Question about Olympus FE-340 Digital Camera
My FE -340 Olympus camera will not completely turn on and when it tries to the lens doesn't come on and the screen stays blank.
  • 10,515 Answers
This is a common problem. There is a fault within the lens mechanism. The lens error is common for cameras with telescoping lenses.
  • You can help the motor by connecting the AV cable --- this keeps the LCD off and not draw power away from the motor.
  • Remove the batteries and insert freshly charged batteries.
Few more tricks that you could use :-
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #5a: If you actually do notice sand particles stuck in the gaps around the lens barrel, and blowing air does not help to dislodge them, consider using a thin piece of paper or a sewing needle to help dislodge them. Pay particular care not to scratch your lens barrel with the needle. Also, I do not recommend probing too deeply around the lens barrel with the paper (don't go more than a 1 cm or 1/2 in) . Particularly I do not recommend probing deeply around the most outer (largest) lens barrel gap, as you may dislodge the lens barrel dust gasket that's located just inside of that gap.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some obvious potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #6a: This is a variation of Fix #6, and should be tried if the lens barrels appears straight (not crooked). In other words, try this if there's no obvious mechanical damage to the lens barrels that's causing the problem. With the lens pointed down, try "gently" tapping around the lens barrels with a small item such as a pencil or a teaspoon. The idea is to try to dislodge any sand particles that may be jamming the lens barrel stuck. Simultaneously try turning the camera on and off as you're doing this.
Fix #7: The most extreme of the fixes. You especially might consider this if the lens barrel appears obviously damaged, bent, or crooked such as from a fall. Try forcing the lens. More people have reported success with this method than with any of the other methods (see the polls in the right column). HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
More tricks :-
Try compressed air. With a fine tip blow off gun and dry compressed air (20 lbs) set the tip between the lens turret and the camera body and turn on the air while moving the tip around the lens. It should remove all dust and sand. Turn the camera on and it should function fine.
Another method is to tap the padded USB cover part on a hard surface, for example, a desk. It sounds so simple, but very often in works.
Try forcing the camera lens:
Turn off the camera. Place it on the back with the lens facing up and take a look at the spacing between the lens and the lens housing. If you notice that the gap is not even all the way around the lens, the problem should be easy to fix. This type of a problem usually occurs if the camera was dropped while the lens was extended.
Simply - VERY GENTLY - press down the lens on the side where the gap is the biggest. You should hear a "click" as it pops back into place. Try powering the camera back on.
If the lens doesn't extend at all or it extends, and then retracts again, do the following. Turn the camera off. Take the camera in one hand and with the other gently take one part of the lens and gently move it round in a circular movement. Do so with both sections of the lens. You will hear a "click" as it pops back in place. Power the camera on.
Another version of this fix would be to pull and twist on the largest ring of the lens while turning the camera on. Listen for a "click". If at first the focus seems to be off, turn the camera on and off and take lots of pictures, close ups and distance. Focus should slowly start improving.
Unfortunately, there is no one good trick. This is a common problem and you could try to use any of the above tricks that you could find it comfortable to use.
The best advise would be to contact the manufacturer and get the camera replaced/repaired if under warranty.If out of warranty and the above tricks would not work, repair is usually not advisable as the cost of repair would be high as compared to the cost of the camera.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on May 18, 2011
  • 43,501 Answers
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
Why does the screen stay black when camera is turned on?
Did you try to press the display button several times? Most of the time you can cycle through different views on the display, with different information during record mode. One is display off.
Jun 18, 2014 | Olympus FE-340 Digital Camera
My Olympus FE 340 Camera firmware is crashed.Hardware is ok.Menu functions are OK.but when Im taking photo Screen is only dark black and shoting photos are same.I cant upgrade the firmware as My camera has...
I have a similar problem in the same camera: all hardware is ok but it doesn't focus. I've taked out the focus motor and it works, and all the pieces works too, they're not damaged, in fact wth the motor out I can focus manualy the picture. So I think it could be a firmware problem, but the OLYMPUS software doesn't leave me to write the same version of firmware, and there's no new versions, so is there any way to rewrite the same version of fw????? any service program?
Aug 26, 2011 | Olympus FE-340 Digital Camera
The cameral lens, on my Olympus FE-340 goes in and out and then turns off when i'm trying to turn it on. ONLY 2 years old!!!
i hv the same problem the lens goes in and out...my frens gurl has one n its the same problem....its a nice camera but it worthless
May 07, 2010 | Olympus FE-340 Digital Camera
Power on olympus camera
Do you experience low battery? Have you tried using brand new and fully charged rechargeable batteries like NiMH or NiCd?
May 06, 2010 | Olympus FE-340 Digital Camera
Fix sand in camera (olympus)
Hi there its happens when the lens not ready for work. Some how its not able tostable his focus method. That's why its stuck. There is a chances of lens guide pin disturbed or damaged & thats why continues buzzing. Its mean he inform you there
is a system error. So please visit the service center for repair that. Its a very common & repairable problem. Thanks.
Apr 05, 2010 | Olympus FE-340 Digital Camera
My FE 340 Olympus Camera tries to turn on, but can't. Lens goes in and out several times then shuts off completely. Battery is fully charged.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 19, 2010 | Olympus FE-340 Digital Camera
Olympia fe-340 won't fully turn on
You have a bad lens, you should take into a camera repair shop. The only other thing that can be possible is the cable from the lens to the camera man board may have not be making proper contact.
Jul 02, 2009 | Olympus FE-340 Digital Camera
Fe-340 wont turn on
If the lens is stuck out, that either means impact or it got squished and messed up the lens mechanism. You can have that repaired.
Apr 20, 2009 | Olympus FE-340 Digital Camera
Olympus fe-340 doesnt stay on
go get duracell rechargeble the green one digital camera need powerfull battery let me khow
Dec 29, 2008 | Olympus FE-230 Digital Camera
Olympus FE-340 Digital Camera Logo
345 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
