Voltages in power supplay ok. no diplayn no sound.no stan by light. no power on
  • Antonio Zelaya May 20, 2011
    PRO-940 HD PIONEER PLASMA DISPLAY
    WHERE IS THIUS COINTRL BOARD LOCATED.
  • 10,594 Answers
Apparently it seems main board/ control board problem.
What is model number and brand of tv?
Thanks.
Posted on May 19, 2011
  • Shahid Electronics
    Shahid Electronics May 20, 2011
    Click HERE to view main board image, do you have service manual of
    PRO-940 tv?
    Plasma tv boards are very expensive so please make sure that subject board is bad before ordering, service manual will help you to troubleshoot the problem and sort out defective board. I can just give you an idea about problem location over internet support that can be wrong because tv is not in front of me so I would advise to have related service manual copy in hand and go through troubleshooting chart mentioned in service manual to pin point the bad board.
    Honestly I would buy new lcd tv instead of investing money on plasma tv repair.
    Thanks.
Error code 03130031-2618
It mean "Vh voltage error" and can be cause of short circuit in the printhead . Sometimes you can get good result with printhead changing, but it is not guarantied because of possible printer electric parts (carriage board, flat cable, motherboard or power supply) damage. For printhead changing, delete paper and use Service mode (hold Paper sourse + Information while switching printer on).
Apr 13, 2015 | Canon imagePROGRAF IPF710 Printer
I HAVE SHARP COMPANY 21 INCHES CRT MY FRIEND TV SET PROBLEM IS SET DEAD IN POWER SUPPLAY TRANSISTER 1886 REPLACED AFTER POWER SUPPLAY IS OK FBT ARCKING THEN IMMEDIATLY SET SWITCH OFF SET IN CIRCUIT R6
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 21, 2014 | Sharp Televison & Video
03130031 2618
This error comes up when there is an issue with the power supply unit. For additional information, you may also refer to the down loadable link and go to page 264: http://bit.ly/14m9F6U
Hope this helps.
Nov 06, 2013 | Canon imagePROGRAF iPF8000 Printer
Tv is working but if I switch it off after that is not going on again, need few hours to go on again
Are you getting sound and picture, when it is on? Have you checked for any loose contacts in power outlet, RC jack, cable, socket etc? These minor things, if over looked, can cause such problems. If these are already checked by you, you need to look for any bulgy capacitors in the other boards, especially the display board (provided sound is ok).
Aug 24, 2012 | LG 42LC2D 42 in. LCD HDTV
Error 03130031-2618 restart does nothing
printhead error. Sometimes not an easy fix to troubleshoot. Might need a new head, new relay pcb or main controller. If the head does not fix then plan on spending more money. upwards of $1000 usd
Jun 19, 2012 | Canon imagePROGRAF iPF6300 Large Format...
Canon ipf750 error 03130031-2618
Hardware error. 03130031-2618
Turn off printer, wait, then turn on again.
03130031-2618 VH voltage error
Check the power supply unit.
Mar 01, 2012 | Canon imagePROGRAF Office Equipment &...
Sony KD-28DL11U switched off by itself (went for red light). when I try to switch it on again the control light is green but there is no picture nor sound. any idea what could have failed?
pls. cheks your tv main supplay pin is proper canacted.
IF ok .
then problum is inside of the tv set.
check EHT out put voltage pin Diode /ragistance/ capeceter is filed.
any out put voltage from EHT is Droping. then TV is swithed off by itself
Oct 19, 2009 | Sony Televison & Video
Popping sound on my toshiba 32" flat screen
pls. cheked
1. suond ic input supplay voltage (ic B+ voltage regestance 1 ohm.
and capacetar 2200um/35v replace)
Oct 04, 2009 | Zenith R57W46 57" Rear Projection...
Presario 2100US not powering up
remove power supplay
remove battery
press and hold power button for 1 min
release button
plug the power supplay
turn on laptop without battery
Feb 21, 2008 | Compaq Presario 2100U Notebook
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
