Pci simple communication controller
Hye There,
I wnted to make a normal clean up for my computer, i took it to th shop, instead they have format the whole computer by mistake! Now when i did install the window and every thing is working except somthing called PCI SIMPLE COMMUNICATION CONTROLLER, becuase of this i cant hear any ting.
what shall i do ?
Please use my email (cyberthug61@hotmail.com)
  • 477 Answers
Hello
mistake how can they format a computer and call it mistake?hm
anyway
it seems like they havent installed the modem drivers. do you have a modem in your computer?
what is your model of your computer?
if you go controllpanel>system>hardware tab->device manager. do you see several questions/exclamation marks or is it just one?
if you want to solve this quickly contact me true live support.
Posted on Aug 14, 2008
After installing clean version of windows 7 ultimate 32 bit from windows 7 proffesional 64 bit my pc when ever i need to restared it dosen't I have to manual turned off and on
pci controller drivers are specific to manufacturers, you need to contact the hardware manufacturer to install new drivers for 32 bit working.
Jun 18, 2014 | HP Computers & Internet
PCI Simple Communication Controller is a 56k PCI Modem, to know which exactly you have, use Unknown Device Identifier ( Download Here for free ), that will tell your the Model and Manufacturer, then Google for the drivers.
Sep 27, 2013 | Western Digital Computers & Internet
In device manager there is yellow sign on PCI simple communications controller. How to update. I coonect headphone but still speakers of laptop giving sound
Hi!
When you see PCI Simpple communications controller, it normally points to the built in dial up modem on a laptop.. You can download the modem driver from toshiba suuport site..
Hope it helps.! :D
Sep 11, 2010 | Toshiba Computers & Internet
I recently formatted a second harddrive on my dimension L933r to download windows 7 all works fine but i can not change screen resolution and now i can not find the drive for the pci simple communications...
Hello.
Not certain if you still need this, but ...
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware
Hope this helps.
Nov 17, 2009 | E-Machines eMachines W2686 PC Desktop
Asus EN7200GS
PCI simple Communication controller refers to a modem which is installed in your computer but with no driver installed.
Here is the web address for your graphics card:
http://support.asus.com/download/download.aspx?SLanguage=en-us
Regards,
Graemevm
Apr 20, 2009 | ASUS EN7200GS/HTD/256M-256MB PCI-E DDR...
Motherboard Simple PCI Communications Driver Code 28 for modem
Hello, Mike.
In case you still need this:
From there, you can search for a driver download for your hardware.
Hope this helps.
Mar 29, 2009 | Gigabyte GA-7VA Motherboard
Need a ethernet controller & pci simple communications controller
Try this link: http://partner.atheros.com/Drivers.aspx
You might be able to find something here.
Mar 14, 2009 | Biostar 945GC-M7 TE Motherboard - v6.0,...
PCI Simple Communications Controller
Hi, I have a solution. If you go in device manager, click on the pci simple communications controller, go in property and then go in details. You will see a code like per example PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in my case the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabase.com. Enter the two codes and you should get the name of your
hardware. From there you can search for a driver download for your hardware.
In my case the pci simple communications controller was a Microsoft UAA Bus HD audio. I also had another pci
device that didn't work properly, using the same method I found out that my pci device was an HSF PCI internal modem with code number CX11252-11. I had a hard time downloading one of the drivers, after 6 or 7 times the download started so be patient if you have the same hardware
NOTE: to access the device manager, go in control panel, then performance and maintenance, system, hardware and finally device manager.
Hopefully this helps you, good luck.
Dec 07, 2007 | Gigabyte GA-7VT600 1394 Motherboard
My system doesn't see 500GB HDD (SATA) (Seagate Barracuda)
Can you see this HD in:
Control Panel/System/Device Manager?
In Computer management?(Rt.Click My Computer/Manage/Disk management)? You can also format the disk here.
Oct 14, 2007 | Soltek SL-75FRN2-RL Motherboard
Computers & Internet Logo
82 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
