Question about Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel
Frigidaire freestanding 30" electric stainless
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
TheMobilian
  • 8220 Answers
SOURCE: Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Posted on Dec 19, 2008
  • 39 Answers
SOURCE: F1 fault code Frigidaire electric range
all solutions on the F1 show to replace the EOC control.
Posted on May 22, 2009
  • 506 Answers
SOURCE: we have a f10 error code on our electric range
F10 is thermal runaway. The RTD is most likely bad. Open the oven door and look in the upper corners you will see a little metal rod protruding from the back of the oven, this is the RTD or resistive temperature device. A local parts store should have these.
Posted on Dec 15, 2009
  • 572 Answers
SOURCE: Frigidare oven model ples389ecc displays error
i think the clock is bad
Posted on Feb 06, 2010
Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is off.....how can we re-attach it.
Hey Alice, I appreciate your post!
I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995639282.pdf
Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
Frigidaire stove error code
F68 = Power Line Failure. Turn power off for 30 seconds. If this does not correct it, check the electrical supply for proper voltage, ground, and polarity, if all of this checks ok replace the EOC-Display board
Aug 08, 2014 | Frigidaire Gallery 30 " Stainless Steel...
F10 error code on Model # FEFL79GCA Frigidaire Stove
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 24, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Top is scrached can it be replace
yes $298.00 but you are missing the last letter of your model # denotes the color
Feb 21, 2010 | Frigidaire FEF366EC 30" Freestanding...
THE TOUCH PAD DON'T WORK SELECTING ANY CHOICE OVEN ON,CLOCK SET' ETC ERROR MESSAGE F-1 ERR
The F1 code on all ranges is a bad ERC(clock).
The only repair is to replace the ERC.
Nov 09, 2009 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire stove mod #cfef385jht1
I'M NOT TO UP TO PAR ON THIS MODEL BUT SEE IF THERE IS A PANEL ON THE REAR OF THE CONTROL PANEL AND LOOK FOR A FUSE
Aug 25, 2009 | Frigidaire FEF366EC 30" Freestanding...
Self cleaning oven
http://www.frigidaire.com/support/Result... just need to identify exactly which model you have and download your manual. May your burners be eternally clean Hope this helps :)
Mar 14, 2007 | Frigidaire FEF366EC 30" Freestanding...
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
22 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
