Question about Briggs & Stratton Garden
I changed the air filter, pre-filter, fuel filter, and installed a new fuel line on my 6.0 HP B&S, self-propelled walk behind. Now after running the mower it leaks gas out of the carb into the air filter housing. It looks to be coming right out of the carb. Any ideas why this is happening? The leak is not coming from the new fuel line. Thanks for the help. Jim L
  • 843 Answers
Sounds like the float valve is sticking open. You will have to drain the gas (or at least turn off the valve where the gas leaves the tank if so equipped.) Then remove the bowl to clean the float valve. (There is usually a nut in middle of the bowl.) The bowl looks like a bowl, and is about 2 inches in diameter. When you remove it you will see the float, which probably looks like a little brass donut. If you remove the hinge pin that allows the float to move up and down (it only moves about 1/2 inch) you will then allow the valve pin to fall out. The valve pin is about 3/4 inches long and maybe 3/16 diameter. (I am not measuring these things, just giving approximate dimensions so you will recognize them when you see them.) Good luck, Al K
Posted on May 19, 2011
How do I change the fuel filter on my 3020 John Deere diesel tractor
Leaving the fuel valve on the tank in the on position will allow fuel to run through the line & keep the air purged during removal. On the other side between the pump & the filter, having the new filter topped off & speedily installed will lessen the chance of air entering the line. Once the filter is installed, open the bleed screw at the top of the filter. Just my redneck way.
Oct 05, 2014 | John Deere Ar50041 Diesel Fuel Filter 3020...
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
I have a self-propelled walk behind number and the wheels quit spinning and the mower becomes very difficult to push. I am so frustrated. The mower has only been used five or six times and is brand new,...
I would probably take it back to where I bought it to begin with. But, I have an old Huskavara mower self propelled, at times if I set it on top of two 4 x 6 blocks (6 inches up) I have to take off the wheels and clean up the axles using thinner, degreaser, or gas, anything to break down oil or dirt. Then I oil the surfaces and reassemble, and the wheels work for a while.
Jul 04, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
How do I clean the fuel line to my MTD self propelled high wheel 5.5 HP tradesman Yardmachine? What should the spark plug gap be? how do i clean the air filter?
the fuel line if it is dirty you should just replace it you can get it at homedepot or ace hardware . your spark plugg gap should be the thickness of a match book . and the air filter should be replaced every year if you use it in a dusty environment maby every couple of months .
Jun 11, 2011 | Mtd 22" White Outdoor Self Propelled High...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Troy-bilt self-propelled w/briggs and stratton 6.75hp after starting runs for 3 or 4 mins. dies out and in 3 mins later will start and do the same thing any suggestions?....thanka abb
Hello. Your carburator is partially clogged up. That said, if you havn't installed a new fuel filter and new air filter this year do so. Also put in a new plug if u havn't lately. Finally get a bottle of a fuel additive called seafoam and pour it into the fuel following the directions on the bottle. J.
Aug 16, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Fuel feed
carby service 1 of the brass pipes or jets are blocked ,your looking for a minute pin hole so good luck usually a jet has 4 holes look for one near the thead
May 22, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
The mower starts, buts runs sluggishly, and dies
Most common is a dirty air filter, followed by a plugged vent hole in the filler cap on the gas tank. Next would be fuel issues either in the supply line or in the carburetor.
Hope this helps, --W/D--
Jul 19, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Runs for awhile then will quit
Have the fuel lines or engine shielding been modified at all? Has the fuel filter been changed?
If all of that is OK, remove the fuel line from the tank at the fuel pump, remove the fuel fill cap, gently blow air back through the fuel line so you can here bubbles in the tank. The "tank pre-filter" could be plugged.
Let me know.
Regards,
May 14, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Garden Logo
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
