Question about Garden
Trying to replace my deck belt on zipper mower forgot the pattern I guess.
  • 10865 Answers
SOURCE: Installing mower belt
The pulley at a wierd angle is the tension pulley. You may get the manual on line for free if you are lucky but not all mower manufacturers are that generous. What kind of mower do u have?
Posted on Mar 31, 2009
  • 6 Answers
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Posted on Apr 06, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
bargainbin2
  • 123 Answers
SOURCE: replacing deck belt
Here ya go.
Posted on Aug 26, 2009
mickey813
  • 472 Answers
SOURCE: We have a Weatern Auto Wizard Riding Lawnmower.
19c5756.gifHOPE THIS HELPS LET ME KNOW
Posted on Nov 19, 2009
Need a diagram of pattern to put belt back on a 2014 gtx 52 inch cut riding garden tractor
Kerri, Check the attached links,instruction and guides deck belt diagram, Good luck pg. 49 in link manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Riding Mower Deck Belt Diagram DIY
Riding Mower and Garden Tractor Belt Routing Diagrams
http://www.husqvarna.com/ddoc/HUSO/HUSO2014_AAenAAfr/HUSO2014_AAenAAfr_GT52XLS_588018326.pdf
Jul 12, 2016 | Husqvarna Garden
How do i replace the bladeees belt?
Remove the deck, Find the pattern of the belt direction on each pulley. While deck is removed check for sharpening blades and greasing spindles.
Apr 08, 2015 | Briggs & Stratton Starter Scott's Equip...
Got a craftsman mower 42 inch deck changed spindles and blades and deck still shakes belt may not be tightening up
did you put the blades on right ??? they have a star pattern and it needs to be lined up correctly... if that's ok does the belt have a bad spot in it or is the engagement mechanism operating correctly ???
Oct 20, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do I replace the blade belt on a ranch king lawn tractor?
Turn off the mower completely and clean out beneath the deck with a mower-cleaning tool to remove any built-up grass deposits. As debris collects inside the deck, the blades can't move freely and you'll have unusual patterns or unevenness forming in your lawn as a result. The mower-cleaning tool scrapes this debris off and restores the deck to proper function.
Measure the height of the mower deck with a ruler when the mower is on flat ground. The deck should be an equal distance from the ground on all sides to ensure an even grass cut. Adjust the leveling bolts on both sides of the deck as needed to readjust the height until it's even. If the mower hits something like a rock or a large stick while mowing, it may knock the deck off balance.
Inspect the deck for any dents or warping. Use a rubber mallet to carefully straighten any dents in the deck if the deck is metal. Plastic decks generally need replacement if they crack or warp.
Remove the deck for a more thorough inspection or cleaning as needed. Remove the grass catcher and take off the pins or mounting bolts holding the deck in place. Lower it to the ground and pull it out from under the mower. Unhook the cutting blade from the underside of the deck with a wrench and set it aside.
Sand off any rust with sandpaper and use the mallet or a hammer to eliminate any remaining dents or warps.
Reinstall the deck once any corrosion or dents are fixed.
OBD Tools 365 Days Shop
Sep 15, 2014 | Garden
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Poulan 38"
Call your local repair parts shops and ask if they have the belts and take your old one with you for comparison, but if I had to guess it would be the 2005 one. It is not about engine horse power, it is about deck configuration, that would be my guess that they changed the deck somehow from 2005 to 2006 or changed the belt material or something like that.
Aug 12, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
I need a diagram of the drive belt and blade belts. How they run above the deck.
Ok.... I have to guess what mower you have. I am going to pass a deck belt link below. The first pitcures that will come up are for John Deere. At the top of the page you will see brands with links to the belt routing. Click on the brand name for your mower and then locate your deck.
John Deere http://opebycrigby.tripod.com/decks/jddeck.html
MTD http://opebycrigby.tripod.com/decks/mtddeck.html
Murray: http://opebycrigby.tripod.com/decks/murdeck.html
The MTD and JD links have most deck belt routing pictures that can equate to other brands.
Thanks for choosing FixYa,
Kelly
Jun 09, 2011 | Garden
My lt1000 craftsman riding mower belt broke. I bought a new one and can not seem to find the manual to see how to replace it. Can you show me a diagram please?
On your mower, lift up the seat and you will find a silver sticker with numbers on it. There is a 9 or 10 digit model number. It will look like 123.456789 Go to www.searspartsdirect.com and input your model number and perform a "model" search. I am assuming that the belt you are referring to is the deck belt. Go to the deck section and you will see a basic pattern of what shape the belt will have when installed. There are 2 kinds of pulleys on your deck...V-groove & flat side. The v-groove pulleys go on the inside of the belt, the flat side will go on the outside of the belt.
If the mower is more than 3 or 4 years, it is probably a good idea to replace the drive belt(s) also.
Good luck.
Oct 22, 2010 | Craftsman Replacement Belt for 42" Deck
I am trying to replace my mower deck belt. I
got to www.searspartsdirect.com eneter model # for the tractor & it should give you the option to look at & the chassis & deck to help route the belt or give you the right belt part #
Jun 05, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Garden Logo
81 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
