Question about LG WM-2077C Front Load Washer
What does LE mean on the display - LG WM-2077C Front Load Washer
    Top Expert:
  • LG Master
  • 80,407 Answers
The 'LE' error message indicates the control board has detected that the motor is either not turning, or has locked up for some reason. Monitoring the motor is the job of the hall effect sensor board which constantly determines the direction and speed of the motor and feeds that information back to the control board. If there is a problem between what the motor should be doing and what the hall effect sensor says the motor is doing, the 'LE' will be displayed and the cycle will be stopped.
Motor lock can be caused by several things from a loose connector, to a bad motor, or even the hall effect sensor failing or dislodging from it's mount. Any one or more of these components could have caused this error.
Posted on May 18, 2011
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
Wm2016cw
LE errors mean the motor is locking up and cannot turn the drum. If the drum turns freely by hand then it could be https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/406-200-684484-/LG-LE-MOTOR-ERROR-Motor-Stator-overheat-or-connection-error-WM2016CW
If that is not the problem then the motor needs replaced.
Apr 15, 2017 | Washing Machines
ELE
Do you mean LE? Because a LE code means Overload in Motor.
May 11, 2012 | LG DLE2512W Electric Dryer
LE on the display panel
LE is a motor error.
Possible Causes: Wiring connections, Impeller is locked, Rotor is locked, and or the Blade is locked.
Remedy: Repair the wiring issue, Remove the item stopping the turning of the motor/rotor/blade, Replace the sump assembly, or Replace the main Power Control Board.
If your motor was making in knocking sound before this error, then your issue is probably the motor sump assembly. Just replace the sump assembly and your problem is resolved. You can get these from EBAY for about $105 with free shipping.
Good luck.
Jul 23, 2010 | LG LDF6810ST Stainless Steel Built-in...
My washer say LG what dose that mean
My washer stopped and displayed the LE error code. I turned off the power button and tried again, but after a few seconds it want back to LE. Finally, I unplugged the power cord, plugged it back in, and the washer ran normally.
Dec 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Whirlpool white magic h65 model.what is LE. AFTER
LE error will get displayed when the Lid is opened. Close the Lid and this will get resolved. Similarly you will get FE when the water is not flowing properly into the Machine its a Fill Error.
Nov 05, 2009 | Whirlpool Washing Machines
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
What does LE mean on the control panel
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
May 25, 2009 | Dishwashers
Error code LE
Hello and welcome,
locked.
locked.
Remedy:
Replace the PCB.
Jan 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
LG WM-2077C Front Load Washer Logo
93 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
