Question about Garden
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach? Thanks
  • 731 Answers
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
Posted on May 19, 2011
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    One of the belts on our deck was destroyed to the point that it can't be identified. The mower is old enough that the model number isn't visible. Can anyone provide a part number? Also, one of the springs...
    What you ask is impossible. You need the model number ... you don't have it ... neither will anyone else.
    The best thing for you to do is take what you have to the auto parts store and see if they can match it at all.
    You should probably measure the distance around all the pulleys and tensioner to get some idea of the length. If the store will cooperate, you should get a couple belts to try and return the ones that are not corrrect.
    Jun 25, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    I changed the blade mandrel from my 42 inch cut craftman mower, I need to put it back together I need a directions on how to put the spring and pulley back on also I damaged the nut on the pulley, What...
    Ok Go to partdirect on the Sears website. Enter the 917. xxxxx number that will bring up the drawings and should show you were the spring goes. As for the lock nut its 9/16-18 .You should have gotten a new locknut with the new mandrel.
    GOOD LUCK
    MIKE
    Oct 22, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    13.5 hp Craftsman lawn mower 5-speed
    Here is a picture to help you place it on right. There are two deck designs pick yours.
    Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Craftsman 42 inch deck won't run
    Check proper belt routing. These models are a little tricky. Also check tensioner spring.
    May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
    I need belt diagram for 42 in deck
    You can go to the Sears website an download a free owners manual that shows what you need.
    Apr 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Replace key assembly
    any small engine repair shop should carry that switch - or sears . com - just put in your model number
    Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
    Garden Logo
    240 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
