Question about Quinny Baby Gear
It seems like the front wheel of the Quinney Buzz 3 stroller is always "stuck" and won't align properly in a straight position. Therefore, my stroller often times cannot go striaght/is hard to move around
  • Quinny Master
  • 1,629 Answers
Good Evening
The cause for this is a build up of dirt and grime. Your Quinny Buzz should be regularly cleaned and maintained in order to keep it operating smoothy. We have a Handy Hint guide for cleaning of the front wheel of the Quinny Buzz 3 if you're in the UK follow this link: http://www.facebook.com/media/set/?set=a.112250718852471.18255.104570846287125#!/photo.php?fbid=112250802185796&set=a.112250718852471.18255.104570846287125&type=1&theater
Posted on May 23, 2011
I need wheels for my quinny buzz stroller
Hi - If you're in the UK you can order from your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30. RRP is 30GBP per rear wheel and 25GBP for the Buzz 3 front wheel. P+P would be 8GBP if ordered direct.
If you're not in the UK please go to www.quinny.com and select the country you're in, then click the "Contact Us" tab to be put in touch with the customer service department for your country.
Oct 05, 2011 | Quinny Buzz 3 Stroller
Hello, I recently bought a quinny buzz 3 (second hand) and its very difficult to collapse the frame, but it's easy to open it back up. What would I need to do to fix the problem?
Good Evening
It sounds as though you're not quite depressing the fold buttons fully when trying to collapse it, so you're pushing against the natural spring of the chassis which is making it difficult.
The Buzz is easiest to fold when you're standing in front of it. Either remove the seat unit, or make sure it is forward facing and in the upright position before you start. Swivel the front wheel straight and lock it into position. Standing in front of the Buzz, push the left side button in until you can't make it go any further, then roll the right button toward you as far as possible. It should only require a small amount of pressure to fold the unit, but remember, due to the style of the automatic unfold you are working against it to fold it up. If you hear any clicks, pops or creaks, don't force it as you'll break the fold knuckles.
If this still doesn't work, give the chassis a good, thorough clean to make sure no dirt or debris is causing the problem. Use a dry Teflon spray (found in the laundry aisle of most supermarkets) or normal furnature polish with a soft dry cloth and give the whole chassis a thorough cleaning. Then as you're folding it down, follow the black plastic down the central tube as it goes toward the front wheel unit to make sure its totally clean. This should make it smoother to fold.
Failing that, the product will need to be returned to the engineers for inspection - which country are you in?
May 18, 2011 | Quinny Buzz Three Wheel Stroller
I need new wheels for my Quinny Buzz
You can buy all the types of buzz wheels (front 3 wheel unit, front 4 wheel fork unit, front 3 all terrain air inflated unit and rear wheels) direct from Dorel, go to http://www.dorel.co.uk/contact-us/ or Tel: 01842 763281., they are always super helpful and very nice. Or you can buy them from this retailer (which I found to be a good deal cheaper) http://babyequipmentcomplete.com/main_site/main/index.php?pge=check or on ebay which are definitely more expensive for new wheels, but perhaps not for used ones. Hope this helps.
Apr 10, 2010 | Quinny Buzz Three Wheel Stroller
Quinny buzz 3 and front wheel
I would personally recommend the Buzz 4 front wheel as I beleive that this offers much more stability than a single front wheel. If this does not work out for you, you can always eBay it, it will sell within minutes!
Hope this helps.
Mar 23, 2010 | Quinny Buzz Jogger
I have a quinney buzz 3 wheeler i wondered if there was an attachment to make it 4 wheels
yes there is your local quinney stockist will have all the information if not contact www.buggypitstop.co.uk
they sell spare parts, and will be able to convert it to a four wheeler
Dec 23, 2009 | Quinny BUZZ 3 Jogger
Warranty
Go to this link for Quinny Parts and you can either fill out the form or call them directly at their 800 number shown.
http://quinnybaby.com/info_replacement_parts.asp
I hope this was helpful, DutchTexan
Oct 14, 2009 | Quinny Buzz Three Wheel Stroller
Front wheel of quinny buzz always gets stuck and hard to turn. i always check to make sure it's in the unlocked position.
I would suggest that you completely remove the wheel (pinching the two black plastic buttons and pull it out). Fully clean the assemble and re-attach. Also, a good idea would be to lubricate the moving parts with a thick lubricant, such as vaseline.
I hope this helps.
Aug 03, 2009 | Quinny Buzz Three Wheel Stroller
How do i collapse the buzz modelof the quinney pram
check the manual at www.quinny.com and there are some good you tube videos as well but basically, stand by the front wheel, position the seat slightly reclined and forward facing. Press the buttons on each side of the seat and pull the hinge forward and down. Make sure it clips shut or it will spring open again.
Aug 02, 2009 | Quinny Freestyle 3 XL Stroller
Quinny Buzz front wheel.
Hi they are not very good on rough ground, you can buy all terrain front wheels on ebay.
Oct 06, 2008 | Quinny Buzz Jogger
Stroller pulls to the right.
The following is from the instruction manual for the Expedition LX. It should be very similar to the Expedition LE.
"Stroller pulls to one side:1. The stroller is sensitive to the air pressure in the tires. If the rear tires do not have equal pressure, the stroller will feel like it is pulling to the side with the tire with the lower tire pressure. Check that the rear tires have the same pressure. Add air pressure to a maximum of 25 pounds using a bicycle style hand air pump.2. The alignment of the front wheel of the stroller can also cause the stroller to pull to one side. The stroller is designed so that the front wheel can be adjusted to correct for any alignment problem. Page 3 of the instructions
shows an expanded view of the front fork assembly. To align the front wheel, first loosen the wheel via the quick release handle as in step 2 of the instructions. Grab the front wheel directly in front of the stroller and push the wheel in the opposite direction of the pulling problem. You will notice that the axle will move within the slot on the fork. Move the wheel to the side a small amount. Retighten the quick release handle. Give the empty stroller a push across an empty smooth surface (let go of the handle) and note if the stroller now runs straight. Re-adjust the axle a small amount at a time until the stroller runs straight. Please note that a very minute
movement of the axle will affect the tracking of the stroller. Once you have aligned the front wheel, you can mark the holding plate position with a marking pen if you detach the front wheel on a regular basis. Please note that the hole in the fork is designed to allow the stroller to be adjusted to pull to the right, go straight, or pull to the left. If you continue to have difficulty with tracking, please call our customer service department at (800) 328-7363 for assistance."
Mar 30, 2007 | Baby Trend Expedition LE Jogger
Baby Gear Logo
226 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
