Question about Car Audio & Video
Midland Alan 40 fm/am , Tranmission is intermittant,will only transmitt when is warm,Reception can sometimes fade away then no transmission.But does transmitt clearly,have tested 10 pin audio amp, pin 2 reads 1.8,have tested large eletro capacitors all ok , sure hope you can help me make this set breath again for me,hope to get next time im on-line.With respect. ali
  • 5 more comments
  • aligtop May 19, 2011
    Yea ok, i gotta get a can of that freeze spray tomorrow,would it be possible to be the 10 pin amp working bang-bang .
    Thanks again Talk tomorrow.
  • aligtop May 23, 2011
    Hello again, No i now cannot get the set to transmit at all,not sure if it's recieveing or not.what does it sound like to you ?
  • aligtop May 24, 2011
    Midland 40 chan am/fm, im not getting any transmission.It was working intermittingly both recieveing/trans but now i cant transmit.
    Have checked all main drive transistors,ok.all large electro capacitors checked,ok. mikeraphone checked,ok.Hope you can help me.cheers.
  • aligtop May 25, 2011
    Thanks Tony,wll get on that,an get back to you,.....Cheers
    Hello again,hear is the latest on the cb.
    press the mic an Transmit,then recieveing reception is poor, turn set off/on reception back to normal.
    PA done 2 tests,,just to make sure,On( local Mode) set, nothing,put on DX mode on the mic, blows your mind away with a Deafing squell/pitch
    Microphone Is changeing chans, locks / unlocks , push button on mic tight , ok inside i checked it past ,i still cant get a grip on this one T, why it's this way, is'nt true that transmission goes through the 10 pin Audio Amp.? Have a think on it ,an get back to me, will chat soon.
    Thanks again Tony
    aligtop
    hiya bob, took the mic appart everything inside was tight, clean , good con,but as you say some mic's receive an transmit .
    Big respects to you bob, will let you know the outcome.
    aligtop
  • aligtop Sep 07, 2011
    got your email, thanks man,wil try out,got a wharfedale lcd26 hdm tv at the mo,an it's not showing any led light when you plug in turn on,done some testing an found that im not getting a reading of continuity in one transformer of 4.can you advise,is it common ? respect to you , cheers.
    Guru:
  • 1,833 Answers
You can try few things.
1. Add a longer and powerful antenna.
2. Open your transmitter. Please change the coil that is on the ferrite core.
3. Use new batteries.
4. Change the signal amplifier with a low noise high gain pre-apm.
This will solve your problem.
Posted on Sep 05, 2011
  • 10,319 Answers
The outputs in the circuitry are getting weak causing the unit to fade in and out
It will need to be serviced most likely with a new board
Posted on Sep 14, 2011
    Sergeant:
  • 405 Answers
HI.If you receiveD low frequency signal you may as well replace the crystal accesory to 10.7 mhrtz value.it has color brown. You may as well try to bring the equipment to a higher terrain.place wherein it recieves maximum frequency signal.This is a frequency signal capable in receiving frequency signal.Try to open the unit then replace that accessory that has color brown since this crystal will responsible on receiving maximum frequency.Hope this idea helps.
Posted on Jul 20, 2011
  • 998 Answers
Try to check the resistors beside your 10 pin audio amp and driver transistors.
Posted on Jun 27, 2011
  • 12,061 Answers
OK well what we do is warm the set up, and using a stuff called "Freeze Spray" we spray individual suspected components now the one that stops,or causes an obvious problem, is the one that's most likely faulty or involved, and stopping it from working, usually this is the culprit and replacement usually fixes it.
It also maybe a bad solder joint? So i t always pays to give all suspect or "Funny" looking solder joints a quick, "Lick of the iron" and reflow those joints again just to be sure...
Things that get hot, are usually the output semiconductors, ,aim audio amp, and power regulator and pass components so check here too.
As usual always start and check that the power supply voltages are all correct as if they aren't well nothing else can be? Check all Electro Caps, Vregs, Zeners, and output semis...
Posted on Jun 17, 2011
  • 517 Answers
Good day!
If your machine OK when its warm,,
the solution I suggest is to re-solder all parts using soldering iron and soldering lead..
after that try to test it by powering it on again..
thank you and don't forget to rate my answer..
If you have follow up question or comments Just click (add a comment)
Posted on Jun 09, 2011
    Genius:
  • 1,112 Answers
Hi:
Usually when units tend to operate when it gets warm, this is an indication of a thermal intermittent problem, usually common to poor or cold solder joints on an IC in the unit, I suggest you check all solder connections especially around any large Ic's mounted on the circuit boards and the power supply area.
Posted on May 27, 2011
    Master:
  • 448 Answers
Have you checked the mic at the connection to the radio some units need the mic to
transmit and receive if the connection is bad that might be giving you the problem
hope this helps you
bob
Posted on May 25, 2011
  • robert DIBBLE
    robert DIBBLE May 26, 2011
    other than what i said i cant think of any thing else
  • 3,018 Answers
  • Sounds to me like your finals may be blown or the voice chip.
  • Plug an external speaker into the external jack in the back and key the mic. Can you hear your voice? Then the voice chip is good. If not the voice chip is bad.
  • If voice chip checks out then I would replace the final transistor.
  • Make sure to check the mic and if you can confirm with a spare that it is functioning properly. A bad mic can mess things up a bit too.
Regards, Tony
  • Iron
    Iron May 25, 2011
    Sounds good.
    Regards,
    Tony
  • Car Audio & ... Master
  • 16,194 Answers
IF you are having a fade problem and intermittent issues that appear to be related to heat, Get a can of freeze spray and have it till you find the component that shows reaction to the freeze.
Posted on May 19, 2011
The FM function starts off great but loses reception after a couple of minutes and now the AM function has so much static you can not hear
AM FM TV Reception Guide and Directory » FM Reception ...
www.amfmreception.com/fm-radio/fm-reception-guide
Coax is a source of loss of signal from the FM antenna to the FM receiver and can also .... I believe the FM sound quality would strictly be a function of the tuner when ...It picks up the least off the side, but it does pick up some of the side. ...... THE ELECTRONICS so as not to short anything or to start the Great Chicago Fire of ...Missing: video
How to Avoid Distortion in Audio/Video Transmitters ' eBay
www.ebay.com > ... > Audio/Video Transmitters
An audio / video transmitter, or AV transmitter, is a wireless device that sends audioand ... As with all wireless signals, one can experience distortion or signal loss. ... AV signals are usually transmitted via wideband FM (frequency modulation) ... that of indoor transmitters, but the range drops off significantly the moment an ...
Jan 17, 2016 | Audio Players & Recorders
Wont pick up fm
Deploy the antenna, and orient it. Keep the radio away from electric appliances such fridges, and electric machines. Put the radio on a window sill or close to a window. If a building blocks the line of sight between radio and transmitter reception may be affected.
Dec 10, 2013 | Dewalt DC011 AM/FM Radio
Fm radio works fine but the dab will not find any stations, I have tried different aerials and still no good
What's the make & model of the radio?
Most DAB/FM radios work from the same antenna, so if you receive FM stations, you should receive DAB stations in your area.
It should be noted that DAB transmitters work on lower power than conventional FM transmitters, and so you may be in a weak reception area (for DAB). It should also be noted that DAB uses different frequencies than regular FM stations and household appliances such as laptops,WiFi, microwave ovens, etc can affect DAb reception.
Nov 18, 2013 | Audio Players & Recorders
How can I get my midland 9001z from AM to FM
Hi Trevor,
The Midland radio you have is NOT capable of FM transmit & receive. It is a Citizen's Band radio that operates on channels 1 thru 40 that are assigned to the 26.965-27.405 MHz frequency range. These are the standard 40 Ch CB frequencies in the U.S. (and may not be legal for use in other parts of the world without a license from your country's communications authorities). It also offers Weather Band reception - again these are US frequencies that may or may not even be used at all in the UK. Since the radio only displays a channel number, you don't actually know the frequency you're monitoring or transmitting on. Your friends on CH 5 may be in a completely different band.
Even if they are on the same frequency, the fact that they are operating in FM mode means that you would hear something - but it may not be intelligible - and the same would be for them listening to you transmit in AM mode. If you could have them switch their radio to AM, all would be fine. I suspect they use FM as there is much less static when compared to AM.
If they won't change to FM, you'll either have to stop trying to talk to them or buy a radio capable of FM (and make sure it has the same frequencies as theirs!).
Feb 08, 2013 | MIDLAND-2 WAY RADIOS New - Midland 9001z...
How do you ground the chassis on a midland 75-822 hand held on a motorcycle
Try a inline capacitor to clean up the power coming to the cb while the engine is running at higher speeds
Aug 16, 2012 | Midland Radio 75-822 - 40-Channel...
I have an almost new Midland 75-822 that the WX works fine on, but the CB doesn't seem to receive, or transmit. It operates normally, but no reception, and no evidence of transmissions.
you'll need a schematic and some knowledge. there a two diodes that control the rx and two that control the dx.Check them to make sure they are producing the correct power out put if they are not you should replace all 4
May 10, 2012 | Midland 75-822 40-Channels Handheld CB...
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
Midland 75-822 no transmission in FM? why?
there is no transmission on FM because CB is at 26 to 27Mhz on the AM Band and as with your car radio FM starts around 88Mhz. the other reason is tha one one modulates amplatude(AM) slightly to cary the signal, FM modulates the frequincy slightly to carry the transmission.
if you want to talk on FM you might want to become a Amateur "Ham" Radio Operator.
Nov 03, 2010 | Midland 75-822 40-Channels Handheld CB...
My alan 48 plus cb dont seem to change to uk how do u change this thanks
the first button on the right hand side changes the fm to am but these usually break down. it is a small push button switch with four legs two at each side, but recomend sending it in for repair.
Aug 17, 2010 | Midland 1001Z 40-Channels Base CB Radio
My midland allen 78+ uk channel has changed to am it should be fm
I Italy 40 Ch AM/FM 4 Watts I2 Italy 34 Ch AM/FM 4 Watts D Germany 80 Ch FM 4Watts/ 12 Ch Am 1 Watt D2 Germany 40 Ch FM 4 Watts/ 12 Ch AM 1 Watt D3 Germany 80 Ch FM 4 Watts/ 40 Ch AM 1 Watt EU Europe 40 Ch FM 4 Watts / 40 Ch AM 1Watt EC CEPT 40 Ch FM 4 Watts E Spain 40 Ch AM/FM 4 Watts F France 40 Ch FM 4 Watts / 40 Ch AM 1 Watt UKE UK 40 Ch Fm 4 Watts UK frequencies UKC UK 40 Ch Fm 4 Watts CEPT frequencies PL Poland 40 Ch FM/AM 4 Watts midland alan 78 multi plus frequencies
Jun 06, 2009 | Midland 1001Z 40-Channels Base CB Radio
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
