ELECTRICAL PLUG WIRE ON TARGUS POWER ADAPTER, MODEL NO. 800-0196-001A DISINGAGED FROM THE CHARGER. IS THERE A REPLACEMENT FOR THIS PART SINCE IT WAS PURCHASED 03-22-08
  • 177 Answers
The most likely solution is that you will have to replace the charger as it may not be cost effective to just repair.
Posted on Aug 14, 2008
SOURCE:
HI there! I am using a targus universal wall power adaptor for laptops, it has an output of 19.5 V and 90 W. I was wondering if I could use this to charge my UK laptop from ADVENT. The charger for this has...
The wattage is to different, the wattage for the adapter is 90watts, and the charge for the advent is only 65w.
You can always try it, but you risk damaging your battery, or motherboard.
Jul 16, 2011 | Targus APA30US AC Laptop Charger AC...
When i use the computer with full charged(batter) w/o the charger inserted it is working fine once the battery is low, i insert in the charger it will hand my compuer. Basically now my laptop cannot be...
Hello.
From your description, your A/C adapter (power charger) is faulty and needs to be replaced. Look online or at a local shop for a replacement. Targus manufactures a good A/C adapter. Check to see what adapter works with your laptop.
Hope this helps.
Jun 14, 2011 | Toshiba Computers & Internet
Targus COMPACT laptop charger isn't working
Your battery sounds like its buggered. I would suggest buying a new battery
May 20, 2010 | Lenovo 3000 G530 Notebook
Universal power supply targus tip for Dell Latitude D620, won't charge battery, pop up says slow and no (charge), use only Dell. Is there a Targus tip that will go on Model APA10 Targus Universal power...
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
You will need to get a Dell AC adapter.
http://www.discountelectronics.com/index.php?l=product_detail&p=1459
Feb 15, 2010 | Dell Latitude D620 Notebook
I have the targus universal power adapter and can't figure which
If you cannot find the right tip, plug each tip in the Targus and measure the voltage of each tip with a multi-meter.
On the bottom fo the Acer the operating voltage of the laptop will be printed on the label.
Select the tip that matches the voltage that is printed on the Acer label.
Sep 19, 2009 | Targus (PA179U) Car Adapter
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Replacement plug in charger for kawasaki dvd player
On the back/bottom of the unit somewhere, there should be a label that says something similar to:
"Power: 9VDC 1300ma"
and there will be a little picture of the polarity of the plug.
If so, take your Unit to Rat Shack or local electronics repair store and ask them for a replacement power supply.
Mar 12, 2009 | kawasaki PVS-10921 Portable DVD Player
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
Your laptop problom, i have the same thing
I would check the power adapter with a voltage meter. It sounds like the adapter might be defective. The wire at the end of my adapter broke after a month or so of use. I picked up a targus replacement. The only problem since then is the targus plug is a bit loose.
Best wishes
Jul 19, 2008 | Gateway MX8711 Notebook
Computers & Internet Logo
74 people viewed this question
Ekse
Alun Cox
