Question about Evolis Office Equipment & Supplies
Evolis ID maker is not printing anymore. The yellow light was blinking for a while until it just quit. Some guy cleaned it a little, and it started to work, but the next day it wasn't.Please let me know if this problem can be fixed.Do you charge even if it cant be fixed?
  • 1,940 Answers
There are 5 lights on the right side of the Evolis ID Maker. The first is the Control button, second is the End of Ribbon light, third is the No Cards light, fourth is the Cleaning light, fifth is the Cover Open light.
If the fourth light was flashing, or on, this means It is imperative that the printer is cleaned.
If the fifth light was flashing, or on, this means The output hopper is midway between open and closed.
Follow the procedure below:
Repeatedly running the cleaning card through the printer cleans the feed rollers, the cleaning rollers and the print head.
  1. Remove the card feeder from the printer.
  2. Closing the lever, set the card thickness to the MAX position.
  3. Remove any cards found in the feeder.
  4. Insert the cleaning card into the feeder.
  5. Put the feeder back into the printer, then press on the upper section of the feeder until it clicks.
  6. Open the cover.
  7. Remove the ribbon.
  8. Close the cover and check it has clicked shut.
  9. Hold down the control button on the control panel for one second. Cleaning starts.
  10. The used cleaning card is ejected into the output hopper.
In addition to routine printer cleaning, we suggest that you clean the cleaning roller(s) using the special wipes available from Evolis.
The cleaning roller(s) remove(s) any dust or particles from the cards before printing.
  1. Open the cover and remove any ribbon.
  2. Remove the cleaning roller.
  3. Rub the wipe gently over the surface of the roller.
  4. When it has dried, replace the cleaning roller in the printer.
To maintain the original print quality and to absorb surplus ink on the print head, we recommend that you regularly clean the print head (whenever the ribbon is changed) using the cotton buds supplied by Evolis. You must also protect the print head and its components from any discharge of static electricity.
  1. Take an Evolis cotton bud and press the middle of the tube until the end of the cotton bud is impregnated with alcohol.
  2. Open the cover and find the print head.
  3. Gently rub the cotton bud from left to right along the print head for a few seconds.
  4. Close the cover.
If you are having difficulties in configuring and using your printer, read this manual carefully. If you do not manage to solve your problem, you can obtain further information and help from the Evolis partner network.
For any unresolved technical problem, contact an Evolis dealer. If you do not know any Evolis dealers, visit the www.evolis.com website and send us your question. Evolis will pass on the contact details of your nearest Evolis dealer. When calling an Evolis dealer, you do need to be close to your computer and ready to provide the following information:
  • Your printer model and serial number
  • The configuration and operating system that you are using
  • A description of the incident that has occurred
  • A description of the steps that you have taken to resolve the problem.
  • In addition, to enable you to find answers to your questions 24/7, the www.evolis.com website includes a number of aspects related to day-to-day use of your printer.
Here is your User's Guide:
http://downloads.evolis.com/userguide/Dualys3/Dualys3_userguide_KU14E_A0.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Posted on May 19, 2011
My Evolis Primacy Printer's power button keeps flashing. It is the LCD version and the panel only shows the name Evolis in a faded form. I have completed the cleaning and still the same. Thank you!
Hi Marilyn - when the power light is flashing, and no other lights are on, that usually indicates it is receiving data from your PC. Disconnect the power and data cords from the Primacy, then ensure you have ribbon & cards loaded, and that the card thickness gauge is set appropriately for the card thickness you use (usually 30 mil). Then plug in ONLY the power cord to see if the printer will start normally while disconnected to the PC.
If so, go to your PC and clear out the print queue (Control Panel=>Device and Printers=>right-click on the Primacy and select "See what's printing"=>delete all pending jobs). Once done, repeat on any other PC's that have access to the printer. Once all PCs have had their job queues cleared, reconnect the data cord and try again.
If this still fails, feel free to contact us for further troubleshooting - we're an authorized Evolis dealer and service center.
Safe-Card ID Services
Charlotte, NC USA
+1 888.485.4696
https://www.safecardid.com/
Mar 01, 2018 | Evolis Office Equipment & Supplies
Evolis Primacy printer the top light keeps flashing. If you take the cards out of the printer the light quits flashing
If you're referring to the light just below the power-button light, and it is flashing, that usually indicates the printer is unable to feed a card. But you later indicate that it did feed the card, as it was pulled through and ejected after restarting the printer. Some other things that can be occurring:
1. The Primacy has a low-card indicator/sensor where that light will flash if you have fewer than about 20-25 cards loaded. Fill the hopper and see if the behavior changes.
2. The card not printing/rejecting may be a symptom of your having the driver set for a different ribbon than you have loaded in the printer. Evolis puts the part-numbers on the side of their ribbon cartridges, so make sure you've selected the right one in the driver.
3. You may be out of ribbon. Each ribbon cartridge has a fixed number of prints that it will do. This is electronically controlled and limited through the use of an RFID tag embedded in the ribbon cartridge. For example, a R5F008AAA ribbon is limited to 300 prints. So, while there may be ribbon remaining on the spool, if the ribbon has done 300 prints, it won't allow you to print more and will also act as you describe.
4. There are a number of other potential causes and fixes beyond these most common ones - driver settings, firmware updates, calibration routines, etc. - should the above not resolve the issue.
And, if I can get on my soapbox for a moment, you really should establish a good working relationship with an Evolis authorized dealer (like us). These plastic card printers really exist in a technology niche and, as you are seeing, require some specialized knowledge and expertise. Most authorized dealers will provide at least a basic level of support and service via phone for free to their REGULAR CUSTOMERS. That means that if you buy your printer and supplies from them, they're happy to help you out when the need arises.
However, if you want to be a do-it-yourself guy, searching the web for the rock-bottom lowest price on your printer and supplies, well ... you get what you pay for.
Jul 24, 2017 | Evolis Office Equipment & Supplies
How do I clear a yellow light on my Scotsman ice maker?
Front panel has cleaning procedure if followed correctly it should of came off...if not quick way push clean let run 2 min sump full light has to be on push and hold clean button for 4secs blinking amber light should stop blinking let run for 2 mins.then push and hold until dash comes out unit shuts down and light is off... push green button continue to make ice
Dec 02, 2014 | Kitchen Appliances - Others
Evolis tears ribbon
You have to put darkness setting down on your driver.
2 chances: a) you have the headset with too much temperature due to darkness setting, or you are printing a particular color like metallic blue, gray or intense yellow that can make headset hotter.
b) When you say you have just a left side printed, i remembered customers that set the ribbon to 1/2 YMCKO, check it's not your case
Jan 21, 2013 | Evolis DUALYS 3 ID CARD PRINTER
Blinking Clean
with mine you hold down the auto button until the coffee maker turns on and it will enter the cleaning cycle the clean light will continue to blink until the cleaning cycle is complete it could take awhile and at some points it may seem like it stopped brewing it will start again dont turn it off until it is completly done. hope this helps
May 20, 2010 | Black & Decker 12-Cup Programmable...
Yellow ink blinking
Please clean the printhead using the software installed in your PC . Try printing now.
Apr 30, 2010 | Epson Stylus Photo R2400 InkJet Printer
Evolis pebble 3 is printing very dark and then has large yellow and magenta spots
Check for luminosity and contrat settings in properties/graphic/more options
If you have replaced print head enter its serial number properly.
Apr 27, 2010 | Evolis Pebble 3 ID Card Printer Package...
Evolis Pebble 3 printer: the varnish is being put on as black
Check if ribbon type is proper.
Do self adjustment at once.
Clean optical sensors emitting blue light just below you install ribbon in printer
Jun 28, 2009 | Evolis Pebble 3 ID Card Printer Package...
Evolis pebble 3 displays mechanical problem error?
Clean all rollers
Check if print head is mounted properly
May 27, 2009 | Evolis Pebble 3 ID Card Printer Package...
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
536 people viewed this question
Top Evolis Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Evolis Office Equipment and Supply Expert? Answer questions, earn points and help others
