Question about Emerson LC320EM9 32 in. LCD HDTV
The sound echoes. Low echo compared to the regular volume. Drives me crazy. Tv is 2 mo old
  • 85 Answers
Use the warranty
Posted on May 18, 2011
My new Vizion tv has a vizion sound bar, the sound comes out with an echo, how do I correct?
Your TV speakers should be turned all the way down or off when you use a separate sound system such as a soundbar. Using them with the soundbar may cause echoes and the TV speakers do nothing to improve the sound.
Look at your TV's audio menu. If you can, turn the TV speakers off completely at the menu. Also see if you can set the analog audio output to "variable." This will allow you to control the soundbar's volume with the TV remote.
Jul 08, 2017 | Echo Computers & Internet
Why won't my echo 230 start, has good spark.
If you have been running Ethanol (regular gasoline) in the gas+oil mix, your problem sounds pretty common. I suspect your trimmer is a year old or more and probably not heavily used. I had the same problem after a year. Took it to a professional and they told me the carburetor was shot. Home Depot sells the Echo and they do not repair the machine. What happens is the ethanol in the gas attracts moisture, which shortens the life of these 2 cycle engines. New carburetor, $139.00 +labor. New decent trimmer, $139.00.
Aug 17, 2014 | Echo Garden
I just received my RSQ-echo 2000 karaoke machine. When I plug a mic into the front 2 mic inputs, they both have echo, even tho I turned off the echo volume in the back. I assumed that by turning it all...
The control supposedly controls the mix of the echo... this is a reverb type sound. Please note that room acoustics AND if the mic's "hear" the speaker in this, it may create an echo that is NOT under control of the adjustment. Make sure the mic's cannot "hear" the speaker or a reflection off a wall.
Aug 17, 2011 | RSQ NK 2000U
Lost instructions for my dav-hdx285 dvd home theatre sounds great when the dvd is used but when using sound from the tv sound is not nearly as loud and if i have the volume on the tv up it sounds like a...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-DAV-HDX285-Home-Theater-Systems-manual/id/23316bh343/t/2/
The TV and process the sound differently so the echo is a just a time smear. You shouldn't actually need to augment the HTS speakers with (ugh) TV speakers.
As far as comparative TV-sound loudness goes, if you drew it from the Cable Box to the audio system I'm sure it would be the same as your other audio. TV
Feb 21, 2011 | Sony Bravia DAVHDX285 Theater System
Hi, i've got an astatic mobile max echo chamber but the echo and echo volume controls are very faulty. The echo volume is just a normal potentionmeter but the echo control is more like a balance control....
just replace with same ohms.....replace example--- 100k with 100k 5k with 5k etc......any old C.B. ....stereo...dont matter...what matters is the ohms
Jan 25, 2010 | Radio Communications
Echo when connecting Samsung Plasma to Onkyo TX-SR602
Make sure you have the tv volume turned right down as this will cause an echo,also set amp to prologic 2, and set up xover to suit your speakers or go for the THX standard of 80 hrtz and as a rule of thumb set front L,C,R speakers to zero rears to about +4or5 and your sub to -5[ dont know which speakers you have but try setting the subs on board volume to the 10,o,cloak position],also make sure the speakers -,+ are wired the same at the amp and speakers.
Hope this helps.
CABLE GUY.
Jan 06, 2009 | Onkyo TX-SR602 Receiver
System echos when dvd is in. When I mute the Bose sytem I can hear the TV sound without the echo.
The echo you hear is the audio delay between your TV speakers and Bose speakers. Muting (or lowering the volume) on the TV will eliminate the echo. Some TVs have a setting to turn of TV speakers entirely, allowing you to listen to your TVs audio strictly through your Bose system.
Dec 20, 2008 | Bose 3·2·1 II System
I pluged in my speakers but the sounds are very low and wierd
you cant get echo on a specker there not made for that just normal sound
Nov 16, 2008 | Ozaki DT-500 3-Piece Speaker System...
Sound echo
I found that the best way to avoid this problem is to mute the television speakers or, if you can, turn off the speakers. There seems to be a very brief delay between TV and theater speakers, causing what sounds like an echo. hope this helps.
Oct 20, 2007 | Audio Players & Recorders
Emerson LC320EM9 32 in. LCD HDTV Logo
100 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
