If I connect they don't work as the speakers' sound stopped as it is going to pass through the headphones
    Master:
  • 752 Answers
Rewrite this so it makes sense.
Posted on May 18, 2011
Chat live
1) you must the headphones in any radio, for to see if the problem they are.
2) if they are o.k go control panel use the utility system restore put the last date that you know that was working.
God bless you
Jul 25, 2013 | Sony VAIO Computers & Internet
I have a CD Stereo system SA-AK17, 120V, 145W, without speaker. I provided 2 speaker with the brand of Technics, input 200W(.music), 100W(DIN) each speaker. I bought Audio wire and connect speakers...
Some stereo system have the ability to switch off the speakers when playing via headphones. In others the headphone socket itself does the switching. However headphone sockets can become faulty and when the headphone plug is removed it doesn't restore sound to the speakers. It's very easy to fix this, with a check that the contacts are not bent out of place. Or you can rewire a new headphone socket, making a note of the wire connections before you replace it.
Sometimes it is quite difficult to get the speaker cable to make a good contact with the speaker sockets. You should check that they are making contact.
To test any loudspeaker just connect a 1.5 battery for a short time across the disconnected speaker. If working the speaker will pop!
As the sound is going to the headphones the amp seems to be OK and one of the above options should correct the problem.
Oct 27, 2017 | Panasonic SC-AK17 Shelf System
Headphone jack not functioning properly
This is the normal way for this laptop ..leave it always with the headphones on selected in that list ..cause if the main speakers don't work well there is no point in using them ..This way you will run whatever yo will plug in ..speakers or headphones..The only setting difference in headphones and stereo out ..is that for headphones will but the speakers of the laptop when plugged in ..This way it will even help you if the speakers are making weird noises cause they are damaged ..
Dec 22, 2011 | Computers & Internet
I bought this Acer aspire 7535g laptop off of my mum's friend which was in great condition when I bought it. The sound was perfect. Every driver was up-to-date. However now... 8 months on, the sound...
You can try booting a live linux CD or thumbdrive and see if that gives you sound. That will give you an idea if it's Windows or a hardware problem. If it's a windows problem try uninstalling and reinstalling your drivers. If that doesn't work keep searching around or just try a fresh install of windows.
Aug 27, 2011 | Computers & Internet
Dear Sir, Speakers are working but headphone is not working please tell me the solution.
Well you can only play sound through one device at the same time. If you wish to change the device to play audio from, using windows 7, go to the bottem corner of your screen, to the system tray. You will there see a speaker icon, rightclick it and click sound devices. Then figure out which device your headphones are (if there's multiple speakers showing up). Click the speaker you want to use and click the set as standard button.
You may have to restart the applications currently playing sound in case they don't play sound anymore or they still play through the wrong device.
Jul 24, 2011 | Computers & Internet
I want to watch some videos on my sharp lcd but using headphones without any sound coming from the speakers, but I don't find any headphone output. How can I do this??
First, since there is no proper headphone output on this television some people have been able to find an adapter to connect their headphones to. The other end of that adapter has a red and white RCA audio cable on it, and it would connect to your television's audio output. However I have heard from some people that they only get one volume level that cannot be adjusted when it works. Alternately you can connect your television to a sound bar or sound system that has an actual headphone jack and RCA audio inputs. If you still have a "boom box" sitting around with the RCA audio inputs you can connect the television to it as well. You need something to serve as a go between/center channel for this television that you can also connect your headphones to.
Jul 22, 2011 | Sharp AQUOS LC46LE700 46 in. LCD HDTV
How can I get headphones to work with my Symphonic WF203 TV?
This set doesn't have a headphone jack, nor does it have RCA audio output jacks. Without one or the other, you're out of luck connecting headphones to this TV.
I remember a product some years ago that allowed adding headphones using a small microphone placed in front of the speaker. This was hooked to a little amplifier that ran the headphones so the volume could be independently controlled. It was marketed as a way to let "hearing-impaired" family members listen to TV shows without needing to make it uncomfortably loud for others. I haven't looked, but something similar might still be available. It's cumbersome, though, and needs power, plus maybe being costly if you find one.
It's possible to add a headphone jack, but you need to know how to do electronic soldering. Find a spot on the case where you can make a hole and mount a headphone jack, then wire it to the speakers. If you want the headphones to cut off the speakers when plugged in, you need a switching jack, and the speaker wires need to be cut and connected to the correct terminals. The switch built into the jack then disconnects the speakers when the headphone plug is in. If you don't need to turn off the speakers it's a little easier. You just need to wire from the jack to the speaker terminals. I've added jacks on quite a few sets. If you don't feel up to it and don't know anyone who is, you can see if a TV shop (if there are any left in your area!) would do it. (The shop I used to work for charged about $20, including the jack, but that was over 10 years ago now.)
Good luck, and thanks for using Fixya!
Jun 12, 2011 | Symphonic WF20D4 TV
Sound still appear at speaker even when headphone was installed
Hello Again,
When you Plug in HeadPhones into the Laptop the Sound Playing should automatically Bi-Pass the Speakers and go Straight to the Headphones
-Unless there is a Faulty Input for the Speaker/ Headphone, Try Pushing in the Headphones More to see if the Speakers Turn Off
Hope this Works --P3NGYJ03
Jan 23, 2009 | Audio Players & Recorders
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
