Question about Maytag MDG2706A Gas Dryer
Maytag Gas Dryer SDG515DAWW trips breaker after replace idler pulley wheel.
SOURCE: Kenmore series 70 electric dryer idler pulley
I figured this one out...there are two pairs slots...the tab of the idler pulley goes in the right slot near the motor and the idler pulley goes off to the left.
Posted on Jun 12, 2008
rickzilla
  • 706 Answers
SOURCE: how to install the belt on a Maytag Dryer modek MDE9420AYW
This should give you a few ideas on how it works.. Hope this helps...
Posted on Sep 13, 2008
  • 3 Answers
SOURCE: How to route belt around pulley and idler
repairclinic.com
Posted on Jan 28, 2009
thedayos
  • 57 Answers
SOURCE: My new maytag centennial electric keeps tripping
Hi Matt
I'm not sure that swapping out the breakers to higher rated ones will give you a solution so I'll throw in 2 cents to see if my advice holds true. Let's start by asking this. Is the appliance "rated" at 220 volts at 30 amps per leg. I assume this from your post as to what it has been rated. Next - How long is the "run" of wire from the junction box to the outlet where the appliance plugs in? This usually does not matter in most households but if the run is of significant length it may need a larger gage wire to support the current draw of the appliance. Lastly, and perhaps most importantly, are the lugs and wire connectors tight at the outlet, the plug, and the breaker box. A loose connection will ramp up the current fast. This is assuming the first two items were met. Tell me if any of this helps and we'll work it out from there.
Thanks.
Len
Posted on Feb 28, 2009
SOURCE: Maytag Gas Dryer SDG515DAWW - heating stopped
thermocouple
Posted on Mar 22, 2010
I need to know where the idler pulleys go on the motor
Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part ...
? 13:58
www.youtube.com/watch?v=WX0KjiQJWpY
Apr 7, 2011 - Uploaded by PartSelect Dryer Repair- Replacing Idler Pulley Wheel (Whirlpool Part# 6-3700340) ... Kenmore, KitchenAid, Roper, Maytag, Crosley, Jenn-Air, Hardwick, ...
Sep 15, 2015 | Dryers
Replace belt
  • Disconnect the power source from the dryer. You can unplug from the wall outlet, remove the fuse from the fuse box or flip the breaker in the panel box.
  • 2
    Pull off the front panel of the dryer. Remove the screw in each corner at the bottom of the dryer's front panel. Lift up the front panel until the two clips at the top disengage. Remove the two screws that are found beneath it at the corners to remove the cabinet top.
  • 3
    Remove the belt by releasing the tension applied by the movable idler pulley wheel. The belt loops over the drum, under the idler pulley wheel and then around the motor's drive pulley.
  • 4
    Discard the used belt. It is fine to just throw it in the trash.
  • 5
    Install the new belt by pushing in on the idler pulley arm. Make sure the new belt is placed flat along the exterior of the drum.
  • 6
    Replace the screws back into the dryer's front panel. Screw them in tightly so that the panel will not fall off or jiggle loose.
  • 7
    Reconnect the power source back to your dryer. Either plug it back in or flip the switch in the breaker box.
Jan 11, 2012 | Amana DLE330RAW Electric Dryer
Maytag MDE5500AYW 220V Electric Dryer. Makes a
Your dryers uses rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley your dryer has a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Rear drum bearing. There are videos of the testing and replacing of these parts at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting and replacement of these parts Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. This brings us to the last problem could be the blower wheel, which is usually plastic, may wear out over time.To check this grab the wheel and see if theres any play . But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you need to replace it. If you need diagrams or illustrations of your specific model you can also enter your model # there.
Mar 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
A constant clicking noise near the motor of my maytag dryer. seems something is slipping as occasionally the drum and belt slow down
It sounds as if the idler bearing has started to fail see this picture http://sites.google.com/site/sublimeappliancerepair/_/rsrc/1246721031553/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/ge-dryer-repair/maytag-norge-amana-crosley-basic-repair-info/Norge%20dryer%20with%20drum%20removed.jpg
The idler pulley in the picture is behind the motor.
I would check the ilder pulley to see if it rotates freely and does not have any odd side to side movements. If it does then replace the idler pulley and belt.
Belt: http://www.appliancepartspros.com/part_details.aspx?part_id=4043963&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d47809%26diagram_id%3d681078
NOTE: Before you remove the idler pulley and belt note carefully the installation position of the belt, idler arm, spring and the idler pulley. For a first timer trying to do this it can be quite frustrating to get them all positioned correctly.
Idler pulley:
http://www.appliancepartspros.com/part_details.aspx?part_id=4373393&rdr=%2fpartsearch%2fmodel.aspx%3fmodel_id%3d49146%26diagram_id%3d673577
I hope this has been useful information to you. Good day.
Jan 06, 2010 | Washing Machines
Maytag neptune dryer makes a loud squeaking noise
This noise will normally come from a defective idler pulley. Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced. Check the bearings as well for excessive clearance also(roller bearings)
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Gas Dryer
HI thanks for your question. the problem is with the coils on the gas valve. one has failed. they come in a pack of 2 replace the coils. thanks the appliance doc. please rate my answer. thanks.
Oct 14, 2008 | Maytag Dryers
Maytag MDG2706A Gas Dryer Logo
121 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
