Question about Mitsubishi WD-60735 Projection Television
I replaced lamp on mitisubishi WD-60735. The Lamp light is still blinking yellow, the timer light lit up green, but lamp still blinking yellow
  • 373 Answers
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
Posted on May 20, 2011
  • 1 more comment
  • Troy Mauldin Mar 17, 2013
    did the troubleshooting thing on the mitsubishi website and re-seated the lamp. turned on got sound but still no picture then when turned off, the lamp light went back to red
    oops sorry wrong thread
  • TV Doctor
    TV Doctor Mar 20, 2013
    There is a system restore button on the front to press with a ball point pen
Replaced projector lamp and my lamp light still blinks
Hello, make sure that all the covers are on properly, was the old lamp broken? If it wasn't it may have not been the problem, sometimes the ballast board will cause the lamp light to blink like the lamp is bad....tks
Jan 21, 2015 | Mitsubishi WD-60735 Compatible TV Lamp
How do i reset the lamp timer on my mitsubishi model wd-60735
Not going to fix that if the set even has that (which I doubt). Was the lamp a Mitsubishi or a generic cheap replacement?
when set goes off look to see if lamp is off or on, If you have to turn set back on or when its off, do the sets self check--press and hold both the menu and device buttons at same time for 5 second and release both---power light should blink a digit error code like 1,2, blinks pause and repeat that (1,2 is no error found and 3,7 is lamp issue.
Dec 23, 2012 | Mitsubishi WD-60735 Projection Television
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Nov 22, 2011 | Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
Oct 07, 2011 | Mitsubishi WD-60735 Projection Television
I turned the TV on and heard a pop. I now have a black screen. Nothing works. The Timer light is green when on but not the power light
Hi:
This is an indiccation that your lamp has failed, replace the lamp and you will be good to go, If you heard a pop this was the lamp shattering in its enclosure. Just replace you lamp.
Feb 27, 2011 | Mitsubishi WD-60735 Projection Television
It just shuts off :(
replace Lamp Call Mats Electronics 1-800-628-1118
Feb 01, 2010 | Mitsubishi WD-60735 Projection Television
Mitsubishi Wd 60735 will not turn on
replace the color wheel p/n 938P137010 MODULE-COLOR-WHEEL
Aug 22, 2009 | Mitsubishi WD-60735 Projection Television
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
1,229 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
