Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Inside of icemaker freezing up where ice drops threw door have cleaned it out a few times but it starts freezing again soon.
I am convinced there is supposed to be a seal of some type on the little plastic doot that closes up over teh openindg. MY ice maker has never worked right, it freezes up, the dispenser doesn't work and it leaks.
I'm on a mission to figure this out today.
Posted on May 22, 2011
My undercounder KUIS18NNJB5 icemaker freezes successfully but the ice does not exit the freeze plate completely during the harvest cycle. When the next ice cycle starts, the ice refreezes to the plat
In the manual the fix is to clean the ice maker with cleaner. Your ice slab is not releasing during harvest. The plate (evaporator) has minerals on it and needs to be cleaned to remove the build up. On the door of the unit has cleaning instruction, do not short cut the cleaning process, this does take about an hour and follow the instruction to the letter.
This is not a major issue, just cleaning is needed.
Dec 07, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
I have a GE Adora side-by-side refrigerator Model # DSD26DHWA-BG. About 1 year ago the ice maker stopped producing ice. The mold that forms the ice cubes is filling up with water but never pushes out...
Hello, there are three screws that hold the icemaker in place if you remove these three screws and unplug the icemaker and remove it from the unit. After you take the icemaker out take the entire unit with the cover on it and run it under hot hot water this is actually quiet common for an icemaker to freeze up well actually its the parts on the inside of the icemaker that are freezeing up. After you defrost the icemaker as I term it then you would dry the icemaker and reinstall it. when the icemaker reaches 32 degrees the icemaker will call for water once again from the water valve if at this time after the ice forms the unit still doesnt drop the icecubes then you would have no other alternative then to buy another icemaker they usually sell for around 50-90 dollars american. The icemaker is not worth replacing parts on due to if you were to replace parts on the icemaker you would end up spending about 4 times as much as the entire icemaker costs. If you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again Rick
Jun 04, 2011 | GE Refrigerators
Icemaker makes Ice But doesn't dispense it.
Had same problem. Looked everywhere and found no solution i'm a not a repairman...they probably do not want to post so they can make 150 for a repair visit. At least try this first it may save you $$. Remove ice bucket from freezer. Remove 2 screws @ auger...remove cover and auger ....remove spring and large hex shaped shaft. heat the large shaft end with a torch and put it back in hot side toward motor until the motor end is not frozen. No torch you can use hot water...but that may freeze again.
This was happing because my flap to the ice was not closing all the way .
Manual for parts can be found here it shows ice maker parts on page 7.
Good Luck Kono
Aug 21, 2009 | KitchenAid KSCS25FKSS Side by Side...
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice maker can't release ice into dispenser - stays frozen
the heater in the icemaker that lets the ice drop out is broken and you need to replace the icemaker itself,your local appliance part store should have it in shock for about $50,your model number is inside the frig. top left-mike
Apr 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My ice maker won't make ice.I have a Frigidaire FRS26H5ASB5. Can you tell me what I can do?
I had the same problem with my ice maker.
I took it apart and cleaned the three switches inside the icemaker
The switches are not a high enough amp rating so they burn the contacts. Keep in mine cleaning is temp fix.
I did mine about 4 months ago and still working.
I have new switches now that I will be installing as soon as it quits again. About $9.00 for new switches and about $130.00 for a new Icemaker!
I hope this helps.
Feb 23, 2009 | Frigidaire GLRS264ZA Side by Side...
HSS25IFMDWW- freezer frosting up but working
sounds like the defrost thermostat or you may have a crack in the water line causing the freezing.
Jun 10, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
93 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
