Question about Audiovox Televison & Video
My flipdown DVD player in the car is having tracking trouble-get a series of horizontal lines that jump around screen, happens on both DVD and vhannel tuner. Thanks
  • 1,031 Answers
The lens need to be changed
Posted on Aug 14, 2008
    Master:
  • 521 Answers
Very common the loose wire in the unit check properly and connect it .it will work
  • 594 Answers
It sounds like you reception is getting crossed on the video input.
or you video input cable has worked it's self loose not getting a good connection. i would check that to start out with.
Power ON DVD, horizontal lines running on the TV screen. How do I get the horizontal lines to stop running and for me to view the screen to possible reset the DVD player.
Check video plugin to see if connect good on both tv and dvd player. You might try unplugging and re plug. If that doesn't help you might try another plug wire not sure if you have rca or HDMI plugs.
May 14, 2015 | Jwin Electronics JD-VD138 DVD Player
Directed 10.2
remove all the wires connected externally and then try as some of the wire has got loosed and not supporting the device to work properly.remove the wires and then reconnect it properly.
Oct 25, 2008 | Myron & Davis ADM169GY 7 Inch Flip Down...
Horizontal blue and black lines
Based on your information given maam, I can say that your LCD is not working well but sometimes it happens that there is a problem on its connection to circuit board..This is usually I encounter maam as a most experienced technician.Thanks.
Dec 23, 2011 | Mintek MDP-1770 7 in. Portable DVD Player...
Horizontal lines on screen.
Your unit may have a loose connection from motherboard to the display (video cable inside the unit), another distinct possibility is that the video processor chip is damaged or there is a power supply problem for the video chip (a bad electrolytic cap or similar somewhere around the video IC).
You can check the connection, but you'll need to take the unit apart, also check other connectors, but if it's an IC problem, this could get difficult or/and costly.
Please note that these are only suggestions and that the problem may as well be something else.
regards
3rq8 (Triarcuate)
Jul 23, 2009 | Audiovox D2010 Portable DVD Player with...
Jumping horizontal lines when connected to CD player
Hello, I want you to do a test first. Take you TV and connect a DVD player to it and see if this problem occurs. I bet you it wont, because the problem is not with the TV nor the CD of the karaoke machine. The problem is with the sync pulses of the signal from the karaoky, and the inability of the Tv to sync-up with those signals. What I would use is a video stabilizer between the TV and the DVD player. If the TV still has the problem with the DVD player I would then check the TV for a vertical section problem. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jan 28, 2009 | Sharp 13VT-K100 13 in. Combo
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
No power to ACT car video
Those player are very low price and quility, about $25 each. I would go with an indash touchscreen unit from Pioneer or Kenwood and send signal to the flipdown screen.
Mar 08, 2008 | Car Audio & Video
Insignia vehicle installed dvd player problem
You have a damaged LCD inverter board. The unit can now be used as a player only and you'll need to connect it to the A/V outs to see video clearly and without the lines.
Dec 23, 2007 | Insignia IS-PDVD10 Portable DVD Player
DVD recorder -- displays blue horizontal lines only
Most DVD players today are very inexpensive.
If your system is working well otherwise, I suggest purchasing a new DVD player. Try that solution. If for any reason it does not work then another problem may exist which may include an issue with your TV!
May 02, 2017 | Samsung DVD-R4000 DVD Recorder
Televison & Video Logo
61 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
