Question about Dryers
Nothing happens when i push the start button already checked the house circuit breaker - no problem there
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 18, 2011
My dryer will not start. When you press the start button... nothing happens?
Just so we are on the same page, the skinny white fuse is what you replaced on the blower housing? Have you checked the door switch? It is on the same circuit as that fuse, kills the motor in case the door is opened, that is what I would check next. I have a repair page you might want to look at. I have the service manual and several videos that will help you diagnose:
WHIRLPOOL DRYER REPAIR by Paw Paw
Jan 14, 2013 | Whirlpool Dryers
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes.
When I push the start button, nothing happens. I have checked the breaker and the plug, both are OK. I just completed drying a load of clothes. Kennmore 96590140.
Jan 01, 2011 | Kenmore 62602 Electric Dryer
Suddenly stopped heating water
Check the top thermostat2_bing.gif... right above it is a red button that you will have push hard on to reset...
If all that checks out then you have a bad top element...replace that...
heatman101
Apr 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I went to use my mirowave & it is completely gone. I pushed every button that I could & nothing happens. What should I do
first check the breaker in the electrical panel. your microwave should be on a circuit with nothing else. Depending on when the house was constructed. If the breaker is tripped turn it off and back on. If the microwave is plugged into a gfic outlet check to see if the receptacle needs reset. There will be a reset button on the receptacle. Their may be a orange light on the receptacle.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
My dryer won't start, but I think the cycle button won't engage.
Hi
Thanks for using FixYa. The issue might have happened due to a blown fuse or burnt wiring/components on the control board. You'll need to check and replace the fuse and replace it.
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Sep 20, 2009 | Whirlpool LER4634J Electric Dryer
Dryer will not turn on
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
Please let me know if this help or if I can assist you further.
Thanks
Vic
May 30, 2009 | Dryers
Breaker tripping
Make sure it is plugged into a 20 amp circuit. If it is in a kitchen it should be a 20amp breaker if it trips a 20 amp breaker it needs to be replaced. If it is a new house and you plug it in in the kitchen and it trips a 15 amp breaker then the house does not meet code. ref Article 210.52(B)(1) NEC
Jan 18, 2008 | Emerson MW8107WA Microwave Oven
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Dryers Logo
23 people viewed this question
Top Dryers Experts
