Question about Canon IPF710 A0 Wide Format Plotter Printer
My IPF710...i have it connected to my network router, but cannot seem to get the printer to print
3 Suggested Answers
SOURCE: Canon MF4370dn printer network connection problem
I had the same problem. I entered the info manually and it works. You could follow the instructions on how to do it manually in the e-manual (on the CD).
To get the IP, subnet mask, and default gateway: open a command prompt from windows. At the command prompt, type "ipconfig" without the quotes. Write down the IP address, subnet mask, and default gateway.
For the IP, for example, if what you have from the step above is 192.168.0.100, add 10 (so that you wont have repeated IPs by auto DHCP from the router. I am assuming you have no more than 5 machines on your network.) to the last number to have 192.168.0.110 to enter manually into the printer. Use the same subnet mask and default gateway.
Hope it helps.
Linh.
Posted on Jun 02, 2009
canontech
  • 1219 Answers
SOURCE: Unable to print to canon IR 2020 when connected through router.
Try to conect directly with cross utp cable to an pc, if every thing works, its your network problem (maybe privilegies, banns,...) if not ... good luck :-)
Try to reconect the pcb s
Posted on Mar 02, 2010
Error 03800 500-280 C
Many nozzle on printhead did not inject .
You must clean your head or replace it. Or comes up in service mode
and check your nozzle check .For cleaning head you can take it out of printer and clean with head solvent, if not clears maybe u must replace print head.
Also check the canon ipf710 service manual from below link, it will save you money and time
Canon ipf710 service manual
http://goo.gl/e0h9OC
thanks
Nov 17, 2014 | Canon imagePROGRAF IPF710 Printer
How can I connect my printer to my wireless network
If you have a wireless-enabled printer, you can use the printer's configuration to connect it to the router. If you have a wired connection printer (ethernet port) connect it to one of the ports on the back of the router with an Ethernet cable and the printer should sort itself out. If your printer is not network-enabled, you will need to connect it directly to a network-connected computer, then use Windows' sharing settings to share the printer to the network.
Hope this helps, Alistair
Mar 15, 2011 | D-Link DIR-615 Wireless Router
We currently have a HP LaserJet 4600dn. The printer has been working perfectly fine for the last 9 months, however, today the printer does not seem to want to work. I tried printing a confirguration page...
Try changing the port on the router.
Also you can follow the cable from the printer to the router.
Check that the cable has not been damaged.
Replacing the cable and trying another port on your router is the cheapest option
before the HP Technicians come out.
Good Luck
Feb 16, 2011 | HP LaserJet 4600dn Color Printer
Error-03130031-2F26
I have downloaded the drives for the canon ipf710 but cant seem to get the online connection working
Oct 29, 2010 | Canon IPF710 A0 Wide Format Plotter...
I have a network installed model. Since som time:Scanning is working, copying is working but printing not. It seems that the PC signal is not coming to the printer. On the display: Replace and controll...
Try to reinstall the printer driver from the PC, ie, if you still have the CD. Otherwise download drivers from printer manufacturer's website. You have not provided any details on the printer model.
I am assuming you have a direct network connection to the printer. If more than one PC is connected using a router, then try with one PC connected directly to the printer first. You can reconnect through router after everything is working. Print Test page from the printer preferences menu.
Nov 11, 2009 | Computers & Internet
Printing to a network via wireless router
Usually wireless routers prohibit master browser (network neighborhood) communications from traversing between the wireless and wired computers. You can usually overcome this by setting a static ip address for the computers with the printers so that they are not a moving target (addresses are always changing with DHCP). Then you can use UNC paths to get from wireless computer to your target on internal network. For example, to connect to printer (with shared name BrotherH) on a wired computer with static ip address of 192.168.0.19, on wireless computer create a network printer and manually enter the address \\192.168.0.19\BrotherH , now the wireless computer should be able to traverse and connect to the wired printer.
Your wireless router should have a pool of static ip addresses available, say 192.168.1.1-49, you can specify this to your liking, and then you can also have a block of handed out DHCP numbers, say 192.168.50-60 or whatever.
Jan 26, 2009 | Linksys Wireless-G WRT54G Router
Network printing suddenly stopped working
Perhaps you might wanna try checking the IP address of the printer and see if it matches that of the ones that are mapped in each individual computer. There might be many factors in the "strange" events that have occured (PC gremlins, i call it). That should be an initial starting point.
Resetting the router wouldnt help, cause it is the router that issues different dynamic IP addresses (otherwise known as DHPC) to each and eveny node connected to the netwrok as well.
Another important thing to note is HOW these devices are connected to the router. Wirelessly? Wired connection? The fact that you can see the printer via the router means that there is no problem with the router's end, so the problem lies in the intermidiate connection from the computers to the router. Try to work on this angle. Thanks.
-Technomancer
Jun 02, 2008 | ASUS WL-500g Wireless Router (WL500GDLX)
Canon IPF710 A0 Wide Format Plotter Printer Logo
98 people viewed this question
old marine
old marine
