Question about Grilling
Grill does not heat up beyond 300. Gas coming through on all burners but the flame is very low even with a new propane tank.
  • 43,501 Answers
Your problem could be or probably is with the regulator...not enough gaspressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Posted on May 18, 2011
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
I'm aving a low flame issue. I replaced the burneres and heat shields a couple of months ago, worked great for a while, but now the flame on all 4 burners is low. When the heat is turned down to half...
If you're turning off your propane tank after each use (which is fine), you will need to turn it back on very, very slowly. The new OPD valves that are now required on all portable propane tanks, will lock up the regulator if it's turned on to fast. Also, check all the pilot orifices for clogs. And finally, be sure you have enough gas in the tank.
Jan 19, 2011 | Barbeques Galore Turbo STS 4-Burner with...
When we light the grill the burners only have a low flame. We can't turn it up to a high enough flame.
Hopefully this will fix you up. Follow exactly.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
  10. Your grill should now heat normally
Nov 06, 2010 | Weber Genesis Silver B Grill
My flame is very low when lite and grill will not get beyond 200 degrees. This happens intermittingly.
It is most likely the propane regulator. If it is under a year old the company should replace it for free. (The regulator is located on the gas line and is a round metal object near the propane tank.)
Jul 02, 2010 | Barbeques Galore Capt'n Cook 4-Burner (NG)...
New webber will not start
Ok, let's tackle the obvious things first. New grill with new tank... so was the tank filled? Did they purge it before they filled it? Did you turn the tank valve on very slowly? Were all the grill knobs turned to off when you turned on the gas tank? Try closing the propane tank valve, disconnecting it and reconnecting it. Then very slowly turn it on and light one burner at a time at turn to low heat. Then light additional burners the same way and adjust flame as needed after all are lit. Hope this helps! Douglas
Jun 06, 2010 | Weber Summit S-470 Propane Grill
When I light my grill only one side of the burner has a flame, on all 3 burners. I cleaned everything and even cleaned each hole in the burners. What's next?
This is a common problem with grills purchased after 2001. There is a new safety feature inside the regulator called a 'surge protector'. If you open your propane bottle valve too quickly or if you try attaching a tank with the tank valve in the 'open' position, the propane wants to 'surge' into the grill.
When the propane surges into the regulator (located on the grill hose) the 'surge protector' (inside the regulator) kicks on. When this happens you will not be able to get your grill lit, and if you do, it will be a small blue flame and the grill will not heat up.
So what to do if you trip the surge protector and can't get your grill to light or heat up?
Shut the tank off and shut the valves on the grill off. Disconnect the tank from the grill hose. When you disconnect the tank from the hose you will hear the excess pressure of propane release. This is an indication that you have re-set the regulator's surge protector.
Now that you have deactivated or reset the surge protector, reconnect the tank. Make sure the valve on the tank and the valves on the grill are in the closed and in the off position. After you reconnect the tank to the hose, SLOWLY open the tank valve (making sure the valves on the grill are in the OFF position).
Since you have slowly opened the valve on the tank, the propane did not surge into the regulator and the surge protector did not activate.
Now open 1 valve on the grill and light it. You should get a nice flame. If your grill has more than one valve, open each following valve in sequential order to extend the flames to the other burners.
Thanks for reading and I hope this helps.
Ben Gaetani
Tanks 2 You Propane
propanetanks2you.com
Tanks2youpropane@gmail.com
Mar 02, 2010 | Grilling
The flame coming out of the burner bars is small
May likely be low on propane or propane tank gate valve not opened far enough. Otherwise sounds like faulty regulator.
Jan 16, 2010 | Weber Genesis Silver A Grill
Genesis s310 stainless grill. Does not fully light.
Regulator is not bad, as I stated before new valves are designed to reduce gas flow if valve is opened to fast. This is so if grill catches on fire, the tank will shut itself off, thus propane will stop flowing causing fire to extinguish itself.
Dec 28, 2009 | Weber Genesis E-310 Gas Grill
Grilling Logo
129 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
