Question about Pentair Jet Vac Quick Disconnect Swivel Jv50
Need wiring diagram for GE Model UG412RMW250P spa disconnect panel
Tip
How do I replace water level pressure switch on a GE top load washer?
Hi.
This solution is listed for the GE WBB4500EWW Top Load Washer model. The procedure also applies to others GE top load washing machine model
Replacing the water level pressure switch is not a difficult operation. Here the guidelines.
  • Disconnect the washer from power. Either unplug the power cord or trip the circuit breaker.
  • Pull out the appliance and place it in a space where you can work.
  • Disconnect the water hoses .located at the back of the appliance
  • Removethe four screws that hold the top panel to the body of the machine andpull up the top panel. Be careful while lifting the top panel, itsedges are sharp and you may get harmed.
  • Disconnect connectorfrom the water level pressure switch. Disconnect also the connectorshooked to the water valve solenoid contacts if necessary to access thewater level pressure switch.Always mark the connections with tape andlabels or take a picture before disconnecting the wires. The pressureswitch has only a two wires connector attached, and wires orientationdoes not matter, but get used to note down all disconnected wires.
  • Remove the clamp holding the hose and disconnect the vacuum hose from the water level switch.
  • To remove the pressure switch, push down the metal tab on the rear panel plate and rotate the old switch until it gets loose.
  • Installthe new water level pressure switch by following operations in reverseorder. Ensure that all hoses are well connected, and that all wiringconnectors are in place.
Replacing the water pressure switch is not a difficult operation, however remember to observe strictly all safety prescriptions.
Before replacing the switch you can try blowing into the vacuum hoseattached to the pressure switch, this sometimes can fix an apparentlyfaulty pressure switch.
Before replacing the switch this can be tested either jumping itscontacts, or using a multimeter to read Ohms on switch contacts, andcheck if the switch is opening and closing the contact. With nopressure applied to vacuum hose the switch must have continuity and lowimpedance, otherwise the switch is faulty.
If you have no technical training, and if you do not have done any similar repair before, then it may be better calling a technician. To get an on site qualified technician, ring GE at the number listed on your use and care manual.
The water pressure switch is part nr. ten on the diagram shown below. Click on the picture to enlarge the diagram:
Here also the replacement part for the model shown in example. Ensure that the part you are purchasing is the right one for your model.
PS269904 - Water Level Pressure Switch.
Regards.
Ginko.
on Mar 13, 2010 | GE WBB4500EWW Top Load Washer
I need a wiring diagram for the control panel for GE dryer model number shear46ee1ww
It should be either folded up inside the control panel or pasted inside the dryer front panel
Nov 11, 2015 | GE Dryers
I need a wiring diagram for a ge window air conditioner
Need model number to try and find you one. Older ge air conditioners had the diagram glued to the inside of the outer case. Newer ones had a sheet of paper folded up and stuck near the control panel sometimes in a plastic envelope.
Jun 09, 2015 | GE Refrigerators
Need to see wiring diagram on control panel in apa
Most common reason a gfi trips is the heater or blower have failed!
Unplug each one, one at a time...
whatever is unplugged/disconnected from board and the gfi stays on, that piece is the bad item and needs repair/replacement.
Apr 24, 2015 | Pool & Spa
Wiring diagram for BlueRidge Spa
The wiring diagram for each spa is located on the inside panel of the control box.
Remove the side panel of your spa where the control box is located which is usually on the same side where the topside button is.
Once you remove the side panel you will see the control box.
Remove the front cover and on the inside of this cover is where the electrical diagram for all the wiring is found.
Rod
US Parts Center
Nov 02, 2013 | Pool & Spa
I have a LX80 Commercial pool and Spa Control System made by Pentair. I notice this morning that the jet spa motor was running all the time. Which is not right because the control panel is set for 15 min....
If you are positive that the two hot lines onto the motor relay are in the correct postition, then it is the control wires not giving power to the relay to close the circuit. Make sure the signal wires are connected to the contrl board. then, check to see if the timer is still working. its always possible that the control board has failed under the surge conditions. If signal wiring is in place and relay still wont close the circuit, disconnect the relay signal wires, set the timer to come on, and after it tries to activate that relay, measure for 24 volts at the relay signal wire terminals. If no voltage is found, bad timer, or bad board.
http://www.pentairpool.com/pdfs/LX80IG.pdf
above link has wiring diagram included incase needed
Jun 08, 2011 | Pentair LX802L Commercial Pool/Spa Control...
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
Pentair Jet Vac Quick Disconnect Swivel Jv50 Logo
1,054 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
