Question about Zebra Symbol Technologies MC909X-G Series Barcode Scanner
Can not "Cold Boot" a 9090G
I need to cold boot a 9090G and none of the suggested methods has worked.
Anybody got any ideas ?
  • Anonymous Sep 09, 2008
    I hold the botton on and the trigger bur doesn't work "cold boot" of course i released the battery,
  • bubbahey May 11, 2010
    Pop the battery (not all the way, just pop it out).
    simultaneously press and release the trigger and the
    red Power button.
    Pop the battery back in until it clicks
    If it says "warm boot" you did it wrong, try again
    You should get to the calibration screen, then you know you've done a cold boot
    Of course you will need to reset date/time and check your wireless settings.
Take the battery out, press in the red power and the trigger at the same time for 5 seconds, let go and re-insert the battery :) Works like a charm.
Posted on Aug 22, 2008
While on... Press the red power button and hold it down for about 60 seconds....the screen will fade away and cold boot.
Posted on Dec 04, 2008
1,9, hold red power button. Hold all 3 at same time release.
Posted on Sep 22, 2008
It's pretty easy to write a program to do this....
the battery thing is pretty ugly.
Posted on Apr 17, 2009
MC9090 Stuck Warm Booting
Here you can find links to both clean boot files for the WM5.0 and WM6.1 OS for the MC9090. If you need the full WM5.0 OS you can download it here. For upgrades to WM6.1 from WM5.0 fill out this form and BCTP will help you out.
Aug 20, 2012 | Symbol Computers & Internet
My micromax x600 mobile asking input phone lock code
visit www.hard-reset.com or see the result.Hard reset
Cold boot method: Hold the "Power Button" of the Pocket PC with one
hand while holding the stylus tip to push in the "Reset Button" with the
other. Simultaneously release both the "Power Button" and "Reset Button".
Appropriate situation: If a previous reset has already been attempted and
the Pocket PC is still unable to maintain normal operations, has no
response, or if the screen is frozen.
Before executing the preceding "Cold boot method", please carefully
consider the following instructions and then decide on the cold boot
method.
1. After a cold boot is performed, if no buttons are pressed, when Pocket PC automatically completes the system startup process, the last display will be the Today screen. This is identical to the reset result.
2. If a previous reset has already been attempted but the Pocket PC is still unable to maintain normal operation, consider the following solution:
After cold boot, hold the End Button eten_glofiish_x600_hard_reset_soft_reset_5.jpg on the bottom right of Pocket
PC until the system inquiry screen is shown, and then release the End
Button. Next, please read thoroughly through the instructions on cold
booting before continuing carefully.
Erase all data and load default?
The default is "No." If Yes or No was not
selected, after a few seconds the system will
automatically execute the default No.
If you long press Left Soft-Key for a few
seconds to select "Yes," then the system will
erase all data and load default. After your
Pocket PC restarts, follow the instructions on
the screen to complete.
Caution!
1. After performing a cold boot, the system will retain Microsoft Windows
and pre-installed programs. If you answer "Yes" to the question displayed
after a cold boot, other items such as the user's input data, newly installed programs and user settings will be lost.
2. There are two ways to retain your data, loaded default and registry:
Perform a Reset.
Performing a Cold Boot, and answer "No" when the above question
displays.
Jun 27, 2012 | Eten E-Ten GloFiish X600
How to factory default Mc75 device
Resetting the MC75
There are two reset functions, warm boot and cold boot. A warm boot restarts the MC75 by closing all running
programs. A cold boot also restarts the MC75, and also resets the clock. Data saved in flash memory or a memory
card is not lost.
If the MC75 is not functioning properly, perform a warm boot first. If the MC75 still does not respond, perform a cold
boot.
Performing a Warm Boot
Hold down the Power button for approximately five seconds. As soon as the MC75 starts to boot release the
Power button.
To perform a cold boot simultaneously press the Power button and the 1 and 9 keys.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Motorola MC75
Could you tell me what has to be done when the only item appearing on the screen is MC70?
Resetting the EDA
There are two reset functions, warm boot and cold boot. A warm boot restarts the EDA by closing all running
programs. A cold boot also restarts the EDA, and also resets the clock. Data saved in flash memory or a memory card is not lost.
Perform a warm boot first. If the EDA still does not respond, perform a cold boot.
Performing a Warm Boot - Soft reset
Hold down the Power button for approximately five seconds. As soon as the EDA starts to boot release the Power button.
Performing a Cold Boot - Hard reset
Dec 03, 2010 | Zebra Symbol MC70 HandHeld Mobile Computer...
Motorola MC9090 G oes not cold boot.
I've found this method works best especially on Window Mobile versions, windows CE does not seem to have the problem.
  1. Have the battery inserted,
  2. Remove the battery so its at the first stage of removal,
  3. Hold down the On/Off button and trigger,
  4. Insert the battery, still with On/Off button and trigger held,
  5. As soon as the amber light flashes release the On/Off button and trigger.
  6. Unit will attempt to cold boot and then warm boot,
  7. If it works then it will boot through to the Windows Splash screen or desktop.
  8. If it fails and continuously warm boots, remove the battery fully as soon as it cycles a warm boot.
  9. The terminal will not switch off at this stage and will completely drain the backup battery and RAM, giving you a complete clean cold boot
  10. Leave the battery out fro 20 minutes.
  11. Power on and see how far you get.
If it still fails after this I would suggest a complete re-flash of the system. Please post a follow up question on how to do this.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL 01202 620955
http://www.biastechnology.com/
Jun 06, 2010 | Zebra Symbol Technologies MC909X-G Series...
I'vefound this method works best especially on Window Mobile versions, windows CEdoes not seem to have the problem.
If it stillfails after this I would suggest a complete re-flash of the system. Please posta follow up question on how to do this.
Hopethis helps.
Ifyou need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com orTEL 01202 620955
Jun 06, 2010 | Symbol Motorola MC909X-G Series Portable...
IT ALWAY FREEZES AFTER 20-40 MINUTES OF THE COLD BOOT (FIRST BOOT)
this might be some problem with your registry.. There are plenty of software can check this.. I suggest you try to look into below link to further understand the registry issue.
http://etech.maiila.com/?p=24
May 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Boot up problem continues
Looks like you will have to replace RAM modules.
May 15, 2008 | Toshiba Satellite A100-S2311TD Notebook
Diference between Cold boot and warm boot
A warm boot restarts the mobile computer by closing all running programs. All data that is not saved is lost.
A cold boot also restarts the mobile computer, but erases all stored records and entries from RAM. In addition it returns formats,
preferences, and other settings to the factory default settings.
Apr 07, 2008 | Symbol MC1000 Barcode Scanner
Problem with Symbol MC1000
you kept it in the freezer too long
Feb 28, 2008 | Symbol MC1000 Barcode Scanner
Zebra Symbol Technologies MC909X-G Series Barcode Scanner Logo
2,776 people viewed this question
Top Zebra Computers & Internet Experts
Mike
Gareth Cockram
Gareth Cockram
Are you a Zebra Computer and Internet Expert? Answer questions, earn points and help others
