Question about Numark iDJ2 - DJ iPOD Mixer Docking Station
My idj2 freezes up and the display screen fades out. this usually happens when i use it within the first 5 minutes. It usually happens when i press any button. Do you know what the problem is?
2 Suggested Answers
SOURCE: My Numark iDJ2 won't update it's firmware!
I've tried it with a PC, I've tried it with a Mac, I've tried it with two different memory drives, and nothing will get it to update. Numark has a quality problem they need to address soon.
Posted on Sep 27, 2009
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
The crossfader won't gradually fade from deck to deck.
In the front of the IDJ2 system there should be a switch labeled "CF Slope." Switch it downward and you should be good.
Jun 02, 2010 | Numark iDJ2 - DJ iPOD Mixer Docking...
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Idj2 keyboard problems
I've had my iDJ2 for about a week and have been having the same problems occasionally, however I think I may have figured out a solution. It seems to me that if I activate the number lock key, it works fine and I never have any problems. I'm not sure why this would be, but it seems to do the trick. Just make sure to press the number lock key after you turn the unit on.
Jul 10, 2009 | Numark iDJ Mixing Console Docking Station,...
How to download firmware and librarian files to my idj2
The current firmware available is version v1.13 which is located at http://www.numark.com/idj2 . It also has Librarian v1.5 included with it.
Download the firmware to your PC and then unzip it to your desktop where you can retrieve it easily.
Transfer the firmware file to the handy little 128mb thumb drive that came with the idj2. (I moved all of the files from the thumb drive on to my PC so the firmware file was the only file on my thumb drive to avoid any computer related confusion)
Making sure your idj2 is powered "OFF" insert the thumb drive containing firmware v1.13 into one of the rear USB ports. Make sure this is the only thing plugged into the idj2 at this time(no keyboard, ect)
Turn on the idj2 on. You will see a message that says the machine is checking the firmware.(I don't have the system in front of me right now but that is roughly what it says) It will take a few minutes and the system will update to the new firmware.
Jun 06, 2009 | Numark iDJ2 Docking Station for Apple iPod...
My flatscreen dell monitor fades out to dark gray, sometimes pink
Its definetely the monitor thats having a problem. when it blacks out during th monitor self test. i suggest you can ask for a replacement monitor.
Mar 19, 2009 | Dell E193FP 19" LCD Monitor
Dell Dimension 4100 freezes for approx 1 minute
your ram is prolly going bad
try to download and run "memtest86"
Mar 07, 2009 | Dell Motherboard Dimension 4100 Intel 815...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Numark iDJ2 - DJ iPOD Mixer Docking Station  Logo
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
