Question about Frigidaire 27" Built-In Single Electric Wall Oven - Stainless-Steel
I have a Frigidaire Galley wall oven model CFEB786JGB2. The display on the control panel is getting so faint it can barely be read. What do I do to correct the problem?
  • 87 Answers
SOURCE: Oven Problem
Check power going to the electronic module in back of the display. If power there you have a blown module. If no power check for a blown thermal fuze.
Posted on Jun 08, 2007
Amigaman
  • 248 Answers
SOURCE: Digital Display
This is a problem with this oven. If under 5 years old there is probably a part warranty on the display board. You need to replace the display board.
Posted on Nov 18, 2007
  • 3 Answers
SOURCE: frigidaire single wall oven
We had a similar problem. When the repair person arrived he turned of the electicity to the oven then turned it back on. The control panel is a computer and he rebooted it.
Posted on Jan 08, 2008
SOURCE: panel light is out
There is a capacitor on the clock board labelled C3. It will probably have brown burns on it or "syrup" leaking around the base. You can buy a box of 10 of these for 75 cents at Radio Shack (make sure you match the label on the old capacitor, I think it's 58mf and 35V but I could be wrong) and a pencil soldering iron for $10. It's held on with 2 little wires. Before taking it off note capacitor orientation (where the blue +++ stripe is), the replacement has to go on the same way. Common problem and easy fix.
Posted on Jun 21, 2008
SOURCE: DCS elect wall oven LCD display
Mine DCS WO-230 had the same problem.
Replacing the display unit solved the problem.
You need to call DCS or your local DCS distributor's parts dept and get a new display unit. It's fairly simple to install if you're mechanically inclined.
Posted on Jul 18, 2008
How to get a pf code off . Just installed new control panel and this code is all that shows up. Help it a frigidaire oven mod. Ples389ech
I appreciate your inquiry, J.J!
From what you have described your Frigidaire oven is displaying an error code of "PF" and you just installed the control panel. A "PF" error code stands for power failure. This could be a possible problem with your control panel and power source. You may need to perform a reset on your oven and you can do that by flipping the household circuit breaker off for at least ten minutes. If this does not help resolve your issue I would recommend having a professional technician out to perform a proper diagnosis and repair. I hope this information is helpful to you. -Matt
May 10, 2015 | Frigidaire Ovens
Lights showing oven temp are too dim to read -- difficult to set oven temp. model feb756cetf self cleaning wall oven
Good Morning Friend,
I understand the control panel is dim and hard to read, on your Frigidaire oven, model# FEB756CETF. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and set the clock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire Ovens
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
The LED display is barely visible. Both for Timer and Oven Temp.
Problem with Frigidaire CFEB27S2AB2 Electric Wall Oven.
My LED display on my clock has the 3rd number not showing up all the
light. Sample 10:30 the 3 on the top is not light. What is the problem
Jan 07, 2011 | Frigidaire FEB27S5A Electric Single Oven
Frigidaire gas wall oven
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire wall oven FSC88W-5 The door is open
i have a feb386wech frigidaire wall oven that the left door latch came out and will not latch an stay in place
Aug 11, 2009 | Frigidaire Ovens
F3 message displayed
HI, you oven temp sensor if malfunctioning. the circuit is open. its basically dead. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 22, 2009 | Frigidaire 24" Built-in Single Electric...
Clock fades
Sorry the only way to repair is to replace the control board
Mar 28, 2009 | Frigidaire 27" Built-In Single Electric...
Error F3 on display ovens beeps
the temperature probr is located inside your oven in one of the upper corners. it should be a round stick looking piece. some are removed from the front others are removed from the back.
Nov 26, 2008 | Frigidaire 24" Built-in Single Electric...
Frigidaire 27" Built-In Single Electric Wall Oven - Stainless-Steel Logo
188 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
