Question about Hasbro Beyblade Metal Fusion Electronic Top Wave 1 Set Of 2
My face bolt for my counter Leone broke in half and i need to know how to fix it
You can use glue to stuck them .As like as -fevi quick ,dendrite .AND ALSO TAKE CARE OF YOUR BEY .THAT'S HOW YOU WILL BECOME A STRONG BLADER LIKE ME .
Posted on May 19, 2013
Brake caliper mounting bolts
They are standard thread, and very tight.
If you are facing the bolts from the back of the caliper, you turn counter-clockwise to loosen. If you are facing the caliper from the front you would turn them clockwise. You may need a very large breaker bar and socket to get them loose.
Jun 05, 2013 | 2001 Chevrolet Monte Carlo
Need to know which way the threads are on a crankshaft pulley to take it off
To remove you go counter clockwise just like a regular nut or bolt (lefty loosy, righty tighty). You most likely will need some sort of power tool to loosen the bolt. I have in some cases (but don't suggest) taken a half inch drive breaker bar and wedged it in the correct location for which way the engine turns and "bumped" the engine over to break the bolt loose but if you don't get it on there real good you may end up rounding the head of the bolt and then you would be in trouble. I hope this helps you and good luck.
Jun 12, 2011 | 1993 Oldsmobile Cutlass Ciera
Suzuki has since done a recall to inspect and replace the Crossmember /sub frame. I think the letter came out in July. I just got mine done in November ago in Canada. I think the dealership scammed me...
You got scammed! If a bolt broke off, THEY broke it off, not you! Report the dealer to the bike manufacturer, and ask for compensation, and threaten to take the matter to the National Highway Safety Commission ... and DO THAT if they don't fix the problem!
May 15, 2017 | 1999 Suzuki Esteem
Does the bolt on the blade come off counterclockwise or clockwise.
If you are facing the blade from where the bolt is, and the blade's normal operation is to turn counter-clockwise, then the bolt will loosen counter-clockwise. This is universally true for any blade which is held on by a center bolt (table saws, grinders, etc.) This is because the motor is turning the shaft counter-clockwise, and the resistance against the blade as it does it's work is clockwise - thus tightening the blade rather than loosening it. If the blade normally turns clockwise, then the bolt will loosen clockwise.
Jun 24, 2010 | Craftsman Garden
Bolt broke off inside side mount battery. how do i get it out
Go to the parts store & get a bolt/screw extractor.
It works by first drilling a small hole into the bolt you broke, then you screw the extracter, counter-clockwise into the bolt & it will back it out. Soak the broken bolt with lubricant/wd40 before trying to extract. Don't drill more than the depth of the bolt.
good luck.
Feb 14, 2010 | 1992 Buick Century
I have a 93 crand caravan the water pump went out and in the process of changing it bolts broke how can i fix it?
If the bolts broke off inside the engine block they must be extracted, buy a easy out set of bolt extractors choose the appropriate size drill to use in relation to the broken bolt to be removed then dril a hole through the old broken off peice remaining inside the bock take the easy out extrctor and push it into the drilled hole then tap it into the hole firmly proceed to tur n the extractor counter clockwise to remove the broken off peice. whatever you do don't use an extractor that is too large it may not work you can always go up on the size later.
Dec 15, 2009 | 1992 Dodge Grand Caravan
Right side half side broke
disconnect outer tie rod and ball joints from wheel hub. remove hub. check for retaining bolts to trans . remove axel u will probably need to use a pry bar
Aug 14, 2009 | 2006 Chevrolet Aveo
Which way do I turn the main bolt on crankshaft to get main pulley off. I went counter-clock wise and it broke the braker bar.
you turned it the right way but will have to use an air impact to get it loose or a hammer to hit the ratchet or breaker bar with, you need a half inch drive breaker bar to get it loose and it will have to be in gear and the emergency brake on to get it loose.
Jul 15, 2009 | 1995 Isuzu Rodeo
Broken exhaust
The sad fact is, you will probably be etter off removing the head and having the busted bolt removed and repaired, either by you or a machine shop. You have limited room, a ruined, hardned extractor in there.... going any farther with it in place will most likely F-it up more.
Nov 10, 2008 | 1987 Yamaha FZ 750 MG (Europe-US)
Open Questions:
See all Hasbro Beyblade Metal Fusion Electronic Top Wave 1 Questions
Hasbro Beyblade Metal Fusion Electronic Top Wave 1 Set Of 2 Logo
95 people viewed this question
Top Hasbro Toys Experts
thegtw
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
