clean balancer belt drive pulley, timing belt pulleys and
upper/lower timing cover prior to belt installation.
  1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple
    on oil pump.
  2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align
    with top of cylinder head.
    Timing belt installation
  3. Starting with driver pulley, install timing belt in a counterclockwise
    sequence.
  4. Loosen and ten retighten adjusting nut.
  5. Install balancer belt drive pulley.
    NOTE: Inspect rubber seal on lower cover and replace as necessary.
  6. Install lower cover.
  7. Install crankshaft pulley and bolt.
  8. Rotate crankshaft pulley counterclockwise several times to seat belt.
  9. Loosen adjusting nut 1 turn.
  10. Rotate crankshaft counterclockwise 3 teeth on camshaft pulley.
  11. Tighten adjusting nut to 33 ft lb (44 Nm).
  12. Turn crankshaft pulley until TDC is achieved.
  13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top
    of cylinder head.
  14. Remove crankshaft pulley and lower cover.
  15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm
    timing cover bolt.
  16. Loosen adjuster nut 1 turn and ensure that belt tensioner freely moves.
  17. Push tensioner up and tighten adjusting nut.
    Balancer shaft alignment
  18. Remove bolt and washer from maintenance hole.
  19. Using a 6 X 100 mm bolt, scribe a mark 2.9 in (74 mm) from end.
  20. Insert bolt into maintenance hole and hole in balancer shaft.
  21. Install bolt up to scribed line.
  22. Align groove on balancer shaft with pointer on oil pump housing.
  23. Install balancer belt and loosen adjusting nut 1 turn to tension.
  24. Retighten bolt.
  25. Remove bolt from maintenance hole and install bolt and washer. Tighten to
    22 ft lb (29 Nm).
  26. Reinstall crankshaft pulley.
  27. Loosen adjusting nut 1 turn.
  28. Rotate crankshaft pulley counterclockwise 1 turn and tighten adjusting nut.
  29. Remove bolt from timing belt adjuster arm.
  30. Remove crankshaft pulley.
  31. Install lower cover.
  32. Install seal at adjusting nut.
    NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to
    installation.
  33. Lubricate crankshaft pulley bolt between head and washer and bolt threads
    with clean engine oil.
    CAUTION
    Do not use impact wrench to perform
    following step.
  34. Install crankshaft pulley and tighten bolt using special tools to 181 ft
    lb (245 Nm)
  35. Install dipstick/tube assembly.
  36. Install upper cover. Tighten bolts to 9 ft lb (12 Nm).
  37. Install cylinder head cover.
  38. Install alternator bracket and alternator.
  39. Install power steering pump belt and alternator belt.
    Upper bracket installation
  40. Install upper bracket and tighten fasteners in proper numbered sequence.
  41. Install stop.
  42. Install battery and enter radio anti-theft code.
Oct 29, 2010 | 2000 Honda Accord
Hiwich timing mark I used to time the balancer shaft on a 99 honda accord with a 2.3L
To Install:
NOTE: Clean balancer belt drive pulley, timing belt pulleys and upper/lower timing cover prior to belt installation.
  1. Set timing belt drive pulley to TDC by aligning dimple on pulley with dimple on oil pump. honda-03-23-3426.gif
  2. Set camshaft pulley to TDC so that "UP" mark is at top and grooves align with top of cylinder head. Timing belt installation honda-03-23-3549.gif
  3. Starting with driver pulley, install timing belt in a counterclockwise sequence.
  5. Install balancer belt drive pulley. NOTE: Inspect rubber seal on lower cover and replace as necessary.
  13. Ensure that camshaft pulley "UP" mark is at top and grooves align with top of cylinder head.
  15. Rotate crankshaft to TDC again and lock timing belt adjuster arm with a 6 mm timing cover bolt.
  17. Push tensioner up and tighten adjusting nut. Balancer shaft alignment honda-03-23-3556.gif
  21. Install bolt up to scribed line. Balancer shaft alignment honda-03-23-3557.gif
  25. Remove bolt from maintenance hole and install bolt and washer. Tighten to 22 ft lb (29 Nm).
  29. Remove bolt from timing belt adjuster arm. NOTE: Inspect rubber seal on lower cover and replace as necessary.
  32. Install seal at adjusting nut. NOTE: Crankshaft pulley, bolt and washer must be cleaned prior to installation.
  33. Lubricate crankshaft pulley bolt between head and washer and bolt threads with clean engine oil. honda-03-23-3537.gif
    CAUTION
    Do not use impact wrench to perform following step.
  34. Install crankshaft pulley and tighten bolt using special tools to 181 ft lb (245 Nm).
  39. Install power steering pump belt and alternator belt. Upper bracket installation honda-03-23-3420.gif
  41. Install stop.
Jul 03, 2010 | Cars & Trucks
Belt keeps comming off
can u put a lock washer on bolt or lock tight grease ?
Feb 04, 2010 | Washing Machines
How i fix timing of lantra 1600 cc 95
Disconnect battery earth lead. Do not turn crankshaft or camshaft when timing belt removed. Remove spark plugs to ease turning engine. Turn engine in normal direction of ratation unless otherwise stated, Support engine. Remove, engine mounting, auxilliaty drive belts. Water pump pulley 1. Crankshaft pulley bolts 21. crankshaft pully 2. timing belt covers 3. Turn crankshaft to TDC on No 1 cyclinder. Ensure crankshaft sprocket, camshaft sprocket, oil pump sprocket and balancer shaft sprocket timing marks aligned. Timing marks on camshaft sprockets should align with cylinder head upper face. Dowel pins on camshaft sprockets should face upwards. Slacken tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove, automatic tensioner unit bolts. Automatic tensioner unit. Timing belt, crankshaft centre bolt, crankshaft sprocket. Crankshaft sprocket guide washer. Slacken blancer shaft belt tensioner bolt. Move tensioner away from belt and lightly tighten bolt. Remove balancer shaft belt.
Installation
Ensuring timing marks arligned. Note timing marks on camshaft sprockets should align with cylinder head upper face. Exhaust sprocket mark is on recess, but inlet sprocket mark is on tooth. Note: to check oil pump sprocket positioned correctly, removing blanking plug from cylinder block. Insert 8mm diameter Phillips srcrewdriver in hole. Ensure screwdriver is inserted 60mm from face of cylinder block. if screwdriver can only be inserted 20mm: turn oil pump sprocket 360°. Insert screwdriver again. Fit balancer shaft belt in anti-clockwise direction, starting at crankshaft sprocket. Slacken balancer shaft belt tensioner bolt. Turn tensioner clockwise to tension belt. Tighten bolt to 15-22Nm. Apply thumb pressure to belt. Belt should deflect 5-7 mm. If not repeat tensioning procedure. Install crankshaft sprocket guide washer, crnakshaft sprocket. Tighten crankshaft cente bolt. Tighten torque:110-130 Nm. Note ensure crankshaft sprocket guide washer is fitted correclty. Oil treads and contact face of crankshaft body before fitting. Check tensioner body for leakage or damage replace if necessary. Check pushrod protrusion is 12mm. If not replace automatic tensioner unit. Slowly compress pushrod into tensioner body until holes aligned. Resistance should be felt. Place flat washer under tnesioner body to avoid damage to body end plugs. Retain pushrod with suitable pin through hole in tensioner body. install automatic tensioner unit to cylinder block. Tighten bolts to 22-27Nm. Fit timing belt in anti-clockwise direction, starting at the tensioner pulley. Slacken tensioner pulley bolt. Turn tensioner pully clockwise to temporarily tension belt. Tighten bolts to 43-45Nm. Turn crankshaft slowly 1/4 turn anti-cockwise. Turn crankshaft clockwise until timing marks alligned. Slacken tensioner pully bolt. Fit tool to tensioner pulley. Tool No 09244 28100. Apply clockwise torque of 2,6-2,8 Nm to tensioner pulley. Tighten bolt to 43-45Nm. Insert special tool in timing belt rear casing. Tool no 09244-28000. Screw in tool until pin can be removed from automatic tensioner unit. Remove special tool. Tool nr 09244-28000. turn crankshaft two turns clockwise. Wait 15 minutes. Ensure timing marks aligned. Check extended length of pushrod is 3,8-4,5mm. Install components in reverse order of removal. Tighten crankshaft pulley bolts, Tighten torque 20-30Nm
Nov 01, 2009 | 1995 Hyundai Elantra
Our belt came off but we don't know how to put it back on
1. Look and find the pulley tensioner of your
washer, and loosen it up. This is a bolt holding
the motor base,and allow the base to move and
loosen the belt or tighten it.
2. When it is loose, you just put the belt back on the
big pulley track and then, on the small pulley.
3. Full the tensioner back in place to tighten the belt.
Just follow this instruction, and solve your problem.
Sep 28, 2009 | Whirlpool 3.2 cu. ft. Plus Washer
GHW9250ML0 - belt off, pulley misalignment, bearing ok
no pulley should have that much clearance or movement....Something is seriously worn. Perform surgery and find out what failed.
you will have poor performance until you get this issue resolved and tighten the belt correctly.
Sep 25, 2009 | Washing Machines
Knocking Whrilpool Duet
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub. However, if your machine is knocking like you say it is, it could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped. Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin. To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble. More than likely, though, the drive belt would slip off. I have also seen where the hole in the center of the drive pulley starts to "round out". The hole is not perfectly round and has to flat sides. Sometimes over time the drive shaft will start to slip around the flat sides, causing the pulley to rattle during the spin cycle. If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out. Now this should be a noticeable metal on metal type feel. Not the normal motion of the wash tub moving up and down from the motion of the shocks. The tub bearing is not a cheap (or easy) fix. The entire back section of the rear outer tub shell has to be replaced, because the bearing is molded into the plastic. Check all the easy things first. Let me know if this helps.
Jun 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
53 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
