Question about Simer 1/6 Hp Submersible Utility Pump
My utility pump hums but the impeller doesn't turn,if I turn the impeller by hand it sometimes will turn.Can this be repaired?
  • 731 Answers
Probably easier and cheaper to just replace the pump
Posted on May 18, 2011
Great lakes hot tub humming sound
You either have a locked pump, impeller or stripped impeller on the pump shaft. Remove the jet pump assy and repair the pump and or impeller. You can also replace the pump assy.
Apr 30, 2014 | Holmes Products HM495-UC Humidifier
Waterfall pump hums but won't pump
this sure sounds if the impeller is blocked and not being able to turn ,Dont let it run this way , can dammage motor of pump , remove intake cover (unplugged) and wash out with garden hose real well , see if impeller (black plastic blade) can turn with your finger (unplugged) , should move easy ! this might be an indacation of need for a filter on pump inlet !!!
Oct 14, 2012 | Little Giant Submersible Fountain Pump
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Dishwasher will not drain
Hello there and welcome to fixya
Please check the following carefully
Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Oct 05, 2011 | Neff 24 in. S5409X0 Built-in Dishwasher
When I turned my pump off to backwash and then turned it back on it made a humming noise then stopped running. Now it is doing nothing. what could the problem be?
sounds like a bad start capacitor, or there is something (rock, sand, or some debris) caught in the impeller.
The start capacitor not working will cause your motor to hum, then it will overheat and trip the high limit. It won't attempt to come back on until it has cooled. It's a common problem.
try clearing the impeller first, if that doesn't work and the motor shaft spins freely, then it's a capacitor.
Jul 27, 2011 | Hayward Power Flo Lx
Hello. after washing water still inside of machine. MAYTAG QUIET SERIES 300.
Hello there and thank you for choosing fixya
Drain line/air gap
Pump
Belt
Motor
Timer
Jun 29, 2011 | Maytag Dishwasher
Impeller won't turn after long winter.
TAKE THE SS BAND OFF PULL PUMP MOTOR BACK FROM PLUMBING , TAKE DIFFUSER OFF AND GENTLY TURN IMPELLER BACK AND FORTH. IF THIS DOESN'T WORK HAVE A PRO DO IT !! HERE IS A LINK ON HOW TO REMOVE YOUR AND OTHER TYPES OF PUMPS CLICK HERE
VOTE YES IF I WAS OF HELP THNX JAY THE POOL PUMP REPAIR GUY IN SUNNY FLORIDA
May 29, 2011 | Sta Rite Sta - Rite Dyna - Glas Pool Pump...
Motor hums, but does not start..
turn off power open access panel and check pump close water valves to pump and disconnect lines ckeck pump for debris that may be stuck in pump blocking impeller if clear than lube motor bearings and try moving impeller back and forth to free motor once free return and test pump
Apr 18, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
The pump lost vaccum, now the motor shut off and pump only hums.
Prime the pump. If it still just hums, try to turn the impeller. If the impeller is not jammed, and the motor hums or it doesn't start at all, the motor may be bad. Check for correct voltage of the incoming power wires inside the motor connection housing. Sometimes turning the circuit breaker off, then back on will fix it.
Jan 15, 2009 | Garden
Simer 1/6 Hp Submersible Utility Pump Logo
415 people viewed this question
Top Simer Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Simer Garden Expert? Answer questions, earn points and help others
