Question about Toshiba 32A33 32" TV
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume but as soon as you let go of the volume + button. The volume climbs back to O (no sound). Every once in while it will repair itself and life is good, well it's now back to it's old tricks. I have tried unpluging tv, putting new batteries in remote control, don't know what else to try. HELP I think it messes with the on/off switch as well because in this mode I have trouble turning off the tv
  • 56 Answers
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
Posted on May 19, 2011
Volume tv goes down its own
Depending on your TV, here are the generic steps Toshiba has outlined to reset your TV:
1. Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
2. Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
3. Highlight the SYSTEM STATUS menu at the top.
4. Highlight SYSTEM INFORMATION below and press ENTER.
5. At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
6. Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
Apr 09, 2014 | Toshiba Televison & Video
Toshiba (model 19av500U) volume goes up and down automatically
It may be the remote itself and not the tv, have you tried purchasing an inexpensive universal remote?
Sep 27, 2012 | Toshiba 19AV500U 19-Inch 720p LCD HDTV...
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Toshiba VC-L2B Remote Control Sound volume bar is moving up and down, but there is no sound out of speaker.
Check to make sure the wiring between the sound bar and your audio source is hooked up correctly. Check the source to see if it has it's own volume control. Many TVs require external speakers to be enabled in the "audio" section of your TV's "Settings" menu.
May 04, 2011 | Toshiba VC-L2B Remote Control
I just bought a Coby home theater system 5.1 surround sound dvd/cd/ player model#765. I've got it all hooked up but I have one problem, when I want to listen to my tv stations through the home theater...
Hi - Your Home Theater System and your TV should have separate volume controls. You should be able to control each individually. Start by checking the volume level on your TV with your HTS shut-off. Turn the volume on your TV all the way down to 0.
Next, turn your HTS on and check the volume level there. Is it still loud? If so, try turning the volume down on your HTS. That should do the trick. If its not loud then you know you can control the volume on either the HTS or the TV. If this answer does not help, then please write us back with a little more detail. Thanks.
Feb 28, 2011 | Audio Players & Recorders
Have an Hitachi 60sx12b. the sound meter bar stays on. can manually adjust the sound up but will go back down to 0. tv remote or sat. remote doesn't work at all. Please help
It sounds either volume down button is bad that turns volume down on its own or system control chip got defective and decreasing volume level.
Press volume down button on tv front and check is it working properly.
Let me know to find out further info to solve the issue.
Thanks.
Jun 05, 2010 | Hitachi Televison & Video
Aiwa TV MODEL No. TV-A149 AGING
I have Aiwa TV MODEL No. TV-A149
The problem that I am suddenly facing is that I can't change channels or volume or use any other function. I can't even turn it off with remote control.
Its stuck randomly on a particular channel that I was watching at that point of time.
Along with that channel it now shows a message in flashing red color that reads :-
AGING
6EDEH
Now when I press ''Display'' button on remote control volume goes off and this code is shown :-
S123 K234 Y
100 000 0
The numbers in the second line can be navigated by ''CH+'' button and changed between 0 and 1 by ''Vol+'' button.
I really don't know anything about this. So, please help me out of this problem.
Sep 14, 2009 | Aiwa TV-S2011 20"
I was watching tv when suddenly the volume control indicator bar showed up and started going up and then down and the remote will not operate the tv. the set it self will allow me to change channels and...
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Skyassoc
Jun 26, 2009 | Toshiba 36A43 36" TV
Telivision volume
sounds like a sticking tact switch. an engieer would isolate the sub-panel that contains the volume and the manual programme up/down switches and then operate the TV using the remote control and see if this eliminates the problem
Oct 19, 2008 | Toshiba 32AF42 32" TV
Toshiba (Model : 36A43) - volume goes down automatically
I am having same problem on 32 inch same problem. After playing with board with no results,I tried front buttons and found that if I held the power button in ever so slighItly as not to turn it off, it fixed problem which is the micro on/off switch, I removed the switch and used the remote and everything is back to normal, I am about to insall a used micro switch after I finish typing this but I am sure this will clear up volume problen and menu going crazy problem if not I will just leave micro switch out and use the remote, and I will get back to this board only if that micro switch still causes the problem, so if I don't post in next hour the problem is fixed and I'm more than glad to help.
Jun 18, 2008 | Toshiba 32AF43 32" TV
Toshiba 32A33 32" TV Logo
345 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
