Question about Garden
I have a 14" husgvarna
  • 2,239 Answers
Depends on what model we are talking about,if the hand guard stays with the machine, then take the retaining screws out and remove it, you can now insert this into the cover and use it to load the brake, it will take a fair amount of force as it is compressing a fairly large spring.
Posted on May 19, 2011
How to put the chain back on a 16" Poulan electric chain saw
its probably like the gas model. so you remove the 2 nuts holding on the side cover of the blade side, remove the cover and the blade and chain. To fit back, slacken the adjuster screw a little bit, or if fitting a new chain then a fair amount, as you have to be careful that the pin on the adjuster fits into the proper hole on the saw bar, as you fit back on the bar, of which you have already cleaned out the grooves. supporting the bar in the slackest position, fit on the chain, making sure that the cutting edge at the bottom is coming towards the motor. Then slide the bar and chain away from the motor to take up the slack, then fit back the metal guide in the original position, fit cover with the adjuster pin in its hole on the bar, and replace the 2 nuts almost tight but slack enough to use the adjuster to set the chain to cutting position..slightly sagging on the sprocket nose type, or snug on the solid nose type..then tighten the cover 2 nuts firmly but not excessively as that will damage the machine..NB the bar & chain depends on the adjuster, not on the nuts tightness to maintain tension
Jul 14, 2014 | Poulan 14 in. 2.0 Peak Horsepower Electric...
How to remove top cover
Also, if it has a brake, make sure the brake is not pushed forward. This will cause it to lock on and not release the cover
May 15, 2014 | Husqvarna Chain Saw Chain 14"
Can't put the cover back on my model 240 28" chain saw. the band will no go over rhe brake
Sounds like the cover was taken off with the brake on. On some of the Huskies, the brake is engaged with a three-part metal piece that fits into a corresponding shaped part on the cover and is engaged with a firm click on or off. The piece looks a little like the old nuclear bomb shelter signs, like three pie wedges with the narrow parts meeting in the middle. Be careful not to strip the plastic part when trying to marry these two sections together or you will be buying a new cover. I lined up both parts, made sure it was in as far as possible, put a knee on it, and snapped the chain brake off. This opened the band, and it fit once again. Note: I did this correctly the second time it happened to me. The first time resulted in a brand new pretty cover for my used saw because I tried forcing it and stripped the plastic part it the metal piece fits into. Good luck.
Sep 04, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Aug 31, 2011 | Poulan 14" Chainsaw
How to change the Primer bulb on a 235E chain saw?
Start by removing the top cover, the primer is an assembly, with a bayonet fitting into the air filter back plate, depress the two legs on the back of the primer whilst pulling the primer out, it should come away far enough to remove the two pipes from the back of it, note the orientation of the pipes so as to fit them correctly on the new prime, if you cannot get your fingers in to depress the legs use a small screw driver to push in one of the legs, use another screw driver to insert between the back plate and the primer to gently lever it out. The part no. of a new primer is 545008030
Aug 28, 2011 | Husqvarna Chain Saw Chain 14"
Chain has come off how do i put it back on?
The chain drive links may well be damaged now, it may need a new chain, however,if it has a chainbrake make sure this is off by pulling the hand guard fully back to the top handle,wind the chain adjuster fully back, remove the the side cover nut and remove the side cover, push the guide bar fully back, loop the chain over the drive sprocket, and lay it into the guide bar rails ( the cutters on the top bar rail should face away from the saw ), refit the side cover, if the adjuster pawl is in the cover make sure it aligns with the hole in the guide bar, fit the bar nut finger tight, adjust the chain so as it fit snuggly all round the bar, with a gloved hand pull the chain around the bar to ensure it it is sitting in the sprocket and rails properly, re adjust the chain if it has come lose, now fully re tighten the bar nut. If you fit a new chain there will be an amount of initial stretch, so re tention after a few cuts.
Apr 21, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
My saw just stopped on my chain got stuck and came off as i was pulling it back out of the cut, well i thought it was just the chain came off and it would be a simply fix. but its still not working right?...
First, make sure the chain break is released. (top handle pulled all the way back)
Second, remove the chain cover. You will see a tab on the chain break (a band around the Centrifugal clutch) that fits into the handle/cover. Make sure that is in place and reassemble the unit.
Did this fix your problem?
Jan 06, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I replaced the chain on the poulan el 14 and when I would tighten the aft bolt this caused the chain to begin to stick when I would manually move the chain
Poulan "1420 Electric Saw Type 2" (may not be your saw)http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
Open the link; Click "View the illustrated parts list [GO]" link; open the "Illustrated Parts Lists" folder; Click "Chain Saw Assembly Type 2". Compare items 20 and 21 with your saw, the flared portion of 20 should be toward the clutch cover not the engine and on the clutch side of the bar. The only other thing that comes to mind is item 23 should fit into the hole on the bar (the bar should be tight against the oiler channel; engine side of the case.). HTH
Lou
If these are correct please add comments below and we will continue.
Dec 29, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
What type of oil do a Remington 14" 1.5 electric chain saw use
Use any commercial bar oil. It is available at most home centers and hardware stores. I use the Ace Hardware brand. Bar oil contains tackifiers to attempt to keep it on the bar and chain, the parts that need lubrication. HTH
Lou
Oct 10, 2009 | Remington 16" Electric Chain Saw
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
