Question about Monster Cable MPA 5150 SS Amplifier
My monster 5150ss is not under warranty. where can I get amp module part number 3010-3003-5000. I can replace myself however since Monster no longer produces amps this part is hard to find and any authorized dealer has stated that they will no longer sell parts unless they install.
  • gibbsteam Oct 01, 2011
    me too...Monster sucks
    2 grand for a amp and they stop making parts.....we need to buy a used one for parts or sell it for parts
2 Suggested Answers
fixyathing
  • 341 Answers
SOURCE: Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Posted on Sep 25, 2008
Im missing the screws on the arch bit of the studio headfones by dr dre ... wer can i get them damn screws... and cn i put the screws on myself???
phone moser support OR email them thell most probs send a brand new one
OR if yu bouht from a autorised seller then take it to them they should replace it
Jan 24, 2011 | Monster Cable Products Monster Beats By Dr...
Monster MPA 5150SS
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Monster Amplifier MPA 3250
Hi rrogers1958
Not to discount what your tech has already said, there are a few things that can cause hum. Just want to get info direct from you regarding this problem. Then, I can attempt to point you in the right direction if you can provide me with answers of a few questions
  1. is the hum still there when you disconnect the inputs
  2. does the hum increase in vol when you turn up the preamp
  3. does the amp run hotter than normal
  4. is the problem on both channels
  5. did any event or contributing factor induce the hum or did it just start out of the blue
  6. do you have any warranty on the amp
If you could answer these questions for me, then I will convey what I think to you. Cheers
regards
robotek
Jul 16, 2008 | Monster Cable MPA3250SS 3-Channel...
Monster mpa 5150 ss amp
As It was mentioned on the premium post, if after removing the fuse(s) from it, the amp powers up and stays ON; the failure is on the transistors or mosfets and they will need to be replace to get the amp working again on channel 4.
I would suggest to contact the manufacturers to get an authorized repair center to fix it under warranty if your amp is less then a year old.
Good Luck.
Jun 30, 2008 | Monster Cable MPA 5150 SS Amplifier
4th channel turns on and then it turns off; 5th channel does not turn on
Hi Alex323a
Nice amps. There is really only one check you can do without getting into the internals of the amp to help you resolve the issue. Disconnect the input and speakers from that channel,and see if it is able to turn on. If are up to it, checking over the poweramp board for that channel for dry or cracked solder joints, and in turn resoldering any you find may fix the problem. If not, the amp will have a problem on that channel and will need a tech to look at it. If it is under warranty still, Monster are pretty good for service I have heard, and they would be your first port of call. Other than that, Call you local HiFi specialist store and see if they can recommend a good audio tech in your area.
regards
robotek
Jun 28, 2008 | Monster Cable MPA 5150 SS Amplifier
Monster Cable MPA 5150 SS Amplifier Logo
81 people viewed this question
Top Monster Cable Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Monster Cable Audio Player and Recorder Expert? Answer questions, earn points and help others
