Question about Avanti WC330DZB Wine Cooler
Needing instruction manual to set refrigerator Moved it 2 weeks ago and have had problems setting termperature
Hotpoint model HM3151. Freezer is iced up!
Sounds like cold control thermostat or control Board is bad. Which ever one your model has v
Sep 05, 2017 | Refrigerators
Have had this refrig. for several years and have had no problems until our 2 year old grandaughter played at the temperature controls about a week ago...The freezer has been set at -2 and the regrigerator...
Hi there
Samsung's child lock is easy to alter
Press the vacation and fridge temp buttons simultaneously and hold for 4 seconds, this will release the child lock, to reinstate the lock just repeat this. 4 seconds is quite a long time.
Hope this helps
Gordon
Apr 20, 2011 | Samsung RB215LASH
I have a ge profile fridge model # PDS22SHRBRSS needing help
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Feb 04, 2010 | GE Profile Stainless Bottom-Freezer...
Moved frig then plugged in and ran for several days then quit, then two days later started again and then a week later quit again? Frig is a ten year old side by side Kenmore about 21 sq feet, ice maker...
If you didn't give it enough time for the oil to settle back in the compressor that could be the problem. I would try leaving it off for a day to see if it will settle down and run better.
Sep 30, 2009 | Refrigerators
Ice maker not making ice
Try changing the filter; our refrigerator did the same thing.
Jul 17, 2009 | Frigidaire FRS6R5EMB Side by Side...
Freezer and Fridge temperature not very cold
I can find only one good reason why your refrigerator may not be cooling. There is a control board inside the fresh food compartment and no signs of a defrost timer. If there is someone that go through some test to eliminate other possible problems would be good. If the refrigerator is still running, unplug and open the freezer compartment. Remove the back panel so we can have a look at the evaporator coils. Clean or are they frozen with a large piece of ice? Let me know, Thanks Sea Breeze
Mar 23, 2009 | Maytag ZigZagW / B Side by Side...
Sub-Zero 561
You are number 3 in the series this AM-
As you probably know, the recommended temperature range is between 35-45 F so if you control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be a problem with your brand; I'd check to see if there is a recall or factory 'fix' for this. They may have gotten a batch of defective sensors or controllers.
Aug 01, 2008 | Sub-Zero 650 / O Bottom Freezer...
Avanti WC330DZB Wine Cooler Logo
62 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
