Question about HP Officejet 5610 All-In-One InkJet Printer
Problem with print spooler: when i print the document stay in the print queue forever and nothing happens..
    Sergeant:
  • 281 Answers
Right click on my computer>click on manage>when the screen opens there will be a list on the left side of the page.Click the plus sign by Services and Applications then click on Services.Thelist is is alphabetical order.Scroll down untill you see print spooler and right click on it.This will bring up a screen has a menu click on properties and this will bring up ascreen that has tabs at the top and a place to to change what the print spooler will do.What you want in this spot is automatic.Now click on the dependancees.This tab tells you what programs the print spooler needs to have running so that it will work right.Just make sure that all the programs are on automatic.Thank you for choosing FixYa.com and I hope this helps. You can all so uninstall and reinstall the printer but disconnect the printer while you do this.
Posted on May 19, 2011
  • 34 Answers
If this is a network printer make sure that your printer is properly connected to the network and is showing up in your list of printers. Make sure your printer is not in some sort of standby mode that prevent it from receiving your print request.
If it is a local printer check the connection between the printer and the pc and make sure it is plugged in all the way.
If problem is not fixed check the manufacturers website and download and install the latest drivers.
Posted on May 18, 2011
    Problem Solver:
  • 17 Answers
You may have to check the status of the Printer
1. in the printer spooler window click on printer then click on use printer offline IF there is a check beside it.
2. Try also checking the printer power plug, power, and connection to the pc. Sometimes taking off plug then plugging it back on works.
I hope that helps.
My Lexmark Z705 Will not Print HELP
Use the Vista driver in Windows 7.
Also, make sure that the Print Spooler service in your computer is running. Try following the steps below:
  1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
  2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
  3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
Try to print a document again to verify that the problem is fixed.
Feb 11, 2012 | Lexmark PhotoJet Z705 InkJet Printer
CAN NOT DELETE A DOCUMENT THAT IS IN THE QUEUE, THEREFORE, NOTHING ELSE WILL PRINT. THE DOCUMENT SAYS IT IS DELETING, BUT DOES NOTHING. i POWERED IT OFF, THEN UNPLUGGED IT FOR A WHILE AND IT IS STILL...
There are 2 simple methods to resolve any print job stuck in queue issue. However, both the methods will not fix printing issue if the HP Printer is in Error mode. Make sure your printer is able to print self test page to prove its functionality,
First method.
This Utility program resolve all the printing issue for HP Printers Only ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
If this does not fix, try the 2nd Method given below ( this is manual process to clear the print job stuck in queue )
This works for all brands of printers ( HP, Canon, Epson, Brother etc )
Click Start > Programs > Accessories > then select Command prompt, then the black window will open and there type NET STOP SPOOLER and hit enter that will confirm service is stopped , after that on the black window type NET START SPOOLER and hit enter. Repeat this step 3-4 times and end the command with NET START SPOOLER and hit enter. Open the Printers folder and Refresh the Window ( Press F5 on the keyboard )
The service will be started and all print queue should already be remove.
// Above given solutions help in resolving print queue issue, however check the printer functionality if it is working fine ( the printer should be in working condition and should be able to print self test page, this utility cannot fix printer hardware issue //
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Jul 02, 2011 | HP Photosmart Premium C309A All-In-One...
When I send a document to print, the document seems to get 'stuck' and won't print. The status bar stays at about 50%. Sometimes it prints, sometimes it won't.
It could be the print spooler of your computer that has gotten disabled somehow. Try to refresh the print spooler on your computer by following the steps in this article in the Lexmark website on How to Restart or Reset the Print Spooler in Windows. Once the spooler has started, make sure there are no print jobs stuck in the print queue before sending out a new print job.
Feb 21, 2011 | Lexmark X4975 Wireless Color Multifunction...
When the message "5 documents pending" appears but
Rebooting the computer may help get rid of the print jobs stuck in the queue. If not, follow these instructions carefully:
For Windows
Stop the Print Spooler
  1. Go to Control Panel
  2. Go to Administrative Tools
  3. Go to Services
  4. Look for Print Spooler in the items. Double-click on Print Spooler -> click on Stop -> click Ok. Set the Services window aside.
Clear the Spool folder
  1. Go to Start
  2. Type Spool in the Search/Run bar, hit Enter.
  3. Open PRINTERS folder
  4. Delete all the files in the PRINTERS folder. Close the Window
Re-enable the Print Spooler
  1. Go back to the Services window
  2. Double-click on Print Spooler, and click on the Start -> Click on Ok. Close the Services window.
Go to Printers and Faxes and refresh the page. It should clear the print queue now.
For Macintosh
Simply launch Terminal and type cancel -a - That will clear the print queue.
Nov 09, 2010 | Lexmark X2600 InkJet Printer
Printer is not working. There is no error light on and the ready symbol light is on. Nothing willnot print
Have you checked if there are any Documents Stuck in Queue to print ? ( under Control panel - Printer and faxes folder )
Click on Start button
Click on Run
Type SERVICES.MSC and click ok
look for Print Spooler in the list
highlight Print Spooler,
Click on STOP button then click on START
close the window and check if the print queue is gone. ( Refresh the Printers and Faxes folder )
If this does not fix the issue :
Alternate method,
Click STart
Click RUN
Type Cmd ( or COMMAND ) and hit enter
In the black window type
NET STOP SPOOLER ( hit enter button )
Type
NET START SPOOLER ( hit enter button )
Repeat the Stop and START Command 4-5 times
End the Command with NET START SPOOLER
Open Printers and faxes folder - Refresh the Window - the printer will show Status ready with 0 document
Jul 03, 2010 | HP LaserJet P2015dn Printer
My printer won't print...there's a document in queue but it won't print and it won't delete.i've unplugged the printer and re-plugged it in I've restarted my computer...nothing is happening.
Try these steps to remove the print jobs stuck in the queue. Follow the instructions carefully:
First, you have to stop the Print Spooler. To do this: 1. Click on the Windows logo start button. 2. Go to Control Panel 3. Open Administrative Tools 4. Open Services 5. It will pop-up a Services window. Scroll through the list and look for Print Spooler. 6. Double-click on Print Spooler, and click on the Stop button. Click on Ok button. Set the window aside.
Second, you need to clear the print jobs in the Spool folder. To do this: 1. Click on the Windows logo start button. 2. Type Spool in the Search bar. 3. Open Printers folder 4. Delete all the files in the Printers folder. Close the window.
Third, you have to re-enable the Print Spooler. To do this: 1. Go back to Services window. 2. Double-click on Print Spooler, and click on the Start button. Click on Ok button. Close the Services window. Click on the Windows logo start button. Go to Control Panel and open Printers folder. Refresh the page. That should clear the print queue now.
If it still won't print, make sure to clear the print jobs in the queue again and try to reinstall the software. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Jun 21, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
How do you clear que on a c6300 photosmart
Windows XP Operating System
Restart the Print Spooler device
  1. Open Administrative Tools.
  2. On the Windows taskbar, click Start , and then click Control Panel .
  3. Click Performance and Maintenance . NOTE: This step is not necessary in XP Classic View.
  4. Click Administrative Tools .
  5. Double-click Services .
  6. Click Print Spooler .
  7. Click Stop to stop the Print Spooler.
  8. Click Start to restart the Print Spooler.
  9. Click OK .
  10. Restart the computer.
  11. Try the print job again.
Manually clear the print queue
  1. Return to the Printers and Faxes folder that you opened in the previous steps.
  2. Right-click the name of the product, and then click Open .
  3. Click Printer , and then click Cancel All Documents .
  4. Click Yes to confirm the action.
  5. If documents remain in the print queue, restart the computer.
  6. Try printing again.
Windows Vista Operating System
  1. Return to the Printers folder that you opened earlier in this document.
If the issue continues, proceed to the next step. Restart the Print Spooler device
  1. On the Windows taskbar, click the Windows icon (c01319360.gif ), click Control Panel , and then click Administrative Tools .
  2. Double-click Services .
  3. On the User Account Control window, click Continue .
  4. Click Print Spooler .
  5. Click Stop to stop the Print Spooler.
  6. Click Start to restart the Print Spooler.
  7. Click OK .
  8. Restart the computer.
  9. Try the print job again.
Oct 03, 2009 | HP Office Equipment & Supplies
Document stays in queue
You may want to update your driver.
Mar 30, 2009 | HP Deskjet F335 All-In-One InkJet Printer
My print spooler queu says that my document is printing but the document never prints
Go to Settings or Control Panel and select Printers - double click the icon. Here you will find the Print Queue. Delete all jobs in the Print Queue (the first one is probably the problem child and is stopping any others from progressing).
This will free up the Print Queue which should now be ready to accept new Print jobs.
Note: The Spooler is an area where Print Jobs are stored ready for Printing and as long as the previous print has finished then the next job in the Spooler will progress to be printed onto paper.
Good luck.
Apr 14, 2008 | Epson Stylus Multifunction Inkjet Printer/...
HP Officejet 5610 All-In-One InkJet Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
