Question about Kenmore 8,000 BTU Single Room Air Conditioner
I have Kenmore air condition Model 58076081500, Use power saver set at 76F. After the room cool down to 75 or below the air conditioner won't shut off as usual, keep running all the time. What part should I replace?
5 Suggested Answers
lambocar
  • 31 Answers
SOURCE: My air conditioner will not turn on.
AC has a relay, it sounds like it failed on ya. If the unit was on all the time, was it that hot where you were or do you mean switched from AC to fan on all day? From what you said, it sounds like the unit burned its relay out for overheating, meaning thermostat may have originally failed keeping unit on until relay popped. Careful of fire hazard.
Posted on Jul 07, 2010
heatman101
  • 43501 Answers
SOURCE: kenmore window air conditioner model
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 02, 2011
pepper74112
SOURCE: What would cause the air conditioner (model 75251)
On my air conditioner it was the run capacitor that was the problem. It was leaking.
Posted on Apr 13, 2012
If you have a GFCI plug on A/C unit it may need to be reset at the plug.
Posted on Mar 21, 2013
Air conditioner kenmore energy saver model 58076081500
The water should be draining out. Check wherever the drainage is for a blockage and clear it.
Sep 20, 2013 | Heating & Cooling
Power save mode
What model Kenmore air conditioner?
Jun 26, 2013 | Kenmore Heating & Cooling
Kenmore 580.15151500 Compressor doesn't turn off
Most likely is a issue with the temperature sensor that when it reaches the level selected is not turning the compressor off.
Jun 15, 2012 | Kenmore Room Air Conditioner
Thermostat says it's 64 degrees inside so the cold air will not turn on but it's still 80 outside and it's still about 75 inside won't blow cold air during the night time hrs
Hello, Here is a trouble shooting guide for you and some details of how to fix it based on your symptoms. Here is a link to go to and make sure you jump around the site, it will tell you the fix based on your problem off the trouble shooting table. Link is below , copy and paste in browser. If this helped you, please rate it and some kind words are nice. Thanks Mike
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners1.htm
Jul 23, 2011 | GE Electronic Room Air Conditioner AGW12AH
The air conditioner stopped blowing air. It is still too hot for it to have shut off automatically, When I power it down & turn it back on it makes a noise but won't start blowing the cool air. The...
Your going ot have to shut it down and let it deice. remove the filter and replace it or wash it out . this might take a few hours so leave the indoor fan on it will speed thing up a bit. also set the temp to mid range and close all unused rooms off it has to cycle a bit but really my money is a dirty filter and ice.
Jul 19, 2011 | Heating & Cooling
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
Stuck on 75 degrees. Won't respond to buttons or remote
The thermostat sounds like it's bad. If it was good, you could change the temperature settings. The thermostat has to send a signal to the control board, and if it's bad, that just won't happen, and no cooling can occur.
If this unit is a room air conditioner, here is how to check the thermostate on it:
http://home.howstuffworks.com/home-improvement/heating-and-cooling/how-to-repair-room-air-conditioners.htm
Good luck, and hope this helps.
Jun 02, 2011 | Maytag MEY18F7G Air Conditioner
My air conditioner will kick on but will stay on and not
The thermostat is not functional, therefore its not cutting off the compressor once the room air gets cooled to the temp setting of the thermostat, also the refrigerant gas may have leaked out some but not the entire refrigerant gas(freon, CF4, etc.), keeping the compressor running contentiously to come down to the set temp..............sodeep
Aug 20, 2009 | Carrier 38CKC042 Air Conditioner
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
Kenmore 8,000 BTU Single Room Air Conditioner Logo
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
