Question about Dell 1600n All-In-One Laser Printer
Dell 1815dn my wife tried to scan some photos and may have messed with the settings and now I can scan or send any faxes gives me the error code: SEND ERROR (STMP) it will still recieve faxes and copy.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Hmmm..would that error be SMTP, by chance?
Posted on Aug 19, 2008
Dell 1815dn Fax confirmation?
U CAN DO A FLEA POWER . \
1. restart the system ,
2. turn off the power / scan/ fax ,
3. unplug all the cable to the system and wall socket and then wait for 20-30 seconds .,
4. connect all the cables and give a try it should work.
Oct 20, 2014 | Dell Printers:Dell MFP Laser Printer...
Can send but not receive faxes. dell 1815 dn. I can do everything else, just not receive faxes, went through help lists and have follow everything to no avail...i need it to work:(
Did you check the "answer call after x rings" option?
It sometimes defaults to 7 rings, at which time the sending fax machine has given up already.
You find the settings here: "Fax -> Fax Defaults -> Rings to answer"
If this solved your problem - great!...If not, just come back and leave a comment - I'm happy to help.
May 22, 2010 | Dell 1815dn All-In-One Laser Printer
Scan from printer through router to pc?
You will need to use the TWAIN software for the printer. From the computer you will be running the scan options thru the TWAIN software. Then the scan files will be pulled from the printer back to the computer. Running scan options directly from the printer will give you the option to print the scan files or send them to a memory card if your printer has a slot for one. If the scanning software is not installed on your computer then you will need to download it from the manufacturer's website.
Sep 22, 2009 | Dell 1815dn All-In-One Laser Printer
I dont know how to send a fax using the Dell laser MFP 1815 dh
Here is a link to the Dell website where you can download the user manual for the MFP 1815dn. I just looked and it has a complete section on how to use your fax...
http://support.dell.com/support/edocs/systems/prn1815/en/index.htm
Sep 10, 2009 | Dell 1815dn All-In-One Laser Printer
How to get the all in one fax / copier /printer to stop printing a report after each incoming and out going fax. It waistes ink and paper.
1 Click Start Programs or All ProgramsDell PrintersDell Photo AIO Printer
964
Dell All-In-One Center.
2 From the Dell All-In-One Center, click the Maintain/Troubleshoot tab, and then click
Display the Printer Setup Utility.
Printer Setup Utility Tabs
On this tab: You can:
Send • Enter your name and fax number.
• Select a maximum send speed and a print quality for outgoing faxes.
• Choose whether to scan the entire document before dialing the number.
• Choose whether to use error correction.
• Select when to print a fax usage report.
• Select when to print a fax activity report.
this information is from the manual found here
http://support.dell.com/support/edocs/systems/PRN964/en/om/om_en.pdf
I hope this helps
Mar 12, 2009 | Dell Photo 964 All-In-One InkJet Printer
Lines going thru the pages of fax i send
you ma try to make a copy see if have lines through the page if does, you may go to document feed unit open the cover you may see a piece glass just use alcohol to clean it should take care your problem
Dec 13, 2008 | Dell 1815dn All-In-One Laser Printer
Fax Transmission fail from Dell Laserjet 1815dn
what do we do if our dell fax machine lazer mfp 1825 doesnt send or recieve faxes?
Nov 15, 2008 | Dell 1815dn All-In-One Laser Printer
SCANNER SAYING NO USER ID
This means that you have not set up any users in the address book in the printer.
Copy is simple, it will scan the document and print out a copy of the scanned image.
Scan however, is trying to make and store an image file of the scan, but it needs to know WHERE you want to scan it to. The printer does not know where to send the stored image unless you create a storage location for it. This is done with the address book that is stored on the printer.
The material below is how to set up the scanner settings of the printer.
Printer Settings Utility Using the Printer Settings Utility window, you can set up the fax system data options, and create and edit Phonebook entries from your computer. You can also configure the destination launches when you access Scan and then PC.
When you install the Dell software, the Printer Settings Utility is automatically installed.
For information about installing the software, see "Installing Software in Windows".
To open the Printer Settings Utility:
  1. Click Start software25.jpg Programs software25.jpg DELL software25.jpg DELL Printers software25.jpg DELL Laser MFP 1815 software25.jpg Printer Settings Utility.
The Printer Settings Utility window opens.
  1. The Printer Settings Utility window provides several features; Directory (Phone Book, Address Book), Fax Setting (Fax Cover Sheet), and Scan (Destination, Resolution, Scan Color, Show Preview).
The Scan Section The Destination Section To configure the operator panel display scan destination list that appears when you access Scan and then PC, click Destination and the Setting button. Using the destination list, you can select a software program that an image can be scanned to.
Oct 07, 2008 | Dell 1815dn All-In-One Laser Printer
Faxing/scanning from AIO 964
throw it in the dumpster and buy a new one
Mar 03, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
214 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
