Question about Toro Garden
Hi, I have a toro 20676 lawn mower that is in great condition from circa 1985. Looks almost new. I am trying to figure out how to charge the battery. The battery has a single plug connector that has both positive and neg wires in the same plug. The battery has number 1365W stamped on it. I would love to get this mower working again. Thanks, Brian
  • 77 Answers
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
Posted on Aug 12, 2009
SOURCE: Toro lawn mower engine starts and then stops after 2 to 3 seconds
i had this problem and the nut was plugged. After i cleaned the nut, it ran perfect.
Thank you very much!
Posted on Aug 23, 2009
  • 88 Answers
SOURCE: no spark from spark plug in honda lawn mower
the pionts could be bad try changing them
Posted on Aug 30, 2009
rwvanlue
  • 486 Answers
SOURCE: Stuck pull cord on Toro 6.5 self-propelled mower
1) Common problem when a mower sits for several weeks at a time between mowing;
check for extra grass debris to be glogged between the blade and the mower shell.
2) If the mower has a 'bail' or 'zone' control handle;
this releases a brake mechanism on the flywheel to allow it to rotate, and after it is running, releasing the lever will 'kill' the engine.
NOTE* when transporting a push mower in the trunk of a car, try to keep the mower as level as possible.
*extra note when mower has been transported in the back of a car;
sometimes the mower is placed in a trunk at such a severe angle that the oil from the crankcase is forced around the rings and sits on top of the piston so that when you try to pull the rope you have a 'hydra' lock. (that is when a liquid is between the piston and the spark plug) You cannot compress a liquid, so the rope appears stuck.
If this happens, remove the spark plug (make sure the loose plug wire is fastened away from any combustable that comes out of the spark plug hole *** AND THERE WILL BE A HUGE STREAM OF OIL AND GASOLINE, SO BE PREPARED TO CLEAN UP A MESS ***
pull as normal until fluid is dispelled from internal engine
clean or replace the spark plug
a few more pulls (no choke required) and you are up and going
Posted on Nov 08, 2009
SOURCE: Our Toro Personal pacer Model 20031 lawn mower will not start;
i turn the key and it grinds
Posted on Dec 06, 2009
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
TORO LX 425 MOWER - STARTS AUTOMATICALLY
by trying to start it so many times sounds like you blew the fuse. your problem sounds like it started with a bad solenoid.take it off and test. if it is bad replace it. put a new fuse in and it should start as it is supposed to.
Mar 08, 2017 | Toro Lawn Mower With Toro Power Tools
Need to know where to look on my mower to find out what info I need to find a new belt for my Toro SR4 Super Recycler.
I believe you will need belt Toro part # 91-2258 Try Partstree.com or call 1-877-798-7278 they are great to work with and can guide you to id your mower and get you the right part.
Jul 05, 2012 | Toro Power Lawn Mower
When i try to start the riding mower will only crank once.....toro 16-hxl will crank once, then nothing
Make sure your battery is in good condition first. Then if your machine is an OHV you might want check the intake and exhaust clearance. Go to smalleng.com and watch video they have a great tutorial on this subject. Good Luck...
Sep 26, 2011 | Toro Lawn Mower With Toro Power Tools
Toro lawn tractor
There is a switch on the seat and one on the brake pedal
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
97 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
