I have a hp color laserjet cm1312nfi every time i try to print or copy i get pink horazontal lines up both sides of the document. I have tried repeatedly cleaning and calibrating from the set up menu.
jackboy
  • 2985 Answers
SOURCE: Everything printing in PINK
Assuming you have successfully eliminated cartridge/print head problems, the only other thing to try is to delete the printer software and reinstall [Start/Printers and faxes -right click on the printer icon click delete- install new printer -Have the software disk and handy or select from list- select maker, select model,] I suspect the problem is still print head/cartridge however
Posted on May 11, 2007
  • 390 Answers
SOURCE: HP Color Laser Jet 3550 Smearing Colors
Do you use original genuine cartridges or refilled ones. It sounds like you have had a leak and need to completely clean out your printer heads, rollers and perhaps do a deep claean as well. You can buy faulty cartridges and toners that have one leak, then the ink continually leaves traces as it prints. When you say callibrated, do you mean you ran print tests and setting tests. Running a print test can often help to diagnose ink issues an d narrow the results down a bit. After a thorough clean, you could try uninstalling and reinstalling unit.
Posted on Aug 12, 2007
  • 26 Answers
SOURCE: HP Color Laserjet 3500 Problem
Occasionaly these printers fall out of specs so that is why HP made it possible for the user to calibrate the printer:
Calibrating the printer
Calibration is a printer function that optimizes print quality. If you experience any print quality
problems, calibrate the printer:
1 Press MENU to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE.
3 Press to select CONFIGURE DEVICE.
4 Press to highlight PRINT QUALITY.
5 Press to select PRINT QUALITY.
6 Press to highlight CALIBRATE NOW.
7 Press to select CALIBRATE NOW.
If that doesn't help and want to adjust the colors themsevles,this is how you do it:
To adjust color density
Press to enter the MENUS.
2 Press to highlight CONFIGURE DEVICE MENU.
3 Press to select CONFIGURE DEVICE MENU.
6 Press or to highlight ADJUST COLOR.
7 Press or to highlight the desired color.
8 Press or to highlight the correct density setting.
9 Press to select the density setting.
10 Press to set the density for the next color.
11 After setting the density for each color, press MENU.
Hope this helps
Posted on Mar 27, 2008
hemantraj
  • 638 Answers
SOURCE: My HP Laser Jet (color) 1600 is printing color on pages with no color!!
the wastage part of ur pink toner is full a is dropping the powder on paper.get it cleaned to continue good printing.wish u success
Posted on Jun 04, 2008
  • 95 Answers
SOURCE: RICOH CL7200 MAGENTA AND CYAN LINES ON COPIES
It sounds like the transfer belt needs to be replaced. They get scratched up and milky looking and the sensors can't see the color reg marks good enough. It could be other things also but the transfer is a good place to start.
Posted on Apr 23, 2009
Testimonial: "thanks fo your help ALBERT"
WIl not print correctly
If it is faded, it could be the transfer roller. I've had great success with simply periodically cleaning it, then getting a good printout. See my solution for this already posted: Check out this solution to the HP Color LaserJet CM1312nfi Laser Color...
Otherwise, the other issue I had late last year was that it needed a new intermediate transfer belt (part #RM1-4436-000CN). You can find a good deal on one, and the instructions for replacement are on page 156 in the service manual: http://www.feedroller.com/Store/Service%20Manual/HP-CLJ-CM1312-MFP-Manual.pdf
It's not the hardest replacement ever, but needs 2-3 hours depending on skill, and a little patience.
Mar 28, 2014 | HP Color LaserJet CM1312nfi Laser Color...
My HP CM1312nfi is printing a line on the left side of any documents that I copy? Any suggestions as to how I can stop this please?
This is usually caused by ink or correction fluid on the scanner glass. Here is a link to an article about where to look and clean to clear the lines on copied and scanner pages.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
I hope this helps, If so please rate my solution.
BuddyMc
Feb 10, 2012 | HP Office Equipment & Supplies
We have four computers, 3 Macs and a PC networked via an Apple Time Machine to a Hewlett-Packard HP Color LaserJet CM1312nfi MFP. All of the Macs display "Looking for Hewlett-Packard HP Color...
You should update your printers firmware and reload both Mac and windows drivers for the same printer. I look at this as more of a driver problem. Firmware and drivers can be located here. If problem persists, try to approach this instance by using the elimination method. remove pc from network, test with only macs connected. then remove macs and test with only PC connected. then finnaly, install this printer directly to pc and test the performance and then directly on one of the macs and test.
Regards
Nov 23, 2010 | HP Office Equipment & Supplies
HP Color LaserJet CM1312nfi MFP printer leaves a 2 inch area unprinted using any programs. So basically it doesnt print the entire page.
turn on/off, unplug, plug in2_bing.gif, should reset configs.
take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are preventing printing
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
lastly, go to web site of printer model and check site for trouble shooting if this does not work above. HP has an awesome website for this type os trouble shooting
hope this helps and good luck
Apr 29, 2010 | HP Color LaserJet 2600n Printer
Replacing Cartridges on the HP Color Laserjet CM1312nfi
Yes, you will replace the whole cartridge. Open the front door and pull out the cartridge drawer. Grab the handle for the magenta and pull it straight up. There should be directions in the box.
Jan 20, 2009 | HP (Q6473A) Print Cartridge for Color...
Pink lines and background on all prints
I have seen this recently on an HP 4250 and the red toner cartridge was at fault. Can you replace it and try to print again?
Jan 14, 2009 | HP LaserJet 4650 Color Printer
Jun 04, 2008 | HP LaserJet 1600 Printer
k24674
jasbo
jasbo
