Question about Whirlpool Dryers
I have a Whirlpool Electric Dryer Model #LER7646DQ1 and received a repair kit with 2 parts but the connections are different than the old ones (different # of connections)
  • Whirlpool Master
  • 2,696 Answers
What parts did you get,was it the two thermostats,if so the other connectors should be in the bag too.
Posted on May 19, 2011
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Can I stack a new whirlpool washer model # WFW72HEDW with an old whirlpool washer model # WED9270XW1? If yes, what stacking kit do I need to use? Can I stack a new whirlpool washer model # WFW72HED
As we could see new one are not compatible with older one as size and dimension of new washer are changed but in case you could try .It is simple just try compatibility of your older washer stack kit with new one in most new model
Oct 14, 2014 | Whirlpool 8541503 Duet Stack Kit 8541503
How to connect dryer wires to thermal cutoff
The first thing I would like you to do is get your model number from the dryer, it is located near the inside the of the dryer door. you need to make sure you have the right heater and thermal cutoff kit. The manufacture has more than one type of heater and thermal cutoff kit out, (( some will not work with others ))... Call another parts store or sears and make sure you have the correct parts !!
Most of the thermo cutoff kits have direction and if they are not making scence then the chance of you having the rong one is good !!!!!!!
If you remove the thermal cutoff from your origanal heater and then look at how many conetion pins are left. The new heater and old heater should be the same.
The most common heater is the 2 conection. But they made one with three. and if you have the one with three, it has to be replaced with the same one !!!
Without knowing the model of your machine, I cant tell you how to wire your machine.
I recomend you use the direction that came with the Cutoff kit.
Aug 11, 2010 | Kenmore 62602 Electric Dryer
Pilot light goes out about 2 minutes after starting dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 25, 2010 | Whirlpool LER4634J Electric Dryer
My 5 year old Whirlpool dryer just didn't start one day.Instead of dealing with repair,we got a used 4 year old Maytag dryer.It dried the first load,then when I pushed the start button it made a weird...
It is the motor winding shorted out which caused the smell. If you still have your old dryer the safty thermal located on the exhaust housing is blown. White plastic with 2 wires going to it. Very inexpensive repair. Hope this helps.
Feb 13, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
The new high limit thermostat has different prongs than old one. I have one small wire clip and 1 larger clip coming from the dryer, but this therm. has both the same size posts? Any advice?
The correct part you should have gotton , with the small extra terminal is pt # 3977767 , however , there is a pt which comes with the thermal cut-off and high limit , with the jumper wire to exclude this small terminal . If you received only the 2 t-stats , then you got the wrong part .
Oct 11, 2009 | Whirlpool LER5636P Electric Dryer
Replacing heater element
on your old heater there was a "thermostat, mounted to the lower end of the heater correct?? youllneed to remount that to the new heater( one end will gp to one terminal on heater) ohter "thick wire" goes to the other heater terminal, and on eto the open thermostat connectore, the last wire should be smaller in size and connect to teh side of the thermostat you just installed
Jan 21, 2009 | Whirlpool LEQ9858P Electric Dryer
Heating element for kenmore dryer won't turn on
Hi, I have an 11yr old 80 series elec. dryer and just fixed the same problem. On the heater element is a thermostat with 2 wires and above that about 14" is another piece with 2 wires. I had to replace the top one. They sell them together in a kit called Thermal cut off kit. Sears sell it for 25.49 look up part number 279816 or 3399848 again these numbers are for my dryer but you can look them up on the sears parts web site. If you have a sears service center near by they let me buy the parts to see which one it was and then return the ones I didn't need. I hope this helps.Good luck
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Installing a new heating element on my Whirlpool dryer.
shouldnt make a diff, the orange wire can only go in one place,adn the 2 reds make no difference.. the only thing you need to do is remove the thermostat from the oldelemnt and install it on the new heater
Dec 04, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
55 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
