Question about John Deere Garden
Have a 2005 john deer gt245 tractor carb fills bowl fills up with gas and wont start any thought thanks
  • 31 Answers
After cranking for 5 seconds pull the spark plug, if it is dry the carb needs to come off and be cleaned out. If it is wet is is probably ignition related.
Posted on May 19, 2011
WHY DOES ENGINE IDLE UP & DOWN
Carb adjustments need to be made.
Aug 30, 2014 | John Deere Garden
I have a John Deer riding lawn mower SX95 with a fb460v kawasaki engine that only starts with fuel dropped into carburetor I have a good spark , I had changed the oil and filter , I also took the carb...
in the carb did any of the screws have any micro bored holes for gas to go through like in many small engine iv found . clogged with goop. does it have a gas bowl an a screw on bottom take it out if does an look it over close.
Jul 25, 2014 | John Deere Garden
My John Deere LA115 mower sat for about 5 months. It started right up but immediately began flooding out. With the spark plug out and connected, it fires fine when the motor turns over, but the piston is...
sounds to me the flaots are stuck open and allowing gas to continue to flow..They tend to gum up and stick after a few months with the new gas we have.The carbs are fairly simple remove bowl and clean well with carb cleaner..You can try it with out removing and it may work but better if you remove to make sure float is work properly..it has a little pin attatched to the floats , that gets stuck and causes gas to keep flowing into the bowl...
Mar 10, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John Deere troubleshooting
Fuel starvation: Plugged filter or needle valve in the carb. The fuel is not getting to the carb fast enough to keep the float bowl filled.
Oct 30, 2013 | Garden
John Deere 624
first make sure your float bowl does not have water in it. make sure the needle attached to the float is not stuck in the needle seat.clean and blow out the carb.
Oct 14, 2013 | Garden
I need a deck that will fit a 2005. John Deere GT245
Craigslist.com people part out their lawn tractors all the time on there
Oct 03, 2012 | John Deere Garden
I have a John deere 316 with a onan and it will not run unless the choke is almost closed, I have checked the fuel flow and the compression and all seems good. What do you think is wrong?
hello sir, mower will not start or run,runs only when primming, does it have good spark,good compression,or only runs on full choke, are you getting fuel to the engine if not try this,your fuel pump or your carb. is clogged up here is what you can do for a simple repair for the carb,you can remove the air filter and assy, empty fuel tank and clean out tank and line,remove the bowl nut and bowl careful of the gaskets,now spray carb cleaner in the small port holes in the carb steam in the middle of the carb until clean,now spray the bowl nut holes until clean there are three,after cleaning put bowl on the same way you removed it with dip towards front of float,put bow, and fresh gas,you should be good to go,hope this helps.,thank you.~~
Feb 22, 2012 | John Deere 420,1020,2010,2020,2510,2520...
2yr old x300 john deere riding lawn mower wont turn over
Chk the fuel by draing the carb bowl and the black thing may bea ck valve. Remove it and see what happens. Oh! drain the old fuel entirely and fill with fresh fuel. Good Luck
May 28, 2010 | John Deere 420,1020,2010,2020,2510,2520...
3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Jul 04, 2009 | John Deere 3010,3020 Tractor Basic...
John deere tractor won't stay running
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Jun 22, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
327 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
