Question about Dewalt Drills
Model DWD110 While using to drive 2 1/2 inch deck screws the drill was operating normal. After loading another screw to drive, the drill would not energise. It was as if the cord had come unplugged, which it hadn't. Any ideas???
    Problem Solver:
  • 15 Answers
It's possible that you fried it somehow, or you tripped a fuse on the line you are using to power it. Try plugging it into another outlet.
Posted on May 19, 2011
Why does my drill chuck seem to disconnect from the motor?
from pos 32 gear and the drive shaft on the armature can be worm out. or something was broken else.
Detail
Jul 23, 2014 | Dewalt DW505K 1/2" Hammer Drill
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
I have an 18volt Dewalt XRP 1/2 inch drill. The drill has been working perfectly up until this morning when I took it froms its case. I was using it the evening before to screw in some 2 inch screws into...
Check electrical contacts in drill body where battery connects. Check wiring inside the drill, trigger and check also brushes. You do not have to invest 329, you can buy "body only" machine for few bucks and reuse your charger and battery packs. Juraj
Oct 20, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
I am having problems getting the screw to screw all the way into the E-Z ANCOR. The plastic E-Z ANCOR screwed in quite easily and is snug up against the dry wall, but the metal screw is not easily screwed...
There are many different models of these drywall anchors, some of which will not allow a too-long screw to be used. But the plastic ones shouldn't have this problem, because the tip (inside the wall) is supposed to split apart. However, you have to drive the screw a bit harder when you get to the point where the plastic starts to split. Do a google image search for---- ez anchor self drilling drywall ---- to see a few useful images.
Aug 09, 2010 | Midwest E-Z Ancor Self-Drilling Drywall...
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
SKIL 18V BATTERY PACK
There are three visble screws and one hidden. Use the right size torx driver if you have it, or a small allen wrench works too and undo the screw that is visble on one side of the pack. Snap the false bottom off of the pack and reveal two more screws to remove. One screw is behid a plastic cap over a fourth obvious screw location. Drill the cap and unscre this screw also. Be sure there are no lables holding the two side together. Pressing down on the battery holdin clasp makes the sides easier to separate. Watch for falling parts. That's it!
Nov 28, 2008 | Skil 2887 05 18 Volt 2 Speed 3/8 Inch...
It doesn't run even with a charged battery pack.
dear T,     The problem here is not your driver, but what you are asking it to do.  A good rule of thumb for carpentry jobs is "Always use the right tool for the job!" I work in the carpentry shop at the metropolitan opera in New York.  We use 14.4v and 18v cordless driver drills only.  However, you should know that cordless tools are to be used for small, short jobs.  Once you subject a cordless tool to constant, repetitive tasks that require lots of power, the tool will suffer performance problems and may fail.  Your broken bit indicates that you are expecting this tool to do more work than it can handle.    When driving long (2-1/2" or longer) screws into very hard (most decks are made of pressure treated lumber at least 1" thick) material, the proper tool is a corded drill.  This tool is made to deliver constant force for long service cycles.   When driving screws over 2" into hard woods or other dense material, any cordless drill is only good for less than 6 cycles of use.  A 12 volt battery will give out after several drive cycles under this type of demand.    Unfortunately I think you have depleted your batteries life expectancy.  Most Ni-Cd batteries will only last 1 to 2 years under normal wear.  I think your batteries will need replacement or repair.  Good Ni-Cd repair centers are hard to find, but with determination and persistence, you may find a battery recycler who will replace the cells in your batteries for a fee of about 1/2 the cost of new batteries.  DeWalt batteries are not cheap, so you will have to determine your best choice.  To drive several screws into your deck, I would recommend a corded drill.  It will stand up better under the demand.      As for broken bits, heavy use will always take a toll on your bits.  They will break less if they fit the fastener perfectly.   Also care must be taken to drive the fasteners in perfectly straight, perpendicular to the work surface.    Remember the adage, "Always use the right tool for the job!".  Take one of the fasteners with you when you but new driver bits.  Check for the best fit to the fastener you want to use.   For decades the standard drive bit has been the "phillips" bit.  At the Met we only use "Robertson" drive or square tip wood screws.  They cost more but slip less, and the bits rarely break. Always select a bit that best fits your fastener.    I hope this solution brings you success in your projects.  Best Regards,  Michael Mittelsdorf
Sep 23, 2008 | Dewalt DC727KA 3/8" 12v Cordless...
Using a bosch psr18 power drill
Hi, they usually list the torque to screw size ratio in the instruaction manual. If you cant locate yours many companies list their instruction manuals pn the web on their home page, or you can sneek a peak at a hard ware store on a similar drill.
The usually rule for small screws is torque 1-4 on small screws.
Otherwise practice makes perfect & different types of timber will affect when the torque kicks in.
I still believe that an impact driver is better than a drill with screws as it impacts the screw in & this gives you better control. It will actually slow the screw down & you can recess it just perfectly. The drawback is that it can snap small screws when driving into soft timber. (but you can always predrill)
cheers
Laurie
Sep 10, 2008 | Bosch Drills
Chuck won't tighten
The chuck is held onto the drive shaft via screw located inside the chuck. The screw has reverse threads and sometimes the screw gets loose restrictinhg the chuck tightening. Turn the chuck to loosen and tighten the screw as though you were removing a normal screw. Good luck
Feb 19, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
