Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
How do I remove and replace the water filter in my side by side?
    Problem Solver:
  • 5 Answers
I'm not familiar with this particular model, but often they are an 'in-line' cylindrical cartridge type of filter on the end of the mains water supply to the Fridge/freezer - pull the cabinet out from the wall and look behind to see if you can find one.
Posted on May 18, 2011
On my Frigidaire Gallery side by side refrigerator, my filter keeps popping out. When it is engaged, I get water but no ice.
replacement water filter keeps popping out of fridge - Shop ...
www.shopyourway.com > Manage My Life > Questions
Kenmore fridge water filter replacement #9911 looks a little different than the last one and pops out after a few minutes of installation ... How do I fix my Kenmore water filterthat keeps popping out? ... Side-by-Side Refrigerator - Stainless Steel.Missing: gallery
Frigidaire Pure Source 2 water filter keeps popping out. - Fixya
www.fixya.com/support/t2000027-frigidaire_pure_source_2_water_filter
... filter keeps popping out. I am posting this again because there were no responses to - Refrigerators question. ... I am trying to replace my water filter with a newFrigidaire Pure Source 2. I have a side by side Frigidaire. I removed the old ... When I press the water lever the Pure Source 2 filter pops out. I called Frigidaire and ...
Dec 26, 2015 | Frigidaire Refrigerators
Where is the water filter on my whirlpool model gx2fhdxvy09
Water Filtration System
The water filter is located in the upper right-hand corner of the
refrigerator compartment.
Do not use with water that is microbiologically unsafe or
of unknown quality without adequate disinfection before
or after the system. Systems certified for cyst reduction
may be used on disinfected waters that may contain
filterable cysts.
IMPORTANT: The disposable water filter should be replaced at
least every 6 months. If the water flow to the water dispenser or
ice maker decreases noticeably before 6 months have passed,
replace the water filter more often.
Replacing the Water Filter
To purchase replacement water filters, model UKF8001AXX-750
or model UKF8001AXX-200, contact your dealer or call
1-800-253-1301 U.S.A. or 1-800-807-6777 Canada.
IMPORTANT: Air trapped in the water system may cause water
and filter to eject. Always dispense water for at least 2 minutes
before removing the filter or blue bypass cap.
1. Turn filter counterclockwise to remove.
2. Remove sealing label from replacement filter and insert the
filter end into the filter head.
3. Turn the filter clockwise until it stops. Snap the filter cover
closed.
4. Flush the water system. See "Water and Ice Dispenser(s)."
NOTE: The dispenser feature may be used without a water filter
installed. Your water will not be filtered. If this option is chosen,
replace the filter with the blue bypass cap.
User Manual=> HERE I am here should you need me, Thanks John Tripp Appliance 911
Apr 16, 2014 | Admiral 26 cu. ft. Side-By-Side...
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
Jan 26, 2011 | GE Refrigerators
Putting in the new water filter to the Whirlpool gold fridge that goes in at the bottom.
Removing a water filter from the base grill of your Whirlpool brand refrigerator:
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 06, 2010 | Whirlpool GD5DHAXVY Stainless Steel Side...
Side by side refrig - ice maker and water don't work after replacing the filters. is there a re-set?
Removing a water filter from the inside of your Frigidaire brand refrigerator:
Removing and replacing a water filter - upper right hand corner inside location
Filters situated up front in the refrigerator compartment of Frigidaire-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Open the door of the refrigerator compartment of your Frigidaire brand side-by-side refrigerator. The filter is located in the upper right hand corner. It has a push button for quick release just to the right of the filter.
  2. Locate the icemaker On/Off power switch and place it in the OFF (o) position.
  3. Push in on the filter release button and pull the filter all the way out to remove it. Remove new filter from its packaging and remove the protective plastic caps. Insert the new filter in the same manner it was removed. Make sure to push in firmly on the filter until you hear the filter cartridge click in place.
  4. Return the icemaker's power switch to the On (l) position.
  5. Condition the filter by running water through the dispenser for about three minutes. This will flush the filter of all fine carbon particles.
  6. In some models, you will have to reset the filter status light. It is located on the ice and water dispenser control panel. Push in on it for ten to fifteen seconds until the green, red, and amber lights flash. If your refrigerator model does not have a filter status light, you should make a note on a calendar, or place a month sticker on your filter to remind you to replace the filter again in six month's time.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator or shut off the water supply when replacing it. Also, this filter should be replaced every six months.
Oct 31, 2010 | Electrolux 25.9 Cu. Ft. Side-by-Side...
How do u replace water filter on samsung refrigerator side by side model number rs2630sh
The water filter in the extra space behind the vegetable Bin.
1) As shown, the fixed cap separates from the refrigerator by rotating
it counterclockwise.
Remove the water filter from the box and put a month indicator
sticker on the filter as shown on the next page.
2) The water filter should be replaced every six months, so if the filter
was installed in March (for example), put on the "SEP" sticker
to remind you to change the filter.
3) Remove the protective cap, then position and insert the
filter as shown.
4) Slowly turn the water filter clockwise 90º to align
the indication mark on the cover, locking the filter in position.
Or go here bottom of page 24 top of 25.
http://www.azmanual.com/download/21949/5478c9cd79f4e04b6a2f6e2b4ab9f513/
Please rate 4 thumba for the free answer.
Mar 08, 2010 | Samsung RS2630WW Side by Side Refrigerator
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Removing the water filter and not replacing
Not with out re plumbing the unit underneath, it would be much easier to leave it in place.
Jan 02, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leaking water and replace filter light not resetting after filter replacement
are you sure that the filter is installed corectly
remove the filter and reinstall it to be sure
May 11, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
50 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
