Question about LG WM-2277HW Front Load Washer
What are the intructions on how to change the "motor pump assembly"? I have the part and want to try abd save $ by changing it myself ... thanks
  • 110 Answers
Here's a link to complete instructions to repair your washer. You may require a special tool to remove the installed pump. Click on the small pictures at the end of the page to view the detailed instructions. Here's the link;
http://www.managemylife.com/mmh/questions/228916-lg-washer-model-wm2277hw-code-oe-wont-drain
Posted on May 18, 2011
I have A Hobart LT1 dishwasher I have changed water motor pump and motor control contactor but machine is still making a loud noise and will not cycle. What could be wrong?
Wrong site. But I congratulate you on trying to fix it. Most don't. For me..I had 2 wives, eight kids and myself. None of us broke down and couldn't wash dishes. Yes I had several, just never used.
Jan 05, 2017 | Cars & Trucks
Need a wiring diagram for a 1997 Nissan quest xe fuel pump assembly it has 4 wires and my not so smart brother in law tried to change fuel pump abd instead of disconnecting the plug he cut the wires so I...
Usually, replacement pump will come with wiring instructions. If dumbo lost them, might go to friendly parts store and ask to look at chart in another one, or simply look at wiring diagram in your shop manual.
Dec 15, 2014 | Cars & Trucks
Washer will not spin. Cleaned drain/filter. Worked for 2 days. Now won't spin and checked drain, it is clean. The drain pump works fine. What to check next?
i had the same problem a year ago. nothing seemed to work. we even got a new washer, same problem. we ended up putting the washer on its own circuit. works fine now.
Feb 16, 2012 | Bosch Nexxt 100 Series WFMC1001UC Front...
HI I JUST GOT CODE P1237 AND I WANT TO KNOW HOW TO ACCESS THE FUEL PUMP DRIVER MODULE, SO I CAN TRY TO FIX IT MYSELF. IS THIS HARD TO DO?
I had the same situation. The fuel pump was overheated and caused the fuse to the fuel pump to burn out. You will need to replace the fuel pump assembly. I say the whole assembly because the problem is in the internal connector. Don't forget to change out the fuse!
Aug 07, 2011 | 2001 Mercury Cougar
Product - YAMAHA AW16G Digital Workstation Two problems: 1) The record button broke (the plastic tabs that hold it in place). The record function still works, but I need to have the actual button...
Unless you are a electronics expert or a pediatric surgeon, I don't think you can attempt to fix the button yourself. And more over these buttons are not available as spares. New company policies are use and throw. Even life has become disposable today !!
Mar 07, 2011 | Audio Players & Recorders
My drivers power window won't work. suddenly quit..depress the window and nothing happens, don't hear anything..all other windows work..need new motor? can i do it myself and save over 300 that the repair...
before you change the window motor check to see if you are getting power to the motor frist it could just need a new window
switch but if you need to change the motor the only thing you need to get the rivets out is a drill and a drill bet and they will come out
Aug 17, 2010 | 1999 Chevrolet Suburban
1995 BUICK PARK AVENUE SUPERCHARGE ULTIMA
On the GM car the engine will have to be removed to change your oil pump, however it is easiest to pull engine and transmission as an assembly. My question is why do you think you have a failed oil pump??? If oil pump fails it usually screws up engine too....
Aug 27, 2009 | 1995 Buick Park Avenue
Changing motor hayward 1.5 HP
Remove the rear motor cover and lock the shaft to spin the impeller off. Be sure to note what voltage your old motor was set for and duplicate that setting on the new motor.
We sell the motor at www.arrowmotor.net
Jun 01, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Change fuel pump assembly Buick Roadmaster 1993
Yes you can, its on the Passenger side of the car, right under the back seat under the floor board, track your fuel line from the tank to there. Good Luck.
Dec 12, 2008 | 1993 Buick Roadmaster
How do i change the belt on a aman aww990 washing machine myself do i have to take the pump off first
yes remove the 4 bolts holding the motor /pump to frame remove hoses from pump and belt from gearcase pulley first ..turn assembly upside down if old belt still on note routing before removing screws in pump mount belt has to be routed around 1 of the pump legs
Jun 17, 2008 | Washing Machines
LG WM-2277HW Front Load Washer Logo
126 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
