Question about Garden
How to remove & internally clean the carborator from a husqvarna model 350 chainsaw
  • 2,239 Answers
Remove the top cover, twist and remove the air filter, there is a small spring that retains the throttle rod at the carb spindle, carefuuly unhook this, it also acts as the throttle sprindle return spring, depress the throttle trigger, hold the throttle spindle open with your finger and let the trigger go, you should now be able to lift the throttle push rod up and out of the spindle, pull the throttle rod away with the rubber boot attached, pull the earth return and cut out wire away from there terminals, unhook the air filter housing from the rubber straps, lift the carb up and use a 4mm allen key to remove the two retaining screws, pull the fiel hose off and remove the carb from the saw.
The pump side of the carb is an alloy plate held with a single screw, under here you will find a gasket and a pump diaphram, in that order, once removed you will find the main fuel filter, clean or replace, the metering side is a chrome plate held with four screws, you will find a diaphram and a gasket, in that order, once removed you will see the inlet needle and metering lever.
Posted on May 19, 2011
My Husqvarna chain saw 350 starts, then runs wide open, what could be the problem?
has a hi low idle jets
could need a carby clean and kit
but if an older model or has lots of uses
or needs a new carby
Nov 13, 2016 | Husqvarna Garden
How to remove gas tank from Husqvarna model yth2242t
David, Not your exact model, links to chainsaw tank removal. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Removing the Gas tank from Husqvarna 350
Husqvarna 372XP tank removal YouTube
Stihl 044 project 2 Gas Tank Replacement
Aug 20, 2016 | Husqvarna Garden
I want to clean the fuel filter on my chainsaw and cannot locate it. I took the carborator out but not filter seems to be in sight.
The fuel filter and pick up tube are located in the fuel tank..You can make a small hook out of a clothes hanger to remove tube from tank.If pick up body is damaged then replace it otherwise just clean thourghly.Thank you.
Mar 29, 2011 | Husqvarna Garden
Broke tooth on chain drive sprocket. whats the easiest way to get it apart to put on new one
Standard procedure for removal of the drive sprocket on the saws i work on are
release the chain brakeremove the sprocket cover... bar & chain clean all that sawdust and oil mud with brake cleaner and or bristle brushremove circlip with a flat head screwdriver and a prying motion* find circlipremove spur or rim sprocket Replace in opposite order.. being sure to align the chain speed driven oil pump with the notch in spur sprocket if equipped(some arborist saws require a piston stop to remove the clutch before you can remove the spur) BUY A STIH AND TALK TO YOUR DEALER.. THEY ARE FULL OF INFO AND VERY HELFUL
Jan 12, 2011 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Husqvarna 350 has spark and fuel wont start just quit running while in use
1- Is the mix (gas & oil) right? If its 2-cycle,check the manual.
2- Is the choke set?
hope this helps
Jan 06, 2011 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Husqvarna chain saw not starting. Seems to have lost compression. What should the compression be?
If its lost compression i would remove the two/three screws holding the muffler, take a look through the exhaust port at the piston, if there is any sign of scuffing or damage it is going to be cylinder off.
Nov 21, 2010 | Husqvarna ChainSaw 18 in Bar 32 HP Model...
Trying to find out what year and model my 350 husqvarna chainsaw is numbers on saw are 967 01 18-00 03 4103750 can you help ?
I am faily certain 967 01 18-00 has to do with the EPA.
If 03 4103750 is the serial number then;
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
03 4103750
03 = year produced – 2003 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
41 = week produced – October (05-11)
03750 = 3750th unit Husky produced that week (not saw, unit)
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 25, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Garden Logo
114 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
