Stuck in sleep mode - Computers & Internet
  • 17 Answers
Press and hold the power button the system shuts off please restart
Posted on Aug 14, 2008
  • 1,800 Answers
Reset it and configure the power supply configurations again its in the windows configurations
Acer aspire z3750
hold down the ctr-alt-delete button same time should bring it out sleep mode and allow you to restart the pc. Once back on desktop go to power settings and turn sleep mode off.
Apr 20, 2014 | Acer Aspire Computers & Internet
Stuck on sleep mode
Unplug the AC adapter, detach the main battery, press the power button for 15 seconds. Attach the main battery, and restart the laptop.
Feb 12, 2014 | HP Pavilion Dv7-4065Dx Laptop Lcd Screen...
M305d-s4829 stuck in sleep mode
go to power potion and disable sleep mode
Jan 30, 2013 | Toshiba Satellite Computers & Internet
Dell gx400 stuck in a sleep mode
Click Start/Control Panel/Power Options and set the sleep or hibernate up to a high number or set it to NEVER.
May 24, 2012 | Dell OptiPlex GX400 PC Desktop
Acer3000 yellow light solid and will not power on Help! Is this motherboard issues?
It's very possible you have motherboard issues. Hardware failures will often resemble the machine being stuck in "sleep mode". You can try a power "reset" in case it is stuck in sleep mode. Press and hold the power button for 30 seconds. If successful, the machine will boot (probably in safe mode) and you should be able to re-configure your power settings to disable sleep mode. If this doesn't work, you most likely have hardware issues and the motherboard is most likely the culprit.
Aug 20, 2011 | Acer Computers & Internet
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Monitor is in sleep mode and I here a beep periodically
Try change the keyboard, if the pc does not detect the keyboard or a key from the key board is stuck which gives something like tic tic sound. On the other hand the display from monitor "sleeping mode" indicates the VGA cord is faulty or monitor is no compatible to the PC's video card.
Nov 26, 2008 | HP Computers & Internet
Sony KP53HS30 Stuck in Sleep Stand by
I don't believe it is stuck in the sleep standby mode, rather it has shutdown with an error. Is there a pattern to the flashing? Does it flash a set number of times?
Oct 19, 2008 | Sony KP-53HS30 53" Rear Projection...
Flat monitor is stuck in sleep mode
difficult to say what is sleep mode yellow light green ight blinking light pleas elaborate
May 10, 2008 | Computers & Internet
JVC tv "stuck" on sleep timer
I think you would have to turn off the sleep timer mode completely or increase its ON time span, say to 4 hours or so
or the lenth of time you have the TV on for. If that does not fix it then it sounds like a STANDBY MODE fault problem.
Hope this helps.
Feb 06, 2008 | JVC AV-27320 27" TV
Computers & Internet Logo
839 people viewed this question
David Payne
David Payne
