Question about Maytag Neptune MDG5500AW Gas Dryer
I just relocate my gas dryer but cannot get it to work. It's getting power but doesn't do anything. It is a MDG500AWW Gas.
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 18, 2011
I have a GE DCVH660GH0BB gas dryer.That doesn't heat or sometimes heats for a short while then stops heating.
You will need to check the thermostats on the blower housing for continuity.
Nov 23, 2012 | Dryers
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
I looked through the peep hole in front of my gas dryer and I don't see anything lit.Dryer spins great, but doesn't heat up. What is the problem?
Igniter - The dryer's igniter is what ignites the gas that has entereddryer-ignitor.jpg through the gas valve. It will glow red, then when it reaches a certain temperature, it will trigger a thermostat that opens up the gas valve and that's when the dryer starts to heat the air. If the igniter has failed, the motor will still run but not produce any heat.
Jan 31, 2012 | Whirlpool Dryers
My Legacy Series gas dryer only gets hot intermittently - sometimes it works sometimes it doesn't :(
A very typical problem with gas dryers is a weak coild that open the gas valve...this tip i wrote goes into more detail about why your gas dryer works intermintely
http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
GENE
Sep 06, 2011 | Maytag Dryers
It runs but doesn't heat up
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 28, 2011 | Whirlpool Dryers
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
heatman101';
Aug 11, 2011 | Dryers
Dryer doesn't get hot
heatman101
Jul 13, 2011 | GE Dryers
I have a Kenmore gas dryer model 110.77670400. The ignitor lights, but gas valve doesn't open. I tested thermal switches in back for continuity and all checked good. Flame sensor is good and I replaced...
Thank you for contacting fixya.com.
If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer.
Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them.
Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires.
Please get back to us if you have further query else please accept the suggestion.
Jun 15, 2011 | Dryers
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
54 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
