Question about Korg DT-10 Digital Tuner
HOW TO CALIBRATE KORG DT-10 TUNER TO 440 TUNING
  • Korg Master
  • 5,603 Answers
From the user manual:
While the setting is shown in the display, press the CALIB key to
set the calibration.
Each time you press the key you will cycle through the following
settings.
0: 440 Hz 2: 442 Hz 4: 444 Hz 8: 438 Hz
1: 441 Hz 3: 443 Hz 5: 445 Hz 9: 439 Hz
When you have made the desired setting, wait approximately two
seconds without pressing the key.
The indication in the note display will blink three times, and the
calibration setting will be completed. You will then return to tuning
mode.
Just do it and stop on the 440 one.
Posted on May 19, 2011
My Korg DT-10 Tuner is broken. I think it is the power supply. Do you think it is cheaper to repair it or should I just get a new one?
if your pretty sure its a crack in the circuit board from dropping or rough treatment then yes it can be repaired in less than an hour-contact a guitar repair center to see who does there electronics repairs they might take that on if asked , but if it just started to do this with out a known cause its most likely a component failure and that will take some time and knowledge to find cause and repair , on this unit that might not be feasible to do
Feb 29, 2016 | Korg DT-10 Digital Tuner
How to tune 12 string acoustic with ga40
Unfortunately, the manual on
http://www.korg.com/us/products/tuners/ga_40/
indicates that 12 string is not supported.
The owners manual can be downloaded at
http://i.korg.com/uploads/Support/GA40_EFG1_633661472559800000.pdf
The YouTube tutorial is at
https://www.youtube.com/watch?v=Of4CRajvq0E
with a 12 string, you can often tune the octave until the tuner sees the matching note. It won't see the correct string number, but an A note is an A note, whether or not it's an octave higher.
Hope that this helps.
Nov 15, 2014 | Korg Ga40 Guitar Bass Tuner W Batteries
KOrg X5D is out of tune
Did you try to get to Global mode, and then check if the tune is 440 hz?
Check the Global Settings. The tuning might either be altered or the key transposed..
May 05, 2013 | Korg X5d
HI Fixya, My Korg DT-10 is broken, when plugin a cable, the light won't get on. I have some experience with opening a pedal look at the circuitboard to the problem, but this i can't fix it....
Just having "volts" does not guarantee they are the right voltage. Check that the adapter you are using is the right one... this device MAY require a higher current than some and low voltage could cuase the failure. Verify the adapter is the original one... if on batteries, replace them with known good ALKALINE batteries. Music devices for the most part will NOT operate reliably on rechargeables.
Aug 02, 2011 | Korg DT-10 Digital Tuner
I tune my bass guitars on the tuner no problem, i have recently tried to tune an electric guitar, but the tuner locks up... any suggestions please.... Thanks ... J
Make sure you have adequate input level to the tuner... some guitars MAY have inadequate output to be recognized CONTINUALLY by the tuner.
Jul 05, 2011 | Korg GB-1 Pitchjack Plug-In Guitar and...
Have a number of chimes that are out of tune...would like to have 2 octaves checked and replaced or fixed, as needed... also am missing one chime... how do we go about fixing our needs?
The tuning is NOT likely to change unless: Metal tube is damaged OR there is dirt or other buildup on the tubes OR there are cracks in the tube. Procure a Korg tuner to check the pitch of these. Do NOT compare against a piano since a piano is "stretch tuned" and may be off up to 22 cents.
The Korg chromatic tuners can be bought for about $20... they are precise. If chimes are cracked, or damaged, that is usually fatal. Dirt can be cleaned.
Jun 27, 2011 | Suzuki 25Note Chromatic Tone Chime Set
How can I tune mas bass guitar to A=444hz with a KORG GA-40 ???
You turn it on and there are the two buttons under the power on button. These ratchet the base frequency up and down. In the upper left corner of the display you will see what A is currently tuned to in tiny characters.
Mar 22, 2011 | Korg Ga40 Guitar Bass Tuner W Batteries
I recently bought a Korg Pitchblack Tuner. It tunes correctly, (maybe a little slower than my Boss) but it will not power other pedals with the daisy chain. I am using a standard Boss wall wart which...
The tuner uses around 500 ma which may be nearly all your wall wart can put out... DO NOT overload the power adapter by daisy chaining other pedal power loads on it.
Feb 08, 2011 | Korg pitchblack + Tuner
Need Korg GT-2 chromatic tuner help
well i hope you've figured it out by now, it's a really cool looking tuner and i love it. but if you are still having problems...
the switch on the left side: OFF, ON, LMP (ON with a little light so you can see in the dark)
The number and letters you see across the top of the interface indicate which string it is tuning to. 6E is the low E string (the thickest one) and 1E is the high E string (the thin one on the bottom of the guitar), i've seen many people get confused when they've tuned those two.
You can leave the tuner in auto and it will pick up what string you are trying to tune. but if you are having problems getting the correct string or whatever the case is, you can switch to manual mode. click the only button on the tuner and the specific string will light up on the interface.
If you press and hold the button, the tuner will go into flat mode, tuning all the strings flat.
once you have the right string and you're tuning it in, you want the needle to be centered.
that's pretty much it. enjoy!
Jan 05, 2010 | Music
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
Korg DT-10 Digital Tuner Logo
920 people viewed this question
Top Korg Music Experts
Michial Gueffroy
Wbix
Are you a Korg Music Expert? Answer questions, earn points and help others
