Question about KitchenAid Dishwashers
My kitchenaid keeps flashing clean and when you push the start it has a 2 and
  • 4,323 Answers
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 19, 2011
Clean keeps flashing even when I've cleaned
External visual cleaning is not enough.
The coffee maker needs internal cleaning.
Please descale the machine to remove the error message.
Mar 03, 2015 | Kitchenaid Coffee Maker - 14 Cup - Empire...
My kitchenaid Supurba washing keeps stopping, I have to push on the lid to get it to start again.
Sounds like door switch has dislodged or has foreign material inside it preventing full closure.inspect clean or replace.
Dec 09, 2014 | KitchenAid Washing Machines
Kitchenaid D/W will not start, lights not all working, getting power. What's my problem?
Sylvia.....is the clean light flashing or any other for that matter? Either way it sounds like the control board is locked up. There are many posts on here about how to reset it. Try the following: With the door open:
Push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry (all the lights should light up) then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. This will unlock the control board and you should be able to restart the dishwasher. There are many issues with this Kitchenaid including the door popping open during cycle issue. I have dealt with all of them over the past 8 years of ownership. Finally replaced it with a used Miele and sold the KA on craigslist with full disclosure of all the issues and it's history. I even threw in the rubber door stopper that we resorted to using to keep the door closed. Let us know if the above procedure works for you. Good Luck.
Nov 30, 2014 | KitchenAid 24 in. KUDS01FLSS Built-In...
My clean button keeps flashing and can not get it to reset
The only way to clear this fault code is to do a key pad dance. I know sounds funny.... I will explain, the sani buttom and heat dry are the buttoms needed. close dishwasher, push sani then heat, sani heat then heat, sani then heat. Yes three time.... This will make all the lights flash then go through a system check. This will take about 2 mins or so to complete. The dishwasher will return to normal function wise.
Basically your fault is a heater circuit problem and will need to be looked at to determine what part of the circuit failed.
Good Luck
Jul 12, 2011 | KitchenAid Dishwashers
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Clean light keeps flashing and will not start.
Try the follow key dance, all within 5 seconds push:
HEATED DRY --- NORMAL ---- HEATED DRY --- NORMAL
wait for about 2 minutes then hit cancel
May 24, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Kitchenaid kudso1dlss3 clean light flashing cannot do a new cycle
I do not have the same model as you, my model is KUD01ILBS6 but I have the same problem. A service tech told me it was a error code and here is how to fix it.
1 open the dishwasher door
2 hit high temp scrub button
3 then hit energy saver dry button
4 do step 2 & 3 again
5 close the door
6 hit the cancel button
7 you can hit cancel button again then try to start your dishwasher
This works for me, you may have to do this every few months because there is a glitch in kitchenaid where if the water temp is not sensed right it will keep the dishwasher from working. It took me 3 service calls to find this out.
Jan 17, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Lights flashing on clean. Program does not take.
you can open the lowe racess panel of d/w and you find a techsheet/ trouble shooter, in ther they will explain how to reset a clean light blinkin 7 times.. you can try pushing the "sani-rinse"---"heated dry"--- "sani-rinse" --- "heated dry"... toggling these buttons will triggor a test mode, youl know your in it for all the lights will light, close the door and wait 30 secs or so, the reopen door and cancel cycle, after it runs for 2min it will be ready fro you to start using again.. of the clean light issue returns, id recommned calling for service
Jan 07, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwashers Logo
114 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
