Question about RCA RT2280 System
I do not have the set up instructions for this system
  • 34 Answers
  • 110 Answers
Here's the link to your instructions:
http://support.radioshack.com/support_audio/doc66/66651.pdf
Posted on May 18, 2011
Model 1260 phohe,voicemail set up not on instructions
The Uniden 1260 isn't a voicemail system. To setup your voicemail system, please refer to the documentation for that system. If you're using the voicemail system provided by your telephone service provider, please contact them for instructions.
Jan 31, 2013 | Uniden Cordless Phone
Tip
Virtual memory Information.
Tutorial Objective
This tutorial talks about anything about the virtual memory and how much virtual memory you need for your system.
Tutorial Introduction & Background
Today application is getting bigger and bigger. Therefore, it requires a bigger system memory in order for the system to hold the application data, instruction, and thread and to load it. The system needs to copy the application data from the HDD into the system memory in order for it to process and execute the data. Once the memory gets filled up with data, the system will stop loading the program. In this case, users need to add more memory onto their system to support that intense application. However, adding more system memory costs the money and the normal user only needs to run the the intense application that requires the memory only for one or two days. Therefore, virtual memory is introduced to solve that type of problem.
Terminology & Explanation
There are two types of memory, which are as follows:
* System Memory is a memory that is used to store the application data and instruction in order for the system to process and execute that application data and instruction. When you install the memory sticks to increase the system RAM, you are adding more system memory. System Memory can be known as either the physical memory or the main memory.
* Virtual Memory is a memory that uses a portion of HDD space as the memory to store the application data and instruction that the system deemed it doesn't need to process for now. Virtual Memory can be known as the logical memory, and it controls by the Operating System, which is Microsoft Windows. Adding the Virtual Memory can be done in system configuration.
Tutorial Information & Facts or Implementation
Virtual Memory is a HDD space that uses some portion of it as the memory. It is used to store application data and instruction that is currently not needed to be process by the system.
During the program loading process, the system will copy the application data and its instruction from the HDD into the main memory (system memory). Therefore the system can use its resources such as CPU to process and execute it. Once the system memory gets filled up, the system will start moving some of the data and instruction that don't need to process anymore into the Virtual Memory until those data and instruction need to process again. So the system can call the next application data and instruction and copy it into the main memory in order for the system to process the rest and load the program. When the data and instruction that is in the Virtual Memory needs to process again, the system will first check the main memory for its space. If there is space, it will simply swap those into the main memory. If there are not any space left for the main memory, the system will first check the main memory and move any data and instructions that doesn't need to be process into the Virtual Memory. And then swap the data and instruction that need to be process by the system from the Virtual Memory into the main memory.
Having too low of Virtual Memory size or large Virtual Memory size (meaning the size that is above double of the system memory) is not a good idea. If you set the Virtual Memory too low, then the OS will keep issuing an error message that states either Not enough memory or Virtual too low. This is because some portion of the system memory are used to store the OS Kernel, and it requires to be remain in the main memory all the time. Therefore the system needs to have a space to store the not currently needed process data and instruction when the main memory get filled up. If you set the Virtual Memory size too large to support the intensive application, it is also not a good idea. Because it will create the performance lagging, and even it will take the HDD free space. The system needs to transfer the application data and instruction back and forth between the Virtual Memory and the System Memory. Therefore, that is not a good idea. The ideal size for the Virtual Memory is the default size of Virtual Memory, and it should not be exceed the value of the triple size of system memory.
To determine how much virtual memory you need, since the user's system contains the different amount of RAM, it is based on the system. By default, the OS will set the appropriate size for Virtual Memory. The default and appropriate size of Virtual Memory is:
CODE
* 1.5 =
For example, if your system contains 256 MB of RAM, you should set 384 MB for Virtual Memory.
CODE
256 MB of RAM (Main Memory) * 1.5 = 384 MB for Virtual Memory
If you would like to determine how much the Virtual Memory is for your system and/or would like to configure and add more virtual memory, follow the procedure that is shown below. The following procedure is based on windows XP Professional.
1-1) Go to right-click My Computer and choose Properties
1-2) In the System Properties dialog box, go to Advanced tab
1-3) Click Settings button that is from the Performance frame
1-4) Once the Performance Options shows up on the screen, go to Advanced tab
1-5) Under the Advanced tab, click the Change button from the Virtual Memory frame to access to the Virtual Memory setting
Then the Virtual Memory dialog box appears on the screen. In there, you are able to check how much the Virtual Memory you set. If you would like to modify the size of Virtual Memory, follow the procedure that is shown below.
2-1) In there, select the drive letter that is used to install the Operating System
2-2) Choose the option that says, "Custom Size:"
Once you choose that option, the setting for Initial Size and Maximum Size become available for you to set. Initial Size (MB) means the actual size of Virtual Memory, and Maximum Size (MB) means the maximum size of Virtual Memory that is allowed to use.
Let's say if your system contains 512 MB of RAM, then the ideal setting for the Virtual Memory is as follows:
CODE
Initial Size (MB): 768
Maximum Size (MB): 1500
Once you are happy with that Virtual Memory size, click the Set button from Paging file size for selected drive to apply the setting for the Virtual Memory size. Then click the OK button to apply the setting.
That's where you can manage and configure for the size of Virtual Memory.
Additional Information
* To maintain the good overall system performance, you should be using the default size of actual size for Virtual Memory and the triple the value of the size of the main memory for the maximum size of Virtual Memory. If you find that main memory plus virtual memory is not big enough to load the intensive application, then you will need to add more main memory onto your system.
Search Keyword
virtual memory
on Dec 02, 2009 | Computers & Internet
How to remove my power steering pump
hope this one help http://www.popularmechanics.com/cars/how-to/maintenance/3322636
This instructable is designed into four main parts. Here's the outline:
1) Gather the materials
-- Instructable step 1 - This includes tools, a new pump, fluids, etc.
2) Remove the leaking pump
-- Instructable step 2 - Drain the Power Steering system
-- Instructable step 3 - Remove accessories from Power Steering system
-- Instructable step 4 - Remove the pulley and bolts
-- Instructable step 5 - Remove power steering pump
3) Install the new pump
-- Instructable step 6 - Place the new power steering pump
-- Instructable step 7 - Press on the power steering pump pulley
-- Instructable step 8 - Align the pulley and attach the belts
-- Instructable step 9 - Flush and fill the power steering system
4) Cleanup
-- Instructable step 10 - Cleanup
You'll need some tools to complete this task. Before you start, gather the necessary equipment -- you will not be able to use the car once you start the replacement! It is always a good idea to have a friend on call, or a second car available.
Equipment list:
  • Power Steering pump (to replace defective pump)
  • Two (2) quarts power steering fluid or appropriate ATF (to flush and fill). More than 2 quarts if flushing the rack is desired.
  • Power Steering Pulley Puller set (to remove and attach the pulley). Some auto parts stores will loan the tool sets.
  • Socket set.
  • Open end wrench set (for use with puller set).
  • Leverage pipe or extension bar (in case the pulley is hardened on the spindle).
  • Drain pan (to drain & flush power steering system).
  • Wheel bearing grease for sliding pulley on the pump hub.
  • 2' wood 1x2 for assistance with aligning the pulleys. Any straight tool will work fine -- a level, metal rod, wood, whatever.
Jun 29, 2012 | 2002 Buick Regal
Getting and setting up voice mail
The VTech 6041 isn't an answering machine. If you subscribe to a voicemail system offered by your telephone company then the phone will let you access it. See the instructions on page 12 of the manual.
For instructions on setting up and accessing the voicemail system, you'll need to contact your telephone company.
Mar 29, 2012 | Vtech Cordless 6041 Phone
How to do a system restore on playstaion 3
Go to settings-->system settings-->Restore Ps3 system.
Delete all hard disk content and restore the system software to its default settings. Follow the on-screen instructions to perform this operation.
After the operation has been completed, the initial setup screen will be displayed. Follow the on-screen instructions to complete the operation.
Feb 19, 2011 | Video Game Consoles & Games
What is the difference between a software and a program? Describe.
A program is a set of instructions written in a programming language to perform a particular function. Many programs combine together to form software. While software refers to a collection of several programs and other procedures and documentation.
Software is also used to perform a task. The most common programming language used for making software is C and C++. Software is of two types that is system software which is the operating system and application software.
So a program is a set of instructions for performing a task whereas a software is made up of several computer programs.
Feb 06, 2011 | Computers & Internet
Problem with wireless settings on my computer - how do I reconfigure? Zonet ZSR1134WE Wireless Router
If you have the manual for the "Zonet ZSR1134WE Wireless Router " read the instructions device set up for the Operating system(OS) on your PC. Different OS setup require diferent sets of instructions/procedures.
Manual download @ http://www.zonetusa.com/file/product/d/ZSR1134WE_UM.pdf
Hope it helps.
Nov 12, 2010 | Computers & Internet
Sony home theater system ht-k25 instructions
http://www.manualsmania.com/model.php?model=59dab3492a57f91914626b922f6b9e3237bdd95
here's the online instructions, all the wires are colour coded so you can't go far wrong.
Apr 20, 2008 | Sony DAV-FC8 System
HOW DO I SET THE TIME I LOST THE INSTRUCTIONS!!!!!
Hello, here is the link: http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCNX3AV&LOC=3 Best regards, Arpi
Apr 22, 2007 | Sony MHC-NX3AV Shelf System
RCA RT2280 System Logo
207 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
