Question about Clarion DXZ-615 CD Player
I lost power and now the clarion pro audio DXZ615, is displaying: system check press power. How do I get the player to turn back on?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Clarion Master
  • 2,226 Answers
Did you try pressing the source (src) button?
Posted on May 18, 2011
  • 6 more comments
  • tralynda May 19, 2011
    I don't have a source button, but I have tried pressing all buttons.
  • kenw392
    kenw392 May 19, 2011
    Try pressing the function (func) button.
    I did press the function button. I have pressed and held all buttons, so I think it may be a combination of buttons?
    Thank you.
  • kenw392
    Do you know if there is a reset switch on the deck? If there is, it will be an unlabeled depression about the size of a pencil tip on the face, or a small hole with a switch behind it on the subpanel behind the face. If so, try pressing that. You can also try disconnecting power to the radio for an hour or so to see if it may reset itself.
  • tralynda May 20, 2011
    I did find two possible reset holes or depressions and pressed them, but it didn't work. I do not know how to disconnect the power since it's in a sealed dash.
    Thank you for your suggestions!
  • kenw392
    kenw392 May 20, 2011
    How did you lose power? Did the battery go dead? Sometimes you can reset the radio by disconnecting the battery for a couple of minutes.
    Yes, the starter had to be replaced and since then the stereo won't work. I will try disconnecting the battery this evening.
    Thank you
  • tralynda May 28, 2011
    I finally got around to disconnecting the battery but that didn't work either!
I need to find a manual for CD player
Clarion Pro Audio Cd7770 Cd 7770 Wiring Harness Manual ...
www.fixya.com/search/...clarion_pro_audio_cd7770_cd_7770.../manual
Clarion Pro Audio Cd7770 Cd 7770 Wiring Harness, manual related issues. Get free help, solutions & advice from top Clarion experts.
Oct 01, 2015 | Clarion Pro Audio Cd7770 Cd 7770 Wiring...
I have a Clarion XMD3 am/fm marine cd player that came with my 2000 Searay boat. I was somehow able to turn the inside cabin speakers off last season and only have the outside speakers on. I must have...
Might be set on mute !
Mute instructions
Use this function to turn off the sound immediately.
1. Press the [ M ] button.
The sound turns off and "MUTE" appears in the display.
2. Press the [ M ] button again to cancel the mute mode
in this other user manual it is a mute button[m] page 4
http://www.clarion.com/us/en/MungoBlobs/552/388/XMD3.pdf
or
Adjusting the fader
1. Press the [ A-M ] button and select "FAD 0".
2. Press the [ w ] button emphasizes the sound from the front
speaker, press the [ z ] button emphasizes the sound from the
rear speaker.
? The factory default setting is "FAD 0". (Adjustment range: F12 to
R12)
3. When the adjustment is complete, press the [ A-M ] button
several times until the function mode is reached
May 04, 2017 | Clarion XMD3-RET AM/FM MARINE CD PLAYER
I got a clarion DXZ615 AND IT HAS NO WIRING DIAGRAM WITH IT
Your basic wires are as follows: Black - Ground goes directly to chassis ground Red - Accessory + 12V Yellow - Memory and goes to fused battery Grey - Front Right + Grey/Black - Front Right - White - Front Left + White/Black - Front Left - Purple - Rear Right + Purple/Black - Rear Right - Green - Rear Left + Green/Black - Rear Left - Blue/White is your amplifier turn on lead Blue is for your antenna Orange/White is illumination If you are looking for the wires for your car, please let me know the year, make, and model. I should be able to get that information for you as well.
Jun 01, 2011 | Clarion DXZ-615 CD Player
How do I change the time?
Press and hold the [D] button for 1 second or longer to switch to the adjustment selection display. Press <<(rewind) or >>(fast forward) to select CLOCK. Press Play/Pause button. Press <<(rewind) or >>(FF) to select the hour or the minute. Turn the [Rotary] knob to set the correct time. Press the Play/Pause button to store the time into memory. Press the [D] button to return to the previous mode. Reference page 9 in this link to your Clarion DB165.
http://www.clarion.com/us/en/MungoBlobs/615/345/DB165-ENG.pdf
Nov 05, 2009 | Clarion (DB165) CD Player
I can tune in the radio but when i switch of the ignition and switch back on all the stations are lost cheers
The wires are backwards. The Yellow wire is to be for direct power to battery so it keeps memory. The red power wire is to turn on when igniton is turned on.
Jul 09, 2009 | Clarion DB238R CD Player
Clarion 3475 speakers wired, player wont turn on
The RED from the clarion wire must be hooked up to a switched power source ... that was wired to your old radio, then press the reset switch, and it should then turn on.
May 05, 2009 | Clarion DRB2475
Equalizer
Press and hold BAND then press DISP (#4)
here's the manual:
http://www.clarion.com/us/en/MungoBlobs/468/198/DB245(Manual).pdf
Jul 24, 2008 | Clarion DB245 CD Player
Clarion DB245 CD player
I think you press and hold the band button then press the display button
Nov 19, 2007 | Clarion DB245 CD Player
Clarion DXZ-615 CD Player Logo
63 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
